436 small block chevy with 14.5.1 compression - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Nitrous - Induction Solutions
Old 05-07-2010, 03:20 PM   #1
15886
Member
Pullin gears
Question 436 small block chevy with 14.5.1 compression
Has anyone had good results ...I'm building a 436 with 14.5.1 compression, afr 227cc heads cnc competition ported 2.10Int 1.60 EXH, 1220cfm carb from chuck nuytten, super victor intake, I'm gonna be spraying a single stage big shot plate... I was wondering what times you think i will get naturally aspirated? Cam is:
Solid roller
@.050 Int:278/ Exh. 292
Gross Valve lift:Int:652/Exh.667
Intake center Line:112.0
Lobe separation:112.0
1.5 jesel rockers on Int. and Exh.
Have a nitrous converter 4000 stall PTC
Powerglide trans with 1.74 ratio
My goal is to run on a ONE STAGE BIG SHOT PLATE Times I'm looking to to run is 5.40s
yOU think I might need a better cam or is it fine for what i have..
also the heads?
The other cam I want to try is:
Howards Cams:.
DURATION@.50 INT.282/EXH.296 ...GROSS VALVE LIFT INT.728/ EXH.712 LOBE CENTER @114 with 1.5 rockers
15886 is offline   Reply With Quote
Old 05-07-2010, 05:37 PM   #2
15886
Member
Pullin gears
Question Re: 436 small block chevy with 14.5.1 compression
And why do i hear its better going to a short stroke 3.750 or 3.875 like a 406 or 421 instead of a 434 4inch stroke when spraying nitrous
Old 05-07-2010, 06:33 PM   #3
smallblockcamaro
smallblockcamaro's Avatar
Default Re: 436 small block chevy with 14.5.1 compression
the compression height of pistons can be a concern with 4" strokes. as far as your combo goes, it's more setup towards nitrous so it's not going to run as hard n/a. i would guess mid 10's, high 6's in the eighth. if it were me i would have a larger head than the 227's for sure and feel it would like a bigger intake rocker as well (1.6 or 1.7)
67' Camaro
421 SB2.2
-Dislikes shops who charge you for work that either they did not do or did not do correctly and on top of it all- fail to make it right.
smallblockcamaro is offline   Reply With Quote
Old 05-07-2010, 06:34 PM   #4
smallblockcamaro
also, with a 4" stroke the cam has to be done on an even smaller base, that's if its a standard cam location.
67' Camaro
421 SB2.2
Old 05-08-2010, 12:46 AM   #5
15886
Member
Pullin gears
What about the 235cc heads from afr or thier new 245cc coming out
Old 05-08-2010, 01:06 AM   #6
z289sec
z289sec's Avatar
Put as much head as you can get on it. My little 415's heads started out as 235 cc before they even went to get worked on. 5.40's should be easily attainable. There are guys doing that here at 3200 lbs on a 275 with an .082 pill restriction in good weather.
Personally I'd like to see a bigger cam in it. I think the Howards is a better choice. I ran one just like that in mine part of last year and it worked well. I just needed a little more. I am at 14.5 to 1 also. As far as what it will run N/A, if it's a dedicated nitrous motor with a dedicated nitrous converter. Don't expect a lot, a lot of the 5.4xx-5.5xx small blocks like that barely even make it into the 6's N/A.
RTCTTFMF!!!!
Stock suspension 67 Camaro
565 Conventional head BBC with fogger and a plate on 275's
Just about done
Thanks to:
Texas Racewerks, Sanger, Texas
Nyes Automotive Racing Engines, Muncie, Indiana
FTI Converters and Transmissions, Deland, Florida
ACE Racing Transmissions, Garland ,Texas
z289sec is offline   Reply With Quote
Old 05-08-2010, 11:57 AM   #7
smallblockcamaro
Quote:
the 245's would definitely be more ideal for what you're doing.
67' Camaro
421 SB2.2
Old 05-08-2010, 01:48 PM   #8
mikeyfrombc
mikeyfrombc's Avatar
what does the combo weigh ? my buddy has a 436 and he weighs 3100ish and its just up and running he has been a best of 9.67 at 138ish on pumpgas with alot less compression and cam , this is a N/A motor combo that is pretty fine tuned
Demon Precision Products
mikeyfrombc is offline   Reply With Quote
Old 05-08-2010, 02:25 PM   #9
gforce nos
Launchin
gforce nos's Avatar
I agree with smallblockcamaro ,I have a simular combo with the changes he is talking about N/A it runs 10.40@ 140 mph. Leaves like a dog N/A tight converter, 3.89 gears, 114 lobe separation. The MPH tells me that the 3220 lbs car is making good HP.I used the biggest head with the biggest valve I could afford with good exhaust side as well.The more air / nos you can get in the engine the more power you can make! With all of that being said your nos tune will be the most important due to your comp. height on your pistons and the comp. ratio you are running. Have your system flowed if you plan on using more than 250 hp tune usuing a single stage setup.
gforce nos is offline   Reply With Quote
Old 05-11-2010, 05:03 PM   #10
Speedracer_SS01
Member
Pullin gears
where can you get more info on the 245 cc afr's
Speedracer_SS01 is offline   Reply With Quote
Old 05-11-2010, 08:59 PM   #11
smallblockcamaro
Quote:
you can find out more info from tony mamo. i heard they're supposed to move mid 350 cfm. not too shabby.
67' Camaro
421 SB2.2
Old 05-12-2010, 12:39 PM   #12
Speedracer_SS01
Member
Pullin gears
DO YOU KNOW WHAT HIS SCREENNAME IS
Old 05-12-2010, 08:51 PM   #13
smallblockcamaro
Tony Mamo @ AFR
67' Camaro
421 SB2.2
Resources saved on this page: MySQL 2.15%
