instant center in a mustang?? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension - TRZ Motorsports
Old 06-27-2010, 11:36 AM   #1
n20mstr
n20mstr's Avatar
Default instant center in a mustang??
With the stock arms or replacement ones in the stock loc. WHere is the instant center in a mustang. Just asking because i am helping someone and we want to know where it is so we can make a decision as to where we might want to move it to. OR is it good in the stock spot and we should just concentrate on shock tuning? The car is '87 mustang
n20mstr is offline   Reply With Quote
Old 06-27-2010, 12:58 PM   #2
mach9
Default Re: instant center in a mustang??
If you're talking about a stock Fox body, there isn't one. Lines drawn through the center of the upper and lower control arms will never intersect. They keep getting further apart. There are some cars out there that work well like that. But, most would benefit from a geometry change. Just my humble opinion.
Mack Johnson
'86 Mustang footbraker
Pump gas 347
6.435 @ 104
https://www.facebook.com/NCslottracks?ref=hl
mach9 is offline   Reply With Quote
Old 06-27-2010, 01:59 PM   #3
feetfirst
feetfirst's Avatar
Quote:
It depends what the ride height is............odds are its around the front wheel area somewhere..
This 25.5 chromoly-stock suspension car is FORSALE!!!
feetfirst is offline   Reply With Quote
Old 06-27-2010, 03:22 PM   #4
n20mstr
n20mstr's Avatar
Quote:
what change do most make?? Im thinking lower the lower arm at the rear end? this will move the center back in the car??
Old 06-28-2010, 12:50 PM   #5
Battlestar
Battlestar's Avatar
Stick/automatic? 11 sec? 9 sec?
Most local guys running stock locations, but are all stick cars leaving hi rpm. Using air bags to keep the rear from squatting too much. Most in mid/hi 1.4 60ft. on good track. Leave sway bar on back also to keep level. Hurts to remove it unlike the front one.
I'd leave the lower arm level and adjust the upper one at front mount. There are torque boxes available to give you 3 options for front mount. If you are leaving hard enough the stock boxes will be pulled apart anyway, so might as well upgrade now.
United Manual Transmission Racer
2006 UMTR Points Champion
2009 UMTR Points Champion
"I get pushed outta shape and it's hard to steer, but I get rubber in all four gears"
Battlestar is offline   Reply With Quote
Old 06-29-2010, 07:49 AM   #6
notsobroke
X275 O.G.
notsobroke's Avatar
depends on the power level??? lowering the lower arm on the rear will will make for alot of bite which can also be an issue as the car tries to pound the tire to the ground
Ultra Street
"Rules? what you talking about rules?"
------X275 RETIRED-------
X275 The Offical S**T SHOW of RACING
UPR, ROSS RACING PISTONS, CRAZY DON'S,
JC PERFORMANCE, KOGAN MOTORSPORTS, INDUCTION SOLUTIONS, PTC , AMITYVILLE AUTOBODY, Schoneck Composites, WILL2SWEAT.COM, SECONDFLIGHTSTUDIO...
New Ultra Trim
SMALLBLOCKPOSSE
notsobroke is offline   Reply With Quote
Old 06-29-2010, 09:00 AM   #7
SmallBlockNova
aka Nova Joe
SmallBlockNova's Avatar
Tony, it depends on way too many variables like ride height, and tire size both front and rear. I agree with Richie, moving the lower bar down like what a SSM bar does is a good quick fix for a "slower" car...No doubt they work well but that really high/short instant center gets to be too much when you start adding lots of power. I'm a big fan of treating the factory triangular 4 link just like a parallel 4 link, with the lower bar as flat as possible and the upper on a downward angle. If your car is low, you can usually get the geometry pretty good with factory mounting points. If you can't get it low enough, Baseline Suspension as well as I think Team Z make brackets and uppers that raise the back part of the upper control arm.
Thrift-Way Auto Body & Chassisworks
www.thriftwayautobody.com
Al-Lee Motorsports - BAE - Resolution Racing - Staria's Transmissions - Scotty's Racing Engines - JTS Carbs
SmallBlockNova is offline   Reply With Quote
Old 06-29-2010, 07:21 PM   #8
n20mstr
n20mstr's Avatar
Rich.......we need to talk ?? You know i like lots of bite (wheelies LOL) My own instant center is down and i run loose shocks
Joe....why are you saying the car has lots of power?? LOL Just kicking it around. I see so many of these cars out there and i know that my instant center is fixed (ladder bar) BUT i have it as far down as it goes (Bar is in the bottom hole and its 2* down) Just wondering aS ive seen some pics (punisher) that had adj for the lowers and uppers. I understand these cars are short wheelbase and can be light, Just trying to figure something out,
Thanks for the replys, at least i see im going in the right direction.
Old 06-29-2010, 07:25 PM   #9
notsobroke
X275 O.G.
notsobroke's Avatar
shoot me a call .. i can steer you in the right direction
Ultra Street
New Ultra Trim
SMALLBLOCKPOSSE
Old 06-29-2010, 10:27 PM   #10
whatbumper
Member
Pullin gears
whatbumper's Avatar
Without getting into it too much all I'm gonna say is most of the quickest stock suspension mustangs in the country use the factory mounting locations.
whatbumper is offline   Reply With Quote
Old 06-30-2010, 07:47 PM   #11
1bad396
Member
Pullin gears
1bad396's Avatar
Hey tony i built that 8.50 275/60/15 fox body , got wolf dbl adjustable uppers , urp lowers , cut coil springs , strange single adjustable shocks, wolf anit roll
60' 1.30 all day . will go 1.23 if we turn it up . ya know just a 8.50 car
Ultra street 4.752 @ 147.50
Romeo brothers Racing
Romeo's Automotive
M.O.S Builders
MRP Plastics
1bad396 is offline   Reply With Quote
Old 05-28-2015, 10:30 PM   #12
yardbird
Launchin
Default
Does anyone have measurement to weld these on front back from lower control arm to the different holes
yardbird is offline   Reply With Quote
Resources saved on this page: MySQL 2.20%
