TH350, removing,stator support selective,s replace with needle bearing - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 02-22-2010, 09:58 PM   #1
four-ever
Spooled up
four-ever's Avatar
Default TH350, removing,stator support selective,s replace with needle bearing
question , for the more knowledgable than me ,
Im rebuilding a TH350 reverse shift trans brake trans for a friend
he broke 2nd last year at our local drags, just getting around to fixing it now, tore it apart today and found what i figured
split the intermediate race and blew up the rollar clutch-
going to order a
High Performance Drum with Sprag,36 element kit for it,
thats a given ,
heres the question , who ever did the trans before , removed the stator support selective washer and shim and replaced with a needle bearing assembly,
Is there a particular one to use as i have to replace it ,(it was damaged in the failure)
Thanks for the help
four-ever is offline   Reply With Quote
Old 02-22-2010, 10:47 PM   #2
Crosley
Member
Pullin gears
Exclamation Re: TH350, removing,stator support selective,s replace with needle bearing
the t-350 trans also came from GM with a torrington bearing on the back side of the stator . Replacement should be easy to find unless something real custom was done
A trans parts supplier NATPRO number is 44211
Check your end play
If you find yourself in a ditch... let up on the throttle and down shift
Crosley is offline   Reply With Quote
Old 02-23-2010, 12:14 AM   #3
four-ever
Spooled up
four-ever's Avatar
Default Re: TH350, removing,stator support selective,s replace with needle bearing
thanks for the reply
do you know approx what year came with it from factory ?
doesnt appear any fancy machining has been done to this trans,
Old 02-23-2010, 12:16 AM   #4
Hutch
Moderator
Hutch's Avatar
1979 and UP TH350's including lockups had a torrington bearing between the direct drum and the stator support.
Hutch
www.hutchtrans.com
519-453-4318
Hutch is offline   Reply With Quote
Old 02-23-2010, 12:53 AM   #5
four-ever
Spooled up
four-ever's Avatar
thanks Hutch
i can source that from work then by application ,
Old 02-23-2010, 04:11 AM   #6
Gregaust
Member
Pullin gears
I believe it is 76 up. The sonnax number is GM-N-14H or Delco 9436851
Gregaust is offline   Reply With Quote
Old 02-23-2010, 09:11 PM   #7
four-ever
Spooled up
four-ever's Avatar
ran into a snag today , phoned my trans supplier out here on the west coast , they are out of stock on the hd element drum assemblies for the TH350 , and are not sure when they will be getting them
if one of the candian suppliers (dont want border hassel) on here would be so kind as to PM me a price and avalibility on , it would be appreciated, then i can tell my bud what hes infor for $$ to fix
Old 02-23-2010, 09:46 PM   #8
Hutch
Moderator
Hutch's Avatar
How much power? Do you need one?
Hutch
www.hutchtrans.com
519-453-4318
Old 02-23-2010, 09:54 PM   #9
four-ever
Spooled up
four-ever's Avatar
no there isnt enough power to actually "need one"
but with the drum and roller clutch and race grenaded
might as well put the good stuff in now and not have to really worry about it
from what i can see alot of other things have been done to this trans already , was suprised not to find atleast the hardened external race in it
got your PM , thanks Hutch , will wait for you to check tom ,
Old 02-23-2010, 10:50 PM   #10
Hutch
Moderator
Hutch's Avatar
Put an HD race on a roller drum and call it a day.
Hutch
www.hutchtrans.com
519-453-4318
Resources saved on this page: MySQL 1.06%
