Low Dyno.. What's Wrong? - Page 5 - Yellow Bullet Forums
Old 04-09-2010, 10:12 AM   #61
CamaroKidZ28
Member
Pullin gears
CamaroKidZ28's Avatar
Default Re: Low Dyno.. What's Wrong?
Soo track results are in.. (Street tires without much tread)
60 ... 2.102
330 ... 5.415
1/8 ... 8.089
MPH ... 92.3
1000 ... 10.390
1/4 ... 12.349
MPH ... 114.94
CamaroKidZ28 is offline   Reply With Quote
Old 04-09-2010, 10:28 AM   #62
Blown Camaro
Tire Waster
Blown Camaro's Avatar
Quote:
60 ... 2.102
330 ... 5.415
1/8 ... 8.089
MPH ... 92.3
1000 ... 10.390
1/4 ... 12.349
MPH ... 114.94
So.... 11.50's with slicks. Changed the carb and converter yet?
Blown Camaro is offline   Reply With Quote
Old 04-09-2010, 10:30 AM   #63
CamaroKidZ28
Member
Pullin gears
Quote:
Nope, same exact setup as original post. Looking for a used carb and going to list my holley for sale on here.
Old 04-09-2010, 10:57 AM   #64
bigjimzlll
bigjimzlll's Avatar
OK...so it's not making any where near 600HP. I bet you find 8-10 MPH in a carb and tuning.
With the gear/converter/weight the way it is I'd go with a 950HP for mostly street for throttle response.
bigjimzlll is offline   Reply With Quote
Old 04-09-2010, 11:36 AM   #65
CamaroKidZ28
Member
Pullin gears
Im torn between geting a 950 and 1050 from QuickFuel at the moment and whether or not I'm going to tune it myself or have a shop dyno tune it
Old 07-07-2010, 07:32 PM   #66
CamaroKidZ28
Member
Pullin gears
I ended up with a quickfuel 1050.
Had it dyno'd and tuned on the same dyno as before and lost about 10 peak horsepower and gained 5-10 through some of the midrange.
I'll have to go to the track to really compare, but this seems like an expensive waste of a mod so far.
Old 07-07-2010, 07:47 PM   #67
CamaroKidZ28
Member
Pullin gears
Here for now until I get my scanner to work somehow..
Red was today, Green and blue were when I posted the thread initially.
Old 07-07-2010, 10:38 PM   #68
CamaroKidZ28
Member
Pullin gears
I guess I'll get 2 inch or 2 1/4 next... Not sure what I should do with this setup honestly and it feels like a big money pit.
Old 07-07-2010, 10:58 PM   #69
revolutionary
revolutionary's Avatar
A quick check with the compression ratio calculator showed.... with 4.310 bore, 4.25 stroke, .005 in the hole, .040 gasket, 119cc chambers you have 8.59:1 compression. That is the main problem. Without a dome piston there is no way to get close to 10:1 on a 'small bore' BBC like that. A piston swap to a true 9.5:1 compression ratio would do wonders. Also was that cam a roller, flat tappet, hyd or what? I didn't see.
I did a pair of 496's for a boat dude and with the same Comp 242/246 hyd flat tappet cams, Edelbrock Marine rect port heads, perf rpm intakes and Holley 750's they each made ~490hp and ~ 540 ft lbs at the crank. Total turds. They had the same flat top pistons and no compression so I knew they would suck which they did. Gotta do what the man says though.
Daryl
Revolutionary Performance and Machine
revolutionary is offline   Reply With Quote
Old 07-07-2010, 11:00 PM   #70
CamaroKidZ28
Member
Pullin gears
Hyd roller
And that's exactly what I was thinking, I probably shouldn't have believed the builders on the 10-1 compression that they claim.
Old 07-07-2010, 11:02 PM   #71
revolutionary
You might check back with them to see if they did any false advertising and would be willing to swap pistons and rebalance for you...
Daryl
Old 07-07-2010, 11:22 PM   #72
CamaroKidZ28
Member
Pullin gears
I'm going to call them tomorrow, I really feel like the CR is false advertising if it's that much lower than they advertise..
Honestly, I'm trying to learn and research as much as I can but I feel like I'm throwing money into a pit and not gaining. Over $1000 in the carb and tuning, and I didn't pick up any.
Another $400-500 for headers I'm guessing, and not even sure they'll net much.
I might need a breather from this car.. lol
Old 07-07-2010, 11:33 PM   #73
Nimitz87
Spooled up
Nimitz87's Avatar
ugh man sorry to hear...
Chad
Nimitz87 is offline   Reply With Quote
Old 07-08-2010, 11:08 AM   #74
No-Nitro
Spooled up
I have a gm 572 620 version 9:6-1 in a 73 Camaro. weight is 3550 with me in it. I have 2-1/4 headers, 3500 stall, Turbo 400, 373 posi, 1050 prosystem dominator, GM intake ,Gm heads. Best time at the track so far was a 10.31 at 129 w/ a 141 60ft foot breaking. I tried the trans brake but still spinning some.
Everyone is telling you what to buy to improve your combo. I have pretty much everything on mine what they say you need. Only thing i would do a little different would be a higer stall (4200 ). Once i get this to hook on the brake i should be able to get it in the 10.20 range.
Good luck with your build!!!
No-Nitro is offline   Reply With Quote
Old 07-08-2010, 01:16 PM   #75
CamaroKidZ28
Member
Pullin gears
Where'd you get BBC 2 1/4 headers for your car? And what brand name?
Resources saved on this page: MySQL 1.00%
