how much boost can a stock sbc take? - Page 2 - Yellow Bullet Forums
Old 07-19-2010, 05:06 PM   #16
Collinsautomotive
Default Re: how much boost can a stock sbc take?
Quote:
Originally Posted by jim loveland View Post
ok didnt really explain what im doing im talking totally bone stock 350 its a jasper crate motor i bought on craigslist i fliped it over checked acouple of bearings and went with it. Runs great .Do you think this would survive with 3 to 5 lbs of boost? i have my timing locked out at 36 degrees and taking a degree out per lb of boost
depend on the heads. If it is iron headed I'd take 1.75 degree per pound or maybe 2 per psi. that siad I have seen stock SBC engines take 15 psi without to much complaint. I have not personally done this. So your results may vary.
Henry Ford, on the stock market
Quote:
"As betting at the race ring adds neither strength nor speed to the horse, so the exchange of shares in the stock market adds no capital to business, no increase in the production and no purchasing power to the market."
Old 07-19-2010, 05:12 PM   #17
pjohnson
pjohnson's Avatar
KEEP IN MIND MY SHIT WAS OFF ALL THE WAY THROUGH....My HP output was only 550, but I slammed 22 lbs of boost to get there. The block showed no signs of wear. I have scrapped the whole motor at this point and I am starting over
Quote:
Originally Posted by Max rider View Post
I retract all my statements ever made about John Sears. You are the man John!!!
pjohnson is offline   Reply With Quote
Old 07-19-2010, 10:23 PM   #18
pjohnson
pjohnson's Avatar
I was thinking about my post, I may have an answer to your original question LOL.
I WAS WRONG IN MY ORIGINAL POST ( i think i screwed the pooch on dyno not at the track)
After thinking about my post MAYBE that 22 lbs of boost did hurt it. 5 passes later my oil was silver in color and loses 38 pounds of oil pressure once it gets hot. That dyno session was the only time it saw 22 pounds of boost was on that dyno run. It only got to 550 in HP this motor was shit from day one
Old 07-20-2010, 08:55 AM   #19
Mattsv8_03
Member
Pullin gears
Mattsv8_03's Avatar
my friend if you need 22lbs to make 550. u need a larger turbo very bad. thats insane boost for a v8 to only make 550.
the heat alone had to be killing it.
My 82 s10 lb 8.89 at 152.78 on pump E85. 15lbs boost 357"sbc 8.4:1
89 s10 blazer 9.90 nitrous 335" sbc 12.4:1 e85 homemade 750 225 shot
2001 z28 camaro hooker lt ofy flowmaster slp lid bellows. Awaiting the turbo kit I built for it that keeps ac and stock rad location.
2001 tahoe bone stock
1997 gmc yukon 2.5" lift 285/75 tires trailer puller.
Mattsv8_03 is offline   Reply With Quote
Old 07-20-2010, 02:20 PM   #20
JR.
Burnout box
all depends on how the car us tuned and how much tq ur rods and rod bolts can handle.
JR. is offline   Reply With Quote
Old 07-20-2010, 10:11 PM   #21
jim loveland
Member
Pullin gears
jim loveland's Avatar
It does have iron heads on it.I want to take it to the track and see how fast it will go i still dont have a cage in it.Not sure how fast it will be?
jim loveland is offline   Reply With Quote
Old 07-21-2010, 10:14 AM   #22
pjohnson
pjohnson's Avatar
Well I have an s480 w 96 mm wheel and 132 ar. This motor upon arrival was NOTHING it was supposed to be. I am sure the motor and cam, and heads were the reason this thing wasnt working. I am not even trying to fix it. I am starting over.
Old 07-21-2010, 10:51 AM   #23
jon volk
jon volk's Avatar
Quote:
Those numbers would make sense if it has factory TBI cam in it.
92 325i Mtech, 4.8 LS, th400 and a small plate.
95 M3, forged L33, 7675 CEA, TH400/Gear Vendors
jon volk is online now   Reply With Quote
Old 07-21-2010, 11:37 AM   #24
pjohnson
pjohnson's Avatar
It was a custom ground lunati cam solid roller (when I got the motor is saw what they had and threw it out) LOL. Also when I got on trans brake it too 9 to 11 seconds to get 7 pounds boost. hellI even put accel gen 7 on it, and had ti to 2 different tuners.
This thing was a disaster
Old 07-21-2010, 11:55 AM   #25
jon volk
jon volk's Avatar
Yikes. What heads and how much timing was in it?
Old 07-21-2010, 12:35 PM   #26
pjohnson
pjohnson's Avatar
Quote:
Actually I dont remeber on the timing, when this piece of shit showed up it had procomp heads. I as fla stuck all the way across the board on this piece of shit
Old 07-21-2010, 10:22 PM   #27
Mattsv8_03
Member
Pullin gears
Mattsv8_03's Avatar
i would say. good luck with the build will deff run better this time arround.
Old 07-21-2010, 10:42 PM   #28
jeff c
pig hunter
jeff c's Avatar
you can beat the chit out them if the block prep and tune is right. i have seen them in the 1100-1200hp range with a turbo. 900-1000 on nos.
sr-20 headed 4.60x3.70=492cid 2.49 per cid @ 9100rpm's
jeff c is offline   Reply With Quote
Old 07-21-2010, 11:16 PM   #29
Mi.5.0Fred
Mi.5.0Fred's Avatar
OK guys, can you answer this: my Brother has spun #8 rod bearing on 2 sbc's. 5lbs boost fromWeiand blower street driven. The 290 hp crate motor was T&T 15-20 passes and maybe 1500 miles. The 305 lasted about 200 miles, never made it to the strip.
Mi.5.0Fred is offline   Reply With Quote
Old 07-21-2010, 11:41 PM   #30
slowstang101
slowstang101's Avatar
cylinder head design on chevy's suck for boosted applications. Two exhaust valves very close to each other....not good for longevity
2000 Mustang - SBF, PT106 on Ethanol
slowstang101 is offline   Reply With Quote
