1980 Malibu: How light can u get it..... - Page 2 - Yellow Bullet Forums
Old 09-29-2011, 11:57 PM   #16
mikeyfrombc
mikeyfrombc's Avatar
Default Re: 1980 Malibu: How light can u get it.....
Quote:
Originally Posted by Drag Radial View Post
We are getting ready to take some weight out of ours, class minimum is 2900 for our combo and we are just under 3100 with 165 lb driver/full bottle/full 5 gallon cell.
It has the following:
Glass hood
Glass front bumper
Speedglass windshield
Aluminum bumper brackets
Aluminum heads
Aluminum radiator
Kirkey Seat (drivers side only)
Light weight carpet
14 pt C/M cage
8.5 10 bolt with 33 spline Moser parts
Aerospace brakes all 4 corners
A superlite set of Holeshot Revolvers
Bow-tie block
Stock radiator support ( plan on buying the Iceman radiator support)
Inner fenders
Full factory type dash
Factor front upper and lower control arms (soon to be swapped out for a set of TRZ arms)
We still have full doors with working windows and crash bars ( Fiberglass doors and lexan side windows are coming)
John what was the end result of the diet ??
Demon Precision Products
mikeyfrombc is offline   Reply With Quote
Old 09-30-2011, 12:02 AM   #17
whitemc
Spooled up
VFN FIBERGLASS HAS A LOT FOR A GBODY
whitemc is offline   Reply With Quote
Old 09-30-2011, 12:03 AM   #18
tyster89
Member
Pullin gears
tyster89's Avatar
SS Sean has his lightened up a ton.
tyster89 is offline   Reply With Quote
Old 09-30-2011, 12:05 AM   #19
whitemc
Spooled up
VFN fiberglass makes alot for gbody
Old 09-30-2011, 12:24 AM   #20
358T
Launchin
358T's Avatar
Had a 78 Malibu we backhalved using a Chassis engineering kit. 32x14 tires in back. Old centerline wheels. Fiberglass hood, bumpers, trunk lid, and doors. Lexan windows. Aluminim headed smallblock. Stock radiator. Plasitc fenderwheels. Airconditioning removed. Ford 9" rear with nodular iron case. Aluminum headed smallblock chevy backed by a powerglide. Car weighed 2905lbs with 205lb driver.
WWW.KillerRONS.COM Tech and Sales
scottoffermann@inbox.com
358T is offline   Reply With Quote
Old 09-30-2011, 12:36 AM   #21
DOTracer
DOTracer's Avatar
Quote:
Originally Posted by dirtysouth View Post
Who sells fiberglass doors for this car?
Glasstek and they fit NICE. If anything, they fit nicer than the stock ones I took off.
Swapping from stock doors (crash bars removed prior) to Glasstek doors, custom hinges, lexan window, etc saved 132 lbs total.
DOTracer is offline   Reply With Quote
Old 09-30-2011, 12:41 AM   #22
dirtysouth
dirtysouth's Avatar
Thanks y'all.
dirtysouth is offline   Reply With Quote
Old 09-30-2011, 12:46 AM   #23
dirtysouth
dirtysouth's Avatar
How do the lexan windows work with no posts?
Old 09-30-2011, 07:49 AM   #24
DOTracer
DOTracer's Avatar
Chromoly tube support frame.
Old 09-30-2011, 08:12 AM   #25
jlo
jlo's Avatar
Quote:
Did you buy those hinges or are they custom made...very nice!
jlo is offline   Reply With Quote
Old 09-30-2011, 08:16 AM   #26
DOTracer
DOTracer's Avatar
made from scratch.
Old 09-30-2011, 08:23 AM   #27
Drag Radial
SOFA KING WHAT?
Drag Radial's Avatar
Quote:
Nothing yet, put it into the wall back in July and it's just sitting...............I don't even want to look at it.
Quote:
Originally Posted by Monte Smith View Post
You CAN'T make rules based on what guys HAVE..........you have to make rules based on the POTENTIAL on any given combo. FAIR is next to impossible..............plus FAIR is a place where they have rides and pigs are judged, has nothing to do with racing..............LOL!!!
Monte Smith
Drag Radial is offline   Reply With Quote
Old 09-30-2011, 08:52 AM   #28
tyster89
Member
Pullin gears
tyster89's Avatar
OUCH!
