Short "header" Spark Plugs - Yellow Bullet Forums
Old 06-23-2010, 08:00 AM   #1
mayhem
mayhem's Avatar
Default Short "header" Spark Plugs
I'm sure you guys have seen them, short plugs for more header clearance, sold by Accel (not sure who makes them).
Other than a good selection of heat ranges and such, is there a big perforance drop using these?
I've used them plenty on street small blocks that had (cheap) header clearance issues. I've also used them on angle plug heads with standard headers.
My question is for my 540'' BBC / Dart 360's. It has Hooker Super Comps and they fit HORRIBLE. #6 takes three men and a boy to change the plug - with a modified (shortened and split socket). #8 is almost as bad and the other just plain suck, except for 1 or 2. Once I pulled the header just to change the plugs.
mayhem is offline   Reply With Quote
Old 06-23-2010, 08:04 AM   #2
Chris Uratchko
Moderator
Chris Uratchko's Avatar
Default Re: Short "header" Spark Plugs
Shoot Rick I haven't used those since the early 90's... didn't even know they still made them!!
Chris Uratchko is offline   Reply With Quote
Old 06-23-2010, 08:10 AM   #3
ROB
I don't know if this has changed or not, but at one point in the past when I had to use these the heat range selection was very limited.
"The masses have never thirsted after truth. They turn aside from evidence that is not to their taste, preferring to deify error, if error seduce them. Whoever can supply them with illusions is easily their master; whoever attempts to destroy their illusions is always their victim."
Gustave Le Bon (1841-1931)
ROB is offline   Reply With Quote
Old 06-23-2010, 08:25 AM   #4
mayhem
mayhem's Avatar
Quote:
Yes, selection is very limited. I've read a few other companies make them as well. I also read AC makes this short plug for Accel.
In a pinch, they work bad ass, especially on (street) small blocks with the wrong headers.
An .800 lift Roller in Aluminum Headed BBC might be a different story.
Old 06-23-2010, 07:17 PM   #5
kens86
i used to run them but now i run autolite ar13. which is the same length as the accels. and a dollar cheaper.
selling tool box in trash section
kens86 is offline   Reply With Quote
Old 06-23-2010, 08:09 PM   #6
whitey70ss
whitey70ss's Avatar
^^^good to know!!!
whitey70ss is offline   Reply With Quote
Old 06-23-2010, 08:12 PM   #7
a1elec
Member
Pullin gears
a1elec's Avatar
rick i will throw this out there you can see if you have the room i just bought header flanges from spd to match my heads. they spaced them out 3/8 and gave me the clearance i needed. john
a1elec is offline   Reply With Quote
Old 06-23-2010, 09:23 PM   #8
rippinriley
Spooled up
rippinriley's Avatar
Quote:
same here used those ar13 in a few different cars , most autoparts have them in stock & they are cheap
rippinriley is offline   Reply With Quote
Resources saved on this page: MySQL 2.25%
