Lets see all the procharged small blocks that broke the 1000 hp mark - Page 9 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Supercharged - All Out Automotive
Old 11-15-2010, 08:12 PM   #121
BCCOUPE
BCCOUPE's Avatar
Default Re: Lets see all the procharged small blocks that broke the 1000 hp mark
Quote:
Originally Posted by 302man View Post
How much do those "Fancy Nascar Pumps" cost ?
It's a magna fuel outlaw 750. Think I paid 400 for it and the drive asembly pulley's, belt and cable is from Waterman Product's I think was around 500. Should be more system than I will ever need. The pump is like 7 gpm. lol
BCCOUPE is offline   Reply With Quote
Old 11-15-2010, 08:19 PM   #122
302man
302man's Avatar
That sounds cool. So...if your at an event and you have to do a fuel sample. What do you do ? Do you use a bump button under the hood and hold open the valve ? Just wondering.
see me for TUBULAR MUSTANG BUMPERS
Parachute Bumpers for Fox Bodies
www.DonathenRacing.com
See my face book for more pictures "Tim Donathen"
87 Mustang - Drag Radial Car
ProTree Race Cars -Chassis
Simple Engine and Machine
Kurgan Motorsports - Tune
Automotion Race Cars
Mike Duke Cylinder Heads
5.27@138 so far on 275's
302man is offline   Reply With Quote
Old 11-15-2010, 08:25 PM   #123
BCCOUPE
BCCOUPE's Avatar
Guess I'd have to. I dont have a valve or anything, havent thought that far ahead. Ha ha!!
Glad u brought it up though, it will be another item on the to do list now.
Old 11-15-2010, 08:27 PM   #124
O.C White
Moderator
O.C White's Avatar
Somewhere I think Jim Summers has a big fat grin on his face looking at all those Procharger cars.
Carl
Gunnery Sergeant of Marines(RETIRED)
"No better friend, No worse enemy. Espirit de Corps
Semper Fidelis Always Faithful
Moral professionalism at its finest.
Mathew 5:9
Quote:
"BE WARY OF THE MAN WHO ENCOURAGES AN ACTION WHO HE HIMSELF INCURS NO RISK
O.C White is offline   Reply With Quote
Old 11-15-2010, 08:54 PM   #125
Vader Ta
Procharged SBC Enthusiast
Vader Ta's Avatar
Quote:
Without a doubt !!
Vader Ta is offline   Reply With Quote
Old 11-16-2010, 06:21 AM   #126
Prochamro
Prochamro's Avatar
He's come along way since '94..........
Prochamro is offline   Reply With Quote
Old 12-17-2010, 03:56 PM   #127
helicoil
Member
Pullin gears
helicoil's Avatar
Yes.
1970 2 bolt block with repair sleeve in one hole
ProGram splayed billet caps 3 center
15 year old Venoila F/Ts with .250" top lands, std. pins
GRP 6.100" LS aluminum rods machined offset for std. SBC
Moroso oilpan with scraper and windage tray
Trick Flow 4340 3.48" stroke with 2.100" rod pin - Summit crank double keyed - 14 years old std/std
Hellfire rings 1/16, 1/16, 3/16" std. tension oils
Isky roots blown alky cam 270/280 @ .050" .700"/,725" 114lsa in at 113 ICL
AFR 210 Eliminators with 8mm valves and 280# seat pressure, std. port Race Ready, Ti retainers, Comp Steel Pro Magnums, AFR girdle
ARP head studs
Ported Super Victor 4150
C&S alky carb with electric solenoids (2 Aeromotive 1000's supply)
1 7/8" tubes
28* timing 15# at 7000 RPM
QUOTE=slow8.0;5062106]Can you give any details on the cam and shortblock? Thanks[/QUOTE]
helicoil is offline   Reply With Quote
Old 12-17-2010, 07:38 PM   #128
michaeld
michaeld's Avatar
By michaelduffy at 2010-12-17
1108 on the chassis dyno,, 22 psi, 9000 rpm F-1r 412 sbf Panhandle performance
michaeld is offline   Reply With Quote
Old 12-17-2010, 07:51 PM   #129
BBF
Nice was this on Marks dyno? Why such a small line going to map sensor? How much compression?
BBF is offline   Reply With Quote
Old 12-17-2010, 07:57 PM   #130
michaeld
michaeld's Avatar
On a local dyno here in Ok,city,, map sensor line is small to dampen pulses,, remember it is a pressure signal, not flowing any volume... Isn`t a work of art,, it is for racing...
I think with the new Alan Kennedy Injectors and what we have learned about this combo it closer to 1200 now
Old 12-17-2010, 08:28 PM   #131
Vader Ta
Vader Ta's Avatar
Nice job !! Thats alot of power from an F1r !!
Old 12-17-2010, 08:41 PM   #132
michaeld
michaeld's Avatar
Quote:
Thanks, I have much faith in Mark Bittle {Panhandle Performance} as an engine builder..
Just started racing the car first of Sept.with some good success, been running 5.10-5.20 140-143 at 3250-3350 depending on the D.A.. Now that I have become accustomed to driving again I am ready to make the necessary converter and tune changes and run better next season..
Old 12-18-2010, 09:23 AM   #133
slow8.0
slow8.0's Avatar
Quote:
Originally Posted by helicoil View Post
Yes.
ARP head studs
1 7/8" tubes
[/QUOTE]
Awsome!!! Thanks
________________________________
No one is always busy....It just depends what number you are on their priority list.
slow8.0 is online now   Reply With Quote
Old 12-18-2010, 12:28 PM   #134
67AfroMaro
That guy...
67AfroMaro's Avatar
What kind of dyno? I'm running an F2 with the same cube count, heads that flow around 390 and 11 pounds more boost and could only muster 980 on a Mustang dyno at around 8000 RPM (aborted the pull).
Granted I had no ice in the cooler, lost a header primary early in the run and was a bit lazy on the tuneup... but still, you seem to be doing much better with less.
DJ Reid - www.afromaro.com
Vortech Superchargers
Chris Alston's Chassisworks
Moran Motorsports
dad's Custom Tanks
T-Flow Racing Heads
Unlimited Fiberglass
Holley Performance
Flatiron Racecars
Follow me on Facebook
Follow my build on
67AfroMaro is offline   Reply With Quote
Old 12-18-2010, 12:56 PM   #135
BOOSTED-SS-ELKY
BOOSTED-SS-ELKY's Avatar
Some Bad Ass combos in here!!
BOOSTED-SS-ELKY is offline   Reply With Quote
Resources saved on this page: MySQL 2.06%