Old 09-30-2011, 09:04 AM   #29
79malibu
LSx The World
79malibu's Avatar
http://www.maliburacing.com/forum/vi...hp?f=5&t=40043
Quote:
I've always had weight loss ideas for the Malibu in my mind and now thought it was time to compile a list. Feel free to add ideas you may have as well.
Keep in mind that not all these items are appropriate for all applications. Each of us must decide what is worth doing, and what are a bit too far "out there" for what we are trying to accomplish.
i can say this, if I had to build my car again from scratch, I'd surely take weight more seriously. When i originally built the car many years ago, I never really gave component weight much thought. As the years pass and i make parts changes here and there, I'm looking at weight much closer as ounces add up to pounds in the end.
enjoy
Todd
- remove undercoating
- remove any sound deadening material
- remove air conditioning
- remove heater box
- remove air ducts under dash
- remove heater or A/C controls
- remove radio & speakers
- remove rear seat
- remove crash bars in doors
- remove wiper motor, linkage, and arms
- remove spare tire & jack
- remove passenger side mirror
- remove front & rear sway bars
- remove emergency brake components
- swap power steering for manual steering
- swap manual steering for rack & pinion conversion
- swap power brakes for manual brakes
- swap tilt steering column for standard
- swap standard steering column for lightweight chromoly tube
- plastic headlights
- light weight race disc brakes front & rear
- light weight aluminum or plastic race seats
- aluminum rear firewall instead of steel
- use minimum gauges to monitor critical functions only
- remove unneeded wiring circuits & wire from dash & car
- aluminum intake manifold
- aluminum heads
- aluminum block???
- aluminum radiator
- aluminum water pump
- aluminum radiator core support
- chromoly tube radiator core support
- chromoly tubular A-arms
- chromoly tubular transmission crossmember
- fiberglass front & rear bumpers, eliminate factory bumper shocks, fab LW mounts
- fiberglass hood liftoff lighter than hinged
- fiberglass doors
- fiberglass trunk lid
- fiberglass dash
- lexan windows
- chromoly roll bar/cage instead of heavier/thicker wall mild steel
- 8.5 10 bolt or 12 bolt rear is lighter than most Ford 9" rears
- if using Ford 9", use aluminum center section and/or chromoly fabricated housing
- aluminum or carbon fiber driveshaft
- gun drilled/profiled flange axles
- lightened spool
- titanium drive studs
- shorter rear with shallow back space wheels are lighter than longer rear and deep backspace wheel combination
- light weight aluminum wheels...compare brands & weight. Many of the new design drag wheels are lighter than the older draglites, drag stars, centerlines, etc.
- light weight drag tires, both front & rear...again compare brands, Hoosier D/R lighter than M/T D/R.
- if using bias ply slicks, remove inner tubes
- keep bolts as short as possible, eliminate washers when you can
- use 1 battery instead of 2
- consider using 16 volt battery and remove alternator...charge between rounds
- new dry cell batteries are smaller & lighter than older wet cell designs
- car audio acoustical carpet lighter than rubber backed factory carpet
- powerglide is lighter than th350 or th400
- if needing 3 speed, maybe consider lightened version like the Kilgore, Coan or Rossler versions
- aluminum or titanium body/sheetmetal fasteners
- use newer breed nylon covered braided hose instead of stainless steel braided hose
- keep exhaust as short as possible, compare muffler weights from different manufacturers
- factory block is lighter than aftermarket
- aluminum rods lighter than steel
- smaller radiator lighter and holds less water, less weight
- acid dipping non critical/structural componenets
79'malibu 383 w/nitrous street/strip car
80' malibu 305 TPI -SOLD
00' Excursion 6.8
79malibu is offline   Reply With Quote
Old 09-30-2011, 07:25 PM   #30
TurboTA87
TurboTA87's Avatar
Glass hood
Glass front bumper
Aluminum heads
Aluminum radiator
Light weight carpet
14 pt C/M cage
Bow-tie block
Inner fenders
What no 25.5 John ?? Just messin with you.
" Overkill is an often underrated achievement "
Originally Posted by 2fst4umalibu
x2 watching nascar is like pouring a bag of skittles in the toilet an flushing it!!!!!
TurboTA87 is offline   Reply With Quote
