BBC 565 Bore and Stroke - Yellow Bullet Forums
Old 06-07-2007, 11:00 AM   #1
Mark @ Meridian Tool
Mark @ Meridian Tool's Avatar
Default BBC 565 Bore and Stroke
I'm about to purchase the rotating kit for a BBC 565.
It will be a 4.600" bore Dart Big M 9.8 deck, with Dart CNC 355 heads w/110 chambers.
I'd like to hear some educated opinions 4.25" stroke with 6.385" rod vs.
4.25" stroke with 6.535" rod, and the rq'd comp heights/ring packs
for these packages. Any pro's and con's to either set up?
This engine may see as much as a 400 h.p. shot in the future.
Mark @ Meridian Tool is offline   Reply With Quote
Old 06-07-2007, 11:48 AM   #2
NOS-Nelson
Procharger Power
NOS-Nelson's Avatar
Default
4.250 stroke and 6.385 rod will give you a 1.27 CH with the piston .020 in the hole. If you use an .043 upper Hellfire you can get the top ring down .350. The 6.535 rod works with a 3.950 stroke and the same piston.
This is for a 9.800 block I assume?
NOS-Nelson is offline   Reply With Quote
Old 06-08-2007, 10:01 AM   #3
68Bird
68Bird's Avatar
Default
Wouldn't the 4.375 stroke be a 582? Sorry if I'm stating the obvious but you said you wanted a 565.
Craig
68Bird is offline   Reply With Quote
Old 06-08-2007, 10:36 AM   #4
Default
Quote:
Craig
Oops! You're right. The point of the question is the different rod lengths and
comp heights. Original question edited!
Old 06-08-2007, 12:01 PM   #5
NOS-Nelson
Procharger Power
NOS-Nelson's Avatar
Default
N/A = Long Rod, Nitrous = Short Rod.
Old 06-09-2007, 05:13 PM   #6
Default
My decision just got very easy.
I just bought a lightly used Callies Pro Magnum 4.25" , 6.535" Oliver I beams,
Je 4.6" piston set , and ATI balancer for less than an Eagle rotating kit ($1600).
This should be a slight step up from my current 431" BBC. LOL.
Time to hit the machine shop!
Old 06-10-2007, 09:04 PM   #7
NOS-Nelson
Procharger Power
NOS-Nelson's Avatar
Default
That's a good deal but I wouldn't spray it.
Old 06-11-2007, 08:30 AM   #8
Default
Quote:
Honestly, I think that would be well down the road for me. This thing could go
high 9.20's n/a. That's considerably quicker than I've ever been. I'll be spending
the off season on safety and brake system upgrades.
When you say you wouldn't spray it , you mean within limits, or whatsoever?
Old 06-11-2007, 11:24 AM   #9
NOS-Nelson
Procharger Power
NOS-Nelson's Avatar
Default
With that combo you are running roughly the same CH as a 632. It all depends on if the top of the oil ring land is zeroed with the top of the pin. Even then the top ring is still going to be higher on the piston than desireable. I've done it myself but you have zero room for error.
Resources saved on this page: MySQL 1.08%
