1st gear band in powerglide - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 06-22-2010, 09:14 PM   #1
.Net Boyz
Default 1st gear band in powerglide
how often do you guys usually adjust it?
Petey SmallBlock Promotions
TakeDown II 2016 May 28 @ Cecil County Dragway
No Prep Race May 29 @ Cecil County Dragway
Extreme Racing ENGINES, Team Z Motorsports, ThriftWay Chassis Works, ARC, ultimate Converters, GrudgeWearApparel.NET, Sk-Speed
.Net Boyz is offline   Reply With Quote
Old 06-22-2010, 09:54 PM   #2
outlawss
"Made" Member
outlawss's Avatar
Default Re: 1st gear band in powerglide
Good question, i was just wondering the same thing last week....
Quote:
Getting ready to put an ass whoopin on someone.....
http://youtu.be/S6qXcDJr0fc
http://youtu.be/mI9HrjxYyQg
http://youtu.be/YTH_A2eQ1sY
outlawss is offline   Reply With Quote
Old 06-22-2010, 09:57 PM   #3
.Net Boyz
and whats a sign that it might be time to adjust it?
Old 06-22-2010, 10:53 PM   #4
SHAKEY
SHAKEY's Avatar
if you have to adjust it more than once?? i see problems in your future. i adjust it,on the bench... then after we make a few passes. readjust it. after that.. we run them till they give up. if it needs adjustment often?? its slipping and wearing out the drum and band!! hope this helps
523 CID STOCK BLOCK BBF, TWIN TURBO, STREET RIDE!!
I SURVIVED DRAGWEEK 09
BIG STUFF 3 DEALER/ INSTALLER/TUNER
HOLLEY EFI DEALER/ INSTALLER/TUNER
FAST XFI TUNING
STS TURBO DEALER/INSTALLER
OWNER/OPERATOR OF MUSTANG 1750HD CHASSIS DYNO
SCT TUNING AND CHIP BURNING
HP TUNERS CUSTOM TUNING
www.schexnayderracing.com
SHAKEY is offline   Reply With Quote
Old 06-23-2010, 01:04 AM   #5
Hutch
Moderator
Hutch's Avatar
For what it takes , check it every time you get back from racing along with your regular maintenance. If it keeps changing (getting loose) , the trans is taking a dump and you can get the band replaced or make neccessary changes before its to late.
Hutch
www.hutchtrans.com
519-453-4318
Hutch is online now   Reply With Quote
Old 06-23-2010, 01:13 AM   #6
onefast68
onefast68's Avatar
will to loose make it back up or roll forward when you get on the transbrake?
68 camaro..3300lbs........
big duke 632 with 2 kits ..
4.95 at 145.8 ................
onefast68 is offline   Reply With Quote
Old 06-23-2010, 01:25 AM   #7
Hutch
Moderator
Hutch's Avatar
Quote:
Loose usually makes it backup when you get on the brake.
Hutch
www.hutchtrans.com
519-453-4318
Old 06-23-2010, 01:26 AM   #8
rskrause
rskrause's Avatar
Once a SEASON. Really.
rskrause is offline   Reply With Quote
Old 06-24-2010, 01:30 AM   #9
Hutch
Moderator
Hutch's Avatar
Quote:
Do you check your valves once a season too?
Hutch
www.hutchtrans.com
519-453-4318
Resources saved on this page: MySQL 1.12%
