BBC CAM SUGGESTIONS - Page 2 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Valvetrain
Old 07-20-2010, 02:35 PM   #16
low warranty
low warranty's Avatar
Default Re: BBC CAM SUGGESTIONS
With a bigger cam, more CR wouldn't hurt either. Have you actually measured your compression ratio or do you just have 12.5:1 pistons?
Special Thanks to:
Billy Briggs
Jim-Powski Racecraft
Joels on Joy
TRZ Motorsports
DADS Custom Intercooler Tanks
RCS
low warranty is offline   Reply With Quote
Old 07-20-2010, 04:19 PM   #17
69camaro
Burnout box
I have 12.5 to 1 pistons,. I did not do any actual measuring. No I did not degree the cam when I installed it.
69camaro is offline   Reply With Quote
Old 07-21-2010, 01:20 AM   #18
scott foxwell
scott foxwell's Avatar
Did you flow your heads? If not, you're throwing darts at a dart board and leaving plenty on the table with off the shelf stuff. I did a 12.4:1 467 quite e few yers ago with some Canfield 310's that honestly, I went backwards with on the flow, but with the flow numbers and build specs, I had Chris Straub spec a roller for it, and with a TR and pair of 1050's it made 821 @ 7100, 680 @ 5500, and had a very flat curve. Here's the kicker...the cam was 717/663 261/266. Not much of a cam for the power. No need to scream the engine to make good power.
If you want the most out of your combination, flow the heads and get the right cam.
JMO
Induction Development Specialties
Retail/wholesale parts sales
Custom cams
423 391 7774
New Canfield BB Chevy heads now available!
Acts 2:38, the perfect answer to the perfect question.
scott foxwell is offline   Reply With Quote
Old 07-21-2010, 07:09 AM   #19
69camaro
Burnout box
Getting the heads flowed for true numbers and measuring for correct compression ratio may be the best place to start. Thanks
Old 07-21-2010, 09:46 AM   #20
jeff c
pig hunter
jeff c's Avatar
like scott said^^^^^^ it 's the ONLY WAY!! comp cams would be one of the last i called. theres intake valve timing, exh valve timing, lifter of the cam and profile i.e how fast the lift accelerates this is why no two cam will ever make the same power unless there form the same company ground the with the all same spec.
sr-20 headed 4.60x3.70=492cid 2.49 per cid @ 9100rpm's
jeff c is offline   Reply With Quote
Old 07-21-2010, 09:57 AM   #21
low warranty
Here is what I would do;
1) Degree cam - VERY IMPORTANT
2) Measure ACTUAL compression ratio, you are probably lower than you think
3) Flow heads
4) Select proper cam for combination
5) Make sure torque convertor and axle ratio match accordingly
Special Thanks to:
Billy Briggs
Joels on Joy
TRZ Motorsports
RCS
Old 07-22-2010, 09:28 PM   #22
slowstang
slowstang's Avatar
JMO
very good advise here,also many factory chevy bbc heads have flow issues past 700 lift thats what the backing up is that is talked about so just jaming in more lift as others have recommended is a big mistake without a flow bench first.
slowstang is offline   Reply With Quote
Old 07-26-2010, 12:21 PM   #23
krash76
Burnout box
krash76's Avatar
did you like the way the 270 -280 cam worked .... with a roller you can go bigger and still gain power through the entire power band..... I too agree go bigger and you will go faster.... at least 6-8 degrees.
krash76 is offline   Reply With Quote
Old 07-27-2010, 08:06 AM   #24
69camaro
Burnout box
Pulling the motor this coming weekend . Car ran excellent with the 270/280. I screwed up with the roller selection thinking the steeper lift angle made the valve full open quicker so not as much duration was needed. Thats why I didn't question Comp Cams online selection.
Old 07-27-2010, 10:55 AM   #25
TR Chassis
TR Chassis's Avatar
Quote:
I really think you need to degree it. Some of these cams coming off the shelf are off more than 4 degrees depending on a bunch of factors. Just my 2 cents.
Rick
TR Chassis is offline   Reply With Quote
Old 07-30-2010, 10:15 AM   #26
Scott McMullen
Let the Clutch Out
Scott McMullen's Avatar
Intresting Thread , I too have a 3800+lbs car with a 454 with too big Dart Race Series 320's and a cam with less than .600 lift and 245-250* of duration. I know I do Have a Honest 12 to 1 comprerssion tho. I am looking at this winter going too a bigger roller and was recommended 274*/278* .435 .435 LL on a 108 and if there is room and Cash I want to go to a rocker shaft . I Have 28 inch tall tires and a 4.56 gear all I need is a new Convertor to match the rest of the set up
Scott McMullen is offline   Reply With Quote
Old 07-31-2010, 10:31 PM   #27
nosnerd
SomeWhat Jaded
nosnerd's Avatar
look into the Comp 11-702-9...its a great piece that is easy on valve springs..
271/282 with .680 lift on 110 LSA...
i will be on the dyno with this cam in about a week in a 522..i will let you know how it turns out...
there is also the old Crane standby, 274/284 with .737 int and i cant remember on exhaust...on 110..also easy on springs and makes great TQ and HP...IIRC #134751...
i personally would not go over 274 on intake...
"IGNORANCE SHOULD BE FUCKIN' PAINFUL"
522/798hp + NOS/I.S plate
Doin' it on 315's at full weight, ladies
*ULTRA PERFORMANCE and FABRICATION *
www.DandDPerformance.ca
nosnerd is offline   Reply With Quote
Old 08-03-2010, 09:23 AM   #28
low warranty
Quote:
Rick
X4!
Special Thanks to:
Billy Briggs
Joels on Joy
TRZ Motorsports
RCS
Old 08-19-2010, 02:35 PM   #29
69camaro
Burnout box
Something I forgot to ask, I'm running 2, 08an lines from cell to y-block then to mallory 180gph pump then a single 1/2 fuel line to regulator on fire wall with (2) 06an lines to each bowl on a dominator,(1050) . I do not have it set up to return it dead heads at carb. Queastion is : is it better to have a return setup also is line size large enough for engine.
Old 08-20-2010, 09:26 PM   #30
VENGNCE
VENGNCE's Avatar
I think your cam is fine for your application. Degree it and put the intake centerline at 106*. You dont need big duration with those heads as their ports are slower than your oval ports. Going with a bigger duration cam than what you have will destroy what little low to midrange torque you have.
VENGNCE is offline   Reply With Quote
Resources saved on this page: MySQL 1.03%
