biggest size cam on a stock H.O 302 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Valvetrain - LGM Racing and Development
Old 03-26-2010, 04:42 PM   #1
Bigrigs
Pre-Staged
Bigrigs's Avatar
Default biggest size cam on a stock H.O 302
Ok so I see alot of people including me are looking to see what the biggest cam you can run on a stock 302 with valve reliefs stock heads ext. I'm not interested in hearing that there are no gains or just use 1.7 rockers and springs cuz I know that already....I just want to see whats the biggest cams (include lift and duration specs) some of you guys have ran without piston to valve clearance issues. The cam I'm interested in is either a stage 1 TFS cam or a B 303, who's got em on stock 302's with no p2v problems? Thanks
89mustang
Bigrigs is offline   Reply With Quote
Old 03-26-2010, 06:14 PM   #2
wcracer
Spooled up
Default Re: biggest size cam on a stock H.O 302
I'm interested too. Got a stage 1 cam on the shelf, running a b cam now.
wcracer is offline   Reply With Quote
Old 03-26-2010, 11:34 PM   #3
Bad Influence Racing
Bad Influence Racing's Avatar
From what I have done, in hydraulic roller form, is up to .520" lift and duration @ .050" I keep below 240*. Hope this helps.
Kris
Bad Influence Racing is offline   Reply With Quote
Old 03-27-2010, 12:17 AM   #4
Chuck u Farley M.D.
Medium Pimpin!
Chuck u Farley M.D.'s Avatar
Location: Hangin @ Sea shanties & wet panties. Baltimore
I ran a x cam in one of my old junkers. 542 lift stock pistons and heads. Ran like shit but sounded ok.
Posted Via Dialup
Chuck u Farley M.D. is offline   Reply With Quote
Old 03-27-2010, 03:11 PM   #5
Bigrigs
Pre-Staged
Bigrigs's Avatar
This is good info....keep those combo's coming!!
89mustang
Old 03-27-2010, 05:35 PM   #6
SBF
Burnout box
i ran a f cam .512 lift in my stock junk stock heads and pistions.
SBF is offline   Reply With Quote
Old 03-28-2010, 03:23 PM   #7
Bigrigs
Pre-Staged
Bigrigs's Avatar
Quote:
How did it run with the F cam on stock heads? I'm guessing you had to tune it to run efficiently?
89mustang
Old 04-01-2010, 04:56 AM   #8
ordinary builder
you are limiting yourself in camshaft design because it is so easy to just add some relief to the pistons.
valves hit the piston at between 10 degrees btdc and after tdc.
max lift has not much to do with when the valves will hit the piston.... oly factor is the comparative low lift duration.
adding extra lift or duration does not add much power unless the cylinder heads port flow is capable of flowing more air.
you never said which of the various stock heads.
ordinary builder is offline   Reply With Quote
Old 04-01-2010, 06:19 AM   #9
indyfoxgt
Burnout box
i have the e303 in mine now (.49 runs good sounds good, i know you can run the f303 (.512) but its cutting it close on stock reliefs a buddy of mine ran the f303 in a stock motor and had no problems, another guy i know had a valve whack a piston, both 87-93 mustang with ho motors, so its somwhere in that area
indyfoxgt is offline   Reply With Quote
Old 04-01-2010, 11:34 PM   #10
CATDADDY1990
Member
Pullin gears
CATDADDY1990's Avatar
i had a f cam in my street car with stock heads and pistons and worked awesome!! Great sound and good power! Never had to tune!!
]Wheelie bars are for girls!!!!!!
http://www.youtube.com/watch?v=akSHevt2XOM
CATDADDY1990 is offline   Reply With Quote
Old 04-03-2010, 03:30 AM   #11
ordinary builder
a few hours to detail the shape of the original eyebrows in each piston is all that it takes to make it fit.
it is NOT the overall lift that causes the valves to hit the pistons.
it is the actual opening and closing duration at about .100 " lift at the valve as=nd how it compares to the actual TDC point is what will tell you if it will or not clear.
you have sighted the "E" and the "F" cams,
the exhaust lobe / valve event on the closing side is what will determine how much piston to valve clearance you will have.
the intalke valve will normally clear by plenty.
once again,
WHAT HEAD IS A "STOCK " HEAD...????
every year the heads were different.
the issue is that the valve seats were all at different depths as measured from the head gasket / deck surface.
and some years the pistons came with different locations and depths of valve relief eyebrows.
Old 04-03-2010, 10:28 PM   #12
SBF
Burnout box
Quote:
the motor was a 92 ho motor with trw forged pistions ported e 7 heasds left the valves alone long tubes and 4.10 gear 150 shot ran pretty good fo what it was.
Old 04-06-2010, 12:32 AM   #13
mustang5oh
Burnout box
mustang5oh's Avatar
have a gt40p motor with trick flow stage 1 13.2 @99mph with full weight daily drive it to
mustang5oh is offline   Reply With Quote
Old 04-09-2010, 12:02 PM   #14
slow87GT
the b303 probably sounds the best, since all you want is sound
slow87GT is offline   Reply With Quote
Old 04-11-2010, 10:13 PM   #15
SS1156
Pre-Staged
SS1156's Avatar
Does anyone have a B303 for sale? I'm looking for one. Please pm me with what you have. Sorry to hijack.
SS1156 is offline   Reply With Quote
