What pump to use with e85 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Racing Fuels
Old 04-29-2010, 06:38 PM   #1
92biminiLX
Burnout box
92biminiLX's Avatar
Default What pump to use with e85
Is anyone running aeromotive's eliminator pump with e85? I just opened my up the other day and some of the literature that came with the pump said it wasn't to be used with alcohol based fuel. Just curious if anyone did it anyway or what pump are you using?
92biminiLX is offline   Reply With Quote
Old 04-29-2010, 07:38 PM   #2
chris406
Launchin
chris406's Avatar
Default Re: What pump to use with e85
carb or efi?
On my carbed turbo car I have a MagnaFuel 500. Does the job for me. Car is 3500lb going mid 9's @150ish.
chris406 is offline   Reply With Quote
Old 04-29-2010, 09:26 PM   #3
92biminiLX
Burnout box
92biminiLX's Avatar
carb. It's a 393w with a turbo. I'm looking to go low 9's.
Old 04-29-2010, 09:44 PM   #4
Mattsv8_03
Member
Pullin gears
Mattsv8_03's Avatar
twin a1000. pro series or belt drive. dont know enough about the magnafuel pumps.
ive decided to run twin a1000s.
My 82 s10 lb 8.89 at 152.78 on pump E85. 15lbs boost 357"sbc 8.4:1
89 s10 blazer 9.90 nitrous 335" sbc 12.4:1 e85 homemade 750 225 shot
2001 z28 camaro hooker lt ofy flowmaster slp lid bellows. Awaiting the turbo kit I built for it that keeps ac and stock rad location.
2001 tahoe bone stock
1997 gmc yukon 2.5" lift 285/75 tires trailer puller.
Mattsv8_03 is offline   Reply With Quote
Old 04-29-2010, 11:47 PM   #5
classic boost
classic boost's Avatar
i ran a a1000 with e85 for a couple of years. no problems.
68 stang
351W PT-88 E-98
9.61@145
classic boost is online now   Reply With Quote
Old 05-08-2010, 07:41 AM   #6
92biminiLX
Burnout box
92biminiLX's Avatar
Well, I called aeromotive and they said there have been 3 updates to the eliminator pump. The current one flows 40% more than the original and is ok to use with E85. I just thought I'd post this info for anyone reading the thread.
Old 05-09-2010, 10:49 PM   #7
IROC-Z
Spooled up
Weldon makes nice stuff.
IROC-Z is offline   Reply With Quote
Old 05-18-2010, 04:18 PM   #8
8liter
Member
Pullin gears
8liter's Avatar
A1000 for me....
8liter is offline   Reply With Quote
Old 05-21-2010, 11:31 PM   #9
koolrayz
Moderator
koolrayz's Avatar
Quote:
Love my weldon pump
X275 ERL motor, Midwest Chassis Suspension, Garrett 88mm turbo, AEICNC, Shearer fabrications, Driveshaft shop, All Pro heads, RPM transmission, PTP performance, Big Stuff 3
Like WWW.facebook.com/koolrayzracing
koolrayz is offline   Reply With Quote
Old 05-28-2010, 09:52 AM   #10
Mattsv8_03
Member
Pullin gears
Mattsv8_03's Avatar
i need more pump im currently a single a 1000
i could add a second but i need a bigger pump today and tomorow and no time to replumb fuel lines
Magnafuel prostar 500
eleminator pump
would be options
i could run a eleminator pump and a1000 later as a twin pump setup.
the dude at aeromotive said the eleminator should be big enough for me. i need to get it today!
Old 05-28-2010, 02:04 PM   #11
hellbents10
hellbents10's Avatar
One Eliminator on a 6l on E85, 825 to the tires...9.9@141 4000+lbs race weight.
hellbents10 is offline   Reply With Quote
Resources saved on this page: MySQL 2.17%
