brodix spread port heads ? - Yellow Bullet Forums
Old 07-20-2010, 10:36 PM   #1
raymond humphries
Launchin
raymond humphries's Avatar
Default brodix spread port heads ?
I just got a motor and it has brodix 10x spread port heads. I have 2 questions if anybody can help. What is the advantages of spread ports, and where can i get a set of headers to fit em in a 67 camaro , for a reasonable price ?????
raymond humphries is offline   Reply With Quote
Old 07-20-2010, 10:43 PM   #2
jeff c
pig hunter
jeff c's Avatar
Default Re: brodix spread port heads ?
stahl headers. spelling http://www.stahlheaders.com/
sr-20 headed 4.60x3.70=492cid 2.49 per cid @ 9100rpm's
jeff c is offline   Reply With Quote
Old 07-21-2010, 12:52 AM   #3
ERV JR
ERV JR's Avatar
headman also makes spreadport headers for them
ERV JR is offline   Reply With Quote
Old 07-21-2010, 07:28 AM   #4
T-flow
T-flow's Avatar
Keeping the heat out of the the middle cylinders. You should be able to find headers from most of the companies.
T-flow is online now   Reply With Quote
Old 07-21-2010, 09:45 AM   #5
Vader Ta
Procharged SBC Enthusiast
Vader Ta's Avatar
You can also give Lemons a call.
Vader Ta is offline   Reply With Quote
Old 07-21-2010, 06:36 PM   #6
raymond humphries
Launchin
ok thanks
Old 07-21-2010, 06:40 PM   #7
69decvr
Spooled up
69decvr's Avatar
Pretty sure I saw a set on Racingjunk for a 1st gen camaro not too long ago.
69decvr is offline   Reply With Quote
Old 07-21-2010, 09:13 PM   #8
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
I used Lemons, so did a friend of mine. Not cheap, but they are worth it. Certainly other companies out there that also make them.
Mike Beck is offline   Reply With Quote
Old 07-21-2010, 09:29 PM   #9
jeff c
pig hunter
jeff c's Avatar
with those heads, if your going to spray the chit out of it, you can put a water fitting right between the middle exh ports just below the port to remove heat that chevy's have a hot spot there.
Old 07-21-2010, 09:35 PM   #10
4digitHP
4digitHP's Avatar
i used hedman huslers on mine. two inch primaries, 3.5" collectors. really nice headers and once on the car they fit great! but i am not going to lie, they were tough to get on. lol take engine loose jack it up al that good jazz. that was drivers side. passenger side fit great!
1968 camaro, turbo lsx, leaf springs on 275s.
under construction
4digitHP is offline   Reply With Quote
Old 07-22-2010, 08:40 PM   #11
raymond humphries
Launchin
yea i talked to hedman they have em ,thats what im probably going with if i cant find a used set. they not cheep ether . and yes i am planing on spraying it probably 200 are so , have to see what it runs first . thanks for advice
Old 07-26-2010, 08:40 AM   #12
AJensen383
Pre-Staged
I'm new here, but I just wanted to chime in... I have a set of Hedman Hustlers FOR SALE.. 1-7/8" x 3 1/2" that fit a spread port Brodix in an early camaro.. I had them on my 70 Nova, so its the same header you need. I also have the heads for sale as well.. They are a -8, spread port ported by Andy Jensen and flow 280+.. I know not stellar, but for a 194cc head, its pretty decent.. Let me know if interested in either or both
AJensen383 is offline   Reply With Quote
Old 07-26-2010, 09:42 AM   #13
69RS
69RS's Avatar
AJensen 383, Sent you a pm for Raymond, he is at work.
69RS is offline   Reply With Quote
Old 07-26-2010, 08:17 PM   #14
raymond humphries
Launchin
yea i need the headers , send me your phone # so we can deal . thanks
Old 07-27-2010, 12:41 PM   #15
AJensen383
Pre-Staged
Quote:
pm sent
