6.0 max bore and stroke - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > LSX, Mod Motor and Gen III Hemi Tech
Old 06-03-2010, 10:28 PM   #1
snowball
Member
Pullin gears
snowball's Avatar
Default 6.0 max bore and stroke
i was looking at building a 6.0 for drag racing was goint to switch to carb setup
what is the max bore& stroke that block will handle???
snowball is offline   Reply With Quote
Old 06-03-2010, 10:31 PM   #2
Collinsautomotive
Default Re: 6.0 max bore and stroke
NA racing I assume. Practically the largest easy to balance strokes 4.125-4.250 but I doubt you'll get anything over a 4.125 in a stock block without a bunch of work. As for the overbore sonic checking will reveal the total overbore capability. I have heard of guys going as big as 4.100 but I doubt this is a commonly found block thickness.
I haven't run anything over a 4.00 stroke becuase I don;t like the way the piston pins gets.
Henry Ford, on the stock market
Quote:
"As betting at the race ring adds neither strength nor speed to the horse, so the exchange of shares in the stock market adds no capital to business, no increase in the production and no purchasing power to the market."
Old 06-03-2010, 10:34 PM   #3
snowball
Member
Pullin gears
snowball's Avatar
what do you think max hp potential would be on with alky carb and mildly worked over heads l92 heads
Old 06-03-2010, 11:29 PM   #4
Collinsautomotive
Quote:
with alky you'll need a bigger port on average. 700ish or more with the right builder at 400ci without to much effort.
Old 06-04-2010, 03:35 AM   #5
SP4167
Spooled up
SP4167's Avatar
We've got a 6.0L block out here that we plan on getting sonic tested. Hoping to see if we can get a 4.125 or so bore out of it, but we'll see. 4.125 crank and 4.000 stroke could make a 427 and would be a cheaper way to do it.
1968 Camaro with a SBC
SP4167 is offline   Reply With Quote
Old 06-04-2010, 05:55 AM   #6
black93z
Launchin
black93z's Avatar
We bored mine to 4.125 and 3/4 filled the block, no problems. And 4.100 stroke.
Mike Lough Racing Engines
black93z is offline   Reply With Quote
Old 06-04-2010, 06:39 AM   #7
SStrokerAce
SStrokerAce's Avatar
You can make a 427 out of that.... 4.075" bore x 4.125" stroke, but if I was building a drag race motor depending on the quality of the head porting and RPM range I would go 4.075" x 4.00" for something in the 8Krpm range or smaller for more RPM. You could get 900+hp out of a Iron 6.0L block and L92 castings if you knew what you were doing... actually I honestly think right at a grand is doable with a small motor and once I get a few of my pet projects done this will be a project of mine.
Bret
Prof Gordon Blair “Those engine developers who grossly exaggerate their engine’s power as evidence of their genius!” ARE IDIOTS
SStrokerAce is offline   Reply With Quote
Old 06-04-2010, 10:56 AM   #8
Pro Stock John
Pro Stock John's Avatar
wow 4.125 with a 6.0 block, I didn't know you could do that. I thought I was adventurous with a 4.060 bore iron block back in 2001.
LSX RECORD LIST
RaceStar, Billet Specialties Dealer
Pro Stock John is offline   Reply With Quote
Old 06-04-2010, 11:01 AM   #9
Collinsautomotive
Quote:
depends on casting shift etc.
Old 06-04-2010, 11:08 AM   #10
snowball
Member
Pullin gears
snowball's Avatar
do all of the cast iron 6.0 have same wall thinkness?
is there some years that are thinner or thicker?
Old 06-04-2010, 11:10 AM   #11
Mike Moore
Member
Pullin gears
Mike Moore's Avatar
While some of the smarter LS guys are in here, how big can you typically go on an aluminum 6.0 block? I've always heard it wasn't much but have never had one to find out.
Mike Moore is offline   Reply With Quote
Old 06-04-2010, 11:13 AM   #12
snowball
Member
Pullin gears
snowball's Avatar
this is impressive!!
who would you suggest to do a build like this?
Quote:
Bret
Old 06-04-2010, 11:25 AM   #13
Collinsautomotive
Quote:
sleeves are thin. I would not go over 4.020 IMHO even that might be to much. I limit my factory sleeve overbores to 10 thousandths and thats it.
Old 06-04-2010, 01:12 PM   #14
Mike Moore
Member
Pullin gears
Mike Moore's Avatar
Quote:
Thanks Shawn, that's what I heard but I wanted to hear it from a reliable source.
Old 06-04-2010, 01:38 PM   #15
Collinsautomotive
Not a problem dude. Those are safe maximums I know work.
