700r4 no reverse - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 06-07-2010, 12:33 AM   #1
CrispySqrl
Pre-Staged
Default 700r4 no reverse
I bought a 87' Blazer K5 lifted for playing in the mud. It had no reverse but the story I was told I figured it would be easy to fix. Well now I am not sure.
First off i took the valve body out and the shift kit he gave me the box for was only partially installed so i finished the install and found the pressure regulator area was done wrong and modified some the reverse boost valve was in upside down and there was a part ground off.
The truck doesn't ride any kind of good so test at speed is hard. But as far as I can tell all shifts are good and all gears are fine. Aside from reverse is not there and neutral won't let the car roll with the engine running. Almost as if forward is everywhere even over by park it will go forward sometimes. I was thinking of just going thru it but it scares me there is something else wrong with like part miss-match or not assembled properly.
I know the case is a 1988 which he told me the old case broke mounting ears off. I have a receipt from the trans shop that moved it all over. The other thing i notice is that the B&M instruction tell me that this valve body was and 1984 or older since it doesn't have the larger check ball over by the TV cable.
Any help would be nice. I really want to make sure that a rebuild and maybe replacing a few hard parts is all i need.
Thanks in advance,
Darrell
Darrell
LQ9 408, ETP 245cc, Twin T-66, BS3, TH400, 9", stock suspension, ams-1000.
1.32 60' 5.67@124 1/8 & 8.84@154 1/4 http://www.youtube.com/watch?v=rRVOxiaJpD0
CrispySqrl is offline   Reply With Quote
Old 06-07-2010, 04:44 PM   #2
Jp outlaw
peanut hunter!!!
Default Re: 700r4 no reverse
Most shops throw the large TV check ball out during a rebuild/etc. The neutral and park problem would have me a little worried, first things first you need to verify shifter movement/adjustment.
Jp Shawgo - Close E'nuff Racing
www.sandeperformance.com
www.shraonline.com/
www.outlawtenfiveracing.com
www.transmission-specialties.com
25.4 '85 notchback for sale; roller or turn-key
Jp outlaw is offline   Reply With Quote
Old 06-07-2010, 05:12 PM   #3
CrispySqrl
Pre-Staged
With the trans apart the column shifter was right on mark but after i got it all back together it is like if i don't go from 1st to park it doesn't go into park. And like i said all six possitions including reverse (acts like nothing) and neutral (is first gear pretty sure) will not allow the truck to roll backwards while truck is running shut it off and she rolls backwards down hill.
Darrell
Old 06-07-2010, 06:36 PM   #4
redvictor
from across the pond...
redvictor's Avatar
Garage
sounds like the fwd clutch pack is welded together...
Gone from this place...
redvictor is offline   Reply With Quote
Old 06-07-2010, 07:46 PM   #5
CrispySqrl
Pre-Staged
I kinda figured it was the direct or forward clutch pack probably beat the hell out of the drum too. Now that is stuff I can take care of
Darrell
Old 06-08-2010, 11:25 AM   #6
Jp outlaw
peanut hunter!!!
fwd clutch is a definite/likely possibility, they don't tend to damage the drum in a 4L60. - May have hurt it due to low line pressure with the incorrectly installed boost valve.
www.shraonline.com/
Old 06-08-2010, 08:11 PM   #7
CrispySqrl
Pre-Staged
Well rebuild sounds like the way to go. But now I may even go stick shift lol SM465 and a better transfer case
Darrell
Old 06-22-2010, 07:37 PM   #8
CrispySqrl
Pre-Staged
just an update haven't had time to work on it but I went to move it to the driveway to work on it and now it has no forward but reverse is back so it was welded forward drum clutches so should just need a rebuild at this point. Thanks again all.
Darrell
Old 07-23-2010, 05:14 PM   #9
1SLOW64
1SLOW64's Avatar
I just had this problem with my 88K5. After beating the piss out of it at the local mudhole the trans is acting funny.
With the engine running it drags in reverse like the brake is on. With engine off it will roll no problem.
1SLOW64 is offline   Reply With Quote
Resources saved on this page: MySQL 2.27%
