Mechanical Fuel Pumps ( How much is TOO Much?) - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 05-09-2010, 09:31 PM   #1
Louie
Spooled up
Louie's Avatar
Default Mechanical Fuel Pumps ( How much is TOO Much?)
Bulding a 400" SBF/ Yates / PT 106mm / EFI combo.
Not sure on fuel yet as the Leaded Ban is still in effect here in Canada.
I have been looking at using an Enderle Mechanical Pump (Belt Driven ). Reason being if I cannot use C16 why buy a pump now ( Areomotive ) and then have to buy another to handle methenol.
I am considering the Enderle 1200 FUEL PUMP 18.8gpm pump
Just because I can make the switch later if I have too.
Is this Too much pump? Can it be regulated by the pulley sizes I use?
400"SBF
CHAPMAN YATES C3-H CYLINDER HEADS
SCAT BILLET CRANK
GRP PRO ALUMINUM RODS
JE PISTONS
PRECISION TURBO 106mm
Louie is offline   Reply With Quote
Old 05-10-2010, 09:18 AM   #2
Louie
Spooled up
Louie's Avatar
Default Re: Mechanical Fuel Pumps ( How much is TOO Much?)
Anyone use mechanical Enderle pumps?
400"SBF
SCAT BILLET CRANK
JE PISTONS
Old 05-10-2010, 09:22 AM   #3
1QuickBird
1QuickBird's Avatar
Since you are going EFI I assume you will have a regulator inline... So I don't think you can have TOO much pump, I don't think you can regulate volume my pulley size, however pressure and how quick you get pressure.
WWW.LEGENDRACINGENT.COM
https://www.facebook.com/LREhorsepower
Midwest Muscle Car Specialists
High Performance engine builders
Induction Solutions Midwest dealer
1QuickBird is offline   Reply With Quote
Old 05-10-2010, 09:41 AM   #4
Kevin Zaske
Eddie Haskell
Kevin Zaske's Avatar
pump loop
Kevin Zaske is offline   Reply With Quote
Old 05-10-2010, 09:59 AM   #5
Jim Wiens
Jim Wiens's Avatar
If your running methanol that would be the smallest pump i would run if you can swing it get a waterman pump they are a lot better and you can change the the gears to get what ever flow you need i have a 19.8 on a 400 ci sbc
Jim Wiens is offline   Reply With Quote
Old 05-10-2010, 05:38 PM   #6
Louie
Spooled up
Louie's Avatar
Thanks Gentlemen!
Louie
400"SBF
SCAT BILLET CRANK
JE PISTONS
Old 05-10-2010, 06:16 PM   #7
Lugnuts
Burnout box
With EFI you want to be able to bypass nearly all of the fuel that the pump can produce. The reason for this is the EFI has the ability to turn the injectors completely off, whereas mechanical injection nozzles do not shut off.
What you have to watch out for with a large mechanical pump and EFI is the deceleration fuel cut.
This is noticed when you let off of the throttle after a pass, the engine is at high RPM and the injectors close (standard EFI tuning - for engine braking/clean plugs).
If your regulator set-up cannot bypass all of the pumps fuel, you can get an extreme pressure spike causing the injector o-rings to be blown out and a possible fire.
You can either:
Ensure the regulator or regulators can bypass enough fuel,
And/Or
Run a high speed bypass set at ~20 psi higher pressure than you will ever run (remember to factor base pressure + boost pressure).
You can test for this by revving the engine off of idle, while watching your fuel pressure gauge or sensor. If the pressure does not immediately return to base pressure, you need to bypass more fuel.
Lugtronic.com
LugnutsTuning.com
EFI Installation, Calibration, Race Tuning
Lugnuts is offline   Reply With Quote
Resources saved on this page: MySQL 2.17%
