GM techs help 5.3 4.8 engine swap - Yellow Bullet Forums
Old 02-18-2010, 08:45 AM   #1
GT 350
Grizzly
Default GM techs help 5.3 4.8 engine swap
can a 5.3 fit with out any probs where a 4.8 was in a 2000 1500 pick up..got a cust...who has a blown engine and the only local thing i can find is 5.3 ..thanks for any help or if anybody done this..just wondering if the intakes will interchange and such
GT 350 is offline   Reply With Quote
Old 02-18-2010, 08:47 AM   #2
tommygun
tommygun's Avatar
Default Re: GM techs help 5.3 4.8 engine swap
all interchangeable
get a Z06 cam for the 5.3 before installing it
we have done some 4.8 to 5.3. 5.7, 6.0 swaps
tommygun is offline   Reply With Quote
Old 02-18-2010, 08:58 AM   #3
GT 350
Grizzly
Quote:
Originally Posted by tommygun View Post
all interchangeable
will it have to be reprogramed just on the swap only this old guy dont need a cam lol
Old 02-18-2010, 09:02 AM   #4
twobad
Member
Pullin gears
twobad's Avatar
swap it drive it reprogram later if needed!
twobad is offline   Reply With Quote
Old 02-18-2010, 09:03 AM   #5
GT 350
Grizzly
Quote:
I dont have the soft ware to reprogram ..if thats the case i will look for a 4.8
Old 02-18-2010, 09:06 AM   #6
twobad
Member
Pullin gears
twobad's Avatar
"if needed" it may not need it .fuel curve should be close
Old 02-18-2010, 09:09 AM   #7
Big Geek
Big Geek's Avatar
Quote:
It will, the fuel and timing tables are slightly different due to the larger exhaust duration of the ZO6 cam. You would also have to address the Rev. Limit to take advantage of the camshaft and you need to swap valve springs. Done a few ZO6 cam swaps.
9.52@152 (Time for a progressive.) on a 26x8.5-14 for all you haters.
A gentleman may do most anything so long as he does so with style.
Big Geek is offline   Reply With Quote
Old 02-18-2010, 09:11 AM   #8
GT 350
Grizzly
Quote:
Originally Posted by Big Geek View Post
It will, the fuel and timing tables are slightly different due to the larger exhaust duration of the ZO6 cam. You would also need to swap valve springs. Done a few ZO6 cam swaps.
I am not swaping cams .... just motors pleaase read
Old 02-18-2010, 09:13 AM   #9
GT 350
Grizzly
Old 02-18-2010, 09:15 AM   #10
Big Geek
Big Geek's Avatar
I did read it and thats what I took away from it. Sorry, just disregard.
Old 02-18-2010, 09:42 AM   #11
dynotune
Spooled up
motor swap will run fine, been there done that. Programming will optimize it a little, but it will work. It will drop right in and plug right in. Blocks are stamped 4.8/5.3. Poke it .120 and put 5.7 guts in it! Idle will need relearn after swap and crank learn, but otherwise no biggie (because of MAF)
DynoTune Speed & Performance
dynotune is offline   Reply With Quote
Old 02-18-2010, 01:58 PM   #12
GT 350
Grizzly
Thanks for your post guys
Resources saved on this page: MySQL 1.02%
