Lets see all the procharged small blocks that broke the 1000 hp mark - Page 10 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Supercharged - All Out Automotive
Old 12-18-2010, 01:09 PM   #136
NOS-Nelson
Procharger Power
NOS-Nelson's Avatar
Default Re: Lets see all the procharged small blocks that broke the 1000 hp mark
Quote:
Originally Posted by 67AfroMaro View Post
What kind of dyno? I'm running an F2 with the same cube count, heads that flow around 390 and 11 pounds more boost and could only muster 980 on a Mustang dyno at around 8000 RPM (aborted the pull).
Granted I had no ice in the cooler, lost a header primary early in the run and was a bit lazy on the tuneup... but still, you seem to be doing much better with less.
DJ you still got a couple hundred hp in that thing. I forgot to tell you that I did talk to a guy from Mustang Dyno and he did say their dyno's will always read lower than a DJ.
NOS-Nelson is offline   Reply With Quote
Old 12-18-2010, 01:27 PM   #137
robsquezn
Member
Pullin gears
robsquezn's Avatar
maybe its the nut behind the wheel DJ not the combo
robsquezn is offline   Reply With Quote
Old 12-18-2010, 03:20 PM   #138
Seabiscuit5.0
Member
Pullin gears
Seabiscuit5.0's Avatar
Seabiscuit5.0 is offline   Reply With Quote
Old 12-18-2010, 03:26 PM   #139
NOS-Nelson
Procharger Power
NOS-Nelson's Avatar
Old 12-18-2010, 03:26 PM   #140
NOS-Nelson
Procharger Power
NOS-Nelson's Avatar
How much power did it make?
Old 12-18-2010, 04:37 PM   #141
ProchargedNova
Spooled up
ProchargedNova's Avatar
^^^^^^^^^ Looks awesome! Very clean.
4.60 2014 X275
4.49 2015 X275
2004 and 2009 PSRA Xtreme 10.5 Points Champion
2008 and 2009 MAKO 10.5 Real Street Champion
Special Thanks to Gatlin Brothers Heat and Air, Superior Medical Transit, and Pro Tire Center
ProchargedNova is offline   Reply With Quote
Old 12-18-2010, 05:08 PM   #142
michaeld
michaeld's Avatar
Dyno Jet 248,,,I have been fortunate enough to have been around blown and turbo sbf most of my life,{been there done that} If I had no ice in my cooler probably would have blown a head gasket.
I have been following your build,, you doing ok, just have some tuning-possible cam issues.. Also have you been airing yours tires up to 20 psi on the dyno? straping it down properly? if it spins the tires on the rollers }{quite common} it kills the hp reading.
michaeld is offline   Reply With Quote
Old 12-18-2010, 09:07 PM   #143
michaeld
michaeld's Avatar
Quote:
This guy is one of my buddys, he had a F-2 combo similar to yours,, can`t remember what it did on the rollers,, maybe he will post his numbers.
Old 12-18-2010, 11:53 PM   #144
Seabiscuit5.0
Member
Pullin gears
Nelson
Thanks for blowing those up. It made 1167 to the wheels. I think it prob has a solid 1200 in it but I am having enough trouble getting it to the ground. After reading some helpful post on here and watch alot of my videos in slow mo I think I have a good starting point for next year.
Old 02-19-2011, 02:22 PM   #145
camaro71
Burnout box
camaro71's Avatar
406 chevy.Brodix heads.F2.A/A Dr Ernie camshaft.Csu 850
1206 hp@6600
Camaro Rs-67
406,F2 reverse,Csu 850,th400
El Camino -72 383 th200
Mustang Gt-05 Conv
www.hermanracing.nu
camaro71 is offline   Reply With Quote
Old 02-21-2011, 08:41 AM   #146
mtpturbo
Launchin
mtpturbo's Avatar
F-2, 406 w/ Brodix 18 degree heads
Midwest Turbo & Performance
www.mtpturbo.com / www.efisupply.com
mtpturbo is offline   Reply With Quote
Old 02-21-2011, 11:58 AM   #147
jc412
Pre-Staged
Quote:
Originally Posted by Seabiscuit5.0 View Post
Nelson
What are the details of your combo? Thanks
jc412 is offline   Reply With Quote
Old 02-21-2011, 05:20 PM   #148
ATI400EFI
Launchin
ATI400EFI's Avatar
Garage
Here is a couple of my junk. Procharger F2, A/W intercooler in nose, power steering, power brakes, Coan 400+Gearvendors overdrive, Dart 400, AFR 235, BS3. Motor and tune by Mike Roy of Middlebury, IN. Also thanks to Vader Ta for helping me find some parts to make my life easier! 938RWHP, 1000+ next dyno visit once our sack gets bigger.
ATI400EFI is offline   Reply With Quote
Old 02-21-2011, 05:43 PM   #149
inline6power
Member
Pullin gears
inline6power's Avatar
here is our f1r procharged 383. made 784hp at the wheels so should be really close to 1k at motor. made those numbers at 18psi and running a junk demon and now has a csu and is now running 26psi so its over 1k now. in our 91 chevy 4x4 sand drag truck.
adam ross, owner of below
2400hp blown 565 mid engine sand drag jeep
2000hp blown 565" sand drag 59 chevy
1200hp blown sbc sand drag jeep
1000rwhp diesel drag truck
1969 olds 442
1967 olds 442
1966 ss 572 el camino
and a few other go fast toys.
inline6power is offline   Reply With Quote
Old 02-23-2011, 01:01 PM   #150
Vader Ta
Procharged SBC Enthusiast
Vader Ta's Avatar
Quote:
Looks great ATI400EFI !!Hopefully this snow melts soon and you can get some enjoyment out of the car this season.
Vader Ta is offline   Reply With Quote
Resources saved on this page: MySQL 1.02%
