55mm cam journal sizes - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Valvetrain
Old 02-18-2010, 12:05 PM   #1
chaz6966
Spooled up
Default 55mm cam journal sizes
anyone know the diameter of the front or rear cam journal on a 55mm cam. i supposedly got a 55mm cam with my head package,and bought 55mm cam bearings on ebay, but the rollerbearing inside diameter is 1/8 (eyeball) bigger than my cam.
cam mikes 1.874 .
chaz6966 is offline   Reply With Quote
Old 02-19-2010, 04:13 PM   #2
ordinary builder
Default Re: 55mm cam journal sizes
what engine...???
just how accurate is that 1.874" measurement. ???
a common small chevy cam core is 1.868
a common big chevy cam core is 1.948
ford smallblock is 2.020 to 2.080 thus are all different on the same
55 millimeter is ...2.165 or so.
ordinary builder is offline   Reply With Quote
Old 02-19-2010, 05:33 PM   #3
chaz6966
Spooled up
dial verniers.
my brodix block has 2.249 front cam bore. spec sheet. according to the literature its for roller bearings.
would this be for a 55 mm bearing.
i would guess then the cam is standard chevy.
Old 02-20-2010, 01:08 AM   #4
ordinary builder
you aint measuring something accurately.
the resultant diamter of the housing bore in block depends on who makes the bearing.
some blocks have specific "retaining methods" to hold / position the roller bearing.
some use screws and some employ a pair of tru-arc type internal lockrings.
some have a oil feed hole, others do not.
you CANNOT install the needle/roller bearings with the common "hit with a hammer" type installers that are for a babbitt type full round insert...
there is no such thing as a "standard chevy" camshaft diameter that is also 55 mm diameter.
standard chevy is the size I posted in previous reply.. a 55 millimeter is DIFFERENT.
Old 02-20-2010, 01:10 AM   #5
ordinary builder
the stated 1.874" does not match to nuthin.
you aint measuring correctly.!!!!!
Old 02-22-2010, 10:58 AM   #6
chaz6966
Spooled up
ok, back at work. checked my 1-2 mikes with standard. miked cam journals.
cam mikes 1.8746.
has anyone seen this size cam before. i see it doesnt match any stock sizes. this cam was supposedly used in a circle track engine.
and the block has snap ring grooves on each side of the cam bearing, to hold them in place.
Old 02-22-2010, 04:09 PM   #7
chaz6966
Spooled up
after doing some research, ive found out that a 1.8745 cam journal size is for roller cam bearings. i didnt realize they made different size cams for roller bearings but i guess they do.
with the 2.2495 cam tunnel bore i either have to use the roller cam bearings or use ford babbit bearings with a 2.125 cam core.
i was hoping to get rid of the roller bearings and use babbit. some people say rollers cost you slight hp loss.
Old 02-23-2010, 04:36 AM   #8
ordinary builder
I answered with all the specks of each poss way to do it, but the website cut it to pieces and I anit going to do it again.
you have to buy the right cam to fit the block...
Resources saved on this page: MySQL 2.15%
