Liberty' Gears All Motor - Rules Update - Page 7 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Racing Organizations > Milan's Heads-up Shootout - Videos -News - Interviews
Old 07-23-2010, 10:22 PM   #91
John Langer
John Langer's Avatar
Default Re: Liberty' Gears All Motor - Rules Update
Quote:
Originally Posted by Chris Uratchko View Post
350 what head? I got a set of those too.....
BMF 355 ya jackass
John Langer is offline   Reply With Quote
Old 07-23-2010, 10:24 PM   #92
Chris Uratchko
Moderator
Chris Uratchko's Avatar
385 to be more precise.
Chris Uratchko is offline   Reply With Quote
Old 07-23-2010, 10:28 PM   #93
MattG
MattG's Avatar
Quote:
Originally Posted by John Langer View Post
What about 1hp per cid over the 525? That is deffinately possible. The 525 bbc with the 355 head made 1176 with a 1150 carb and c-25. The big carb is worth 5 and the fuel is 12. So you got 18hp with 52"?? What did it average in the power band compared to the 525? When I went from a 477 to a 525 I picked up around 35 peak but 62 average.
Not sure on the average numbers at the moment but at peak my 577ci made 1209hp. That is with a 1250 2.125" carb and Q16. The only differences with my motor from a 525 would be a non billet crank and an internal oil pump. So I guess you are right, 18hp for 52ci, give or take a few ponies for the oil pump. That is with 385ish cc Brodix heads too. I would be real surprised to see much over 1250hp outa a 632 with conv. heads
I really do not want to argue about the rules since I have never yet ran in the class but I want to make sure things are kept real in regards to the capability of conventional heads.
MattG is offline   Reply With Quote
Old 07-23-2010, 10:31 PM   #94
John Langer
Not on an nmca pro stock motor... ya jackass
Old 07-23-2010, 10:33 PM   #95
John Langer
Did Tony do the heads from scratch or did he work on what someone else started?
Old 07-23-2010, 10:34 PM   #96
MattG
MattG's Avatar
Everything was done from scratch by Tony. We used my valvecovers, belt drive and vacuum pump from my previous motor.
Old 07-23-2010, 10:35 PM   #97
Chris Uratchko
Moderator
Oh my bad John.... You can go back to asking if your engine is a small block or big block.... smarty. And I would suggest you keep your name calling to yourself.
Old 07-23-2010, 10:36 PM   #98
Mark @ Meridian Tool
Mark @ Meridian Tool's Avatar
Quote:
Originally Posted by Ben Mens View Post
And how is that? Is there several BBC conventional headed cars about to show? Is this a qualified 16 car field? Does that mean the few small block guys that were showing up will now become non qualifiers? Yes, interesting development..........
Ben I can't speak for anyone but me. I don't think this significantly
changes who are the hitters are in the class. Nor do I think it will lead
to that.
Mark the Machinist
Thanks to:
Racetech Racing Engines Scott Carter
C.A.R.S. Sean Collins
TeamZMotorsports Dave Zimmerman
Greg Powrie
Mark @ Meridian Tool is offline   Reply With Quote
Old 07-23-2010, 10:40 PM   #99
John Langer
Didn't you ever see the movie happy gilmore?
Old 07-23-2010, 10:42 PM   #100
Chris Uratchko
Moderator
No I have not... I'm a little sheltered.
Old 07-23-2010, 10:43 PM   #101
John Langer
Rent it and then you will understand my comment... ya jackass
Old 07-23-2010, 10:49 PM   #102
Ben Mens
Ben Mens's Avatar
We have a near 600 inch BES conventional engine coming that makes 1225, the 525 is not a concern. Dave Theisen is coming and his 598 is making around 1175. Should be good racing.
If those combination's are not running with the fastest cars in the class weighing only 3150 lbs there will be something very, very wrong........
Lucas Oil Products / Dart / Total Seal Piston Rings / Trick Titanium / Wiseco Pistons / Scott Rod Fabrications / Motorcity Solutions / Mike's Garage
Ben Mens is offline   Reply With Quote
Old 07-23-2010, 10:52 PM   #103
Butch Kemp
Butch Kemp's Avatar
X 6 trillion.
Took my bat and ball to play in ultra street.
ET record holder 4.773
Do it right the first time
Keep your promises
Dream BIG
Thanks to:
Chris Uratchko
Mickey Thompson tires
Marty Chance
Dean marinis
Butch Kemp is offline   Reply With Quote
Old 07-23-2010, 10:57 PM   #104
MattG
MattG's Avatar
What should be faster, 1400hp @ 3300lbs or 1225hp @ 3150lbs?
Old 07-23-2010, 11:05 PM   #105
Ben Mens
Ben Mens's Avatar
How about comparing either to a 900 or 1000 HP (?) small block that weighs 2900 lbs? I would then say "both".
