Piston Notching - Yellow Bullet Forums
Old 02-07-2010, 10:37 AM   #1
WeDgiE
WeDgiE's Avatar
Default Piston Notching
Want to gain more clearance with a higher lift ratio rocker!
I know Isky sells / rents the tool and your supposed to go one size up on the notching tool... any advice or tips or other methods is appreciated... need to remove about .060 and about how many cc's will that add.... thx
WeDgiE is offline   Reply With Quote
Old 02-07-2010, 05:34 PM   #2
nhraformula00
Default Re: Piston Notching
Do a search for Lindy tool.Works like the isky tool,Guy in N.illinois makes them.My son just used it on his 346 LS1 motor and it worked great.
nhraformula00 is online now   Reply With Quote
Old 02-07-2010, 05:40 PM   #3
s10w/sbford
Spooled up
s10w/sbford's Avatar
my friend did this on his 460 sbf and worked great. he used the lindy tool also,he was having a hard time getting the isky. he said the lindy tool was better anyway....hope this helps
07 PINKS WINNER VMP
IHRA CHASSIS INSPECTOR
804 648 8737
s10w/sbford is offline   Reply With Quote
Old 02-07-2010, 05:55 PM   #4
WeDgiE
WeDgiE's Avatar
thx.. how much are they or do they rent them?
Old 02-07-2010, 08:25 PM   #5
nhraformula00
He is a tool maker,they are about 80$ each plus you need a mandrel.So like 200 for 1intake,1 exhaust,1 mandrel.Call him and tell him your valve sizes and he will make 1 for each.They fit in in place of the valves,all you do is remove all the valves from one head.
Old 02-07-2010, 10:21 PM   #6
Lightners
Lightners's Avatar
How much money do you have invested so far...alot...take the short block apart and do it right!!
Rod Lightner
Lightners is offline   Reply With Quote
Old 02-08-2010, 08:08 AM   #7
smoke ya
Spooled up
smoke ya's Avatar
Quote:
X2
smoke ya is offline   Reply With Quote
Old 02-08-2010, 10:23 AM   #8
Radical540
Misanthropist
Radical540's Avatar
How far off are your current valve reliefs??
"It's not about pop-up Nav screens,burl wood accents, 40 gig harddrives, or sunroofs...Nope, it's not about any of that-- the REAL question is, when you turn your car on- Does it return the favor?"
Radical540 is offline   Reply With Quote
Old 02-08-2010, 12:00 PM   #9
Mark O'Neal
Idiot Savant
Mark O'Neal's Avatar
Quote:
Good question!
Why would a rocker change require cutting the valve reliefs?
Mark O'Neal is offline   Reply With Quote
Old 02-08-2010, 12:37 PM   #10
youngengines
youngengines's Avatar
What I'm getting is he's moving up in ratio. If he's border line on clearance and went from, say a 1.5 to 1.6. With .600 lift at 1.5 (.400 lobe lift), he would now have .640. I know the engine I'm putting back together for my car will clear with a 1.8. but I gotta cut for the 1.9's and 1.95's.
youngengines is offline   Reply With Quote
Old 02-08-2010, 03:48 PM   #11
WeDgiE
WeDgiE's Avatar
Quote:
yea.... the T&d 1.5's clear but thats it ! wanna go atleast 1.65/1.7
Old 02-08-2010, 04:44 PM   #12
B1 SCOTT
Burnout box
If your rocker ratio increases max lift .060 that doesn't mean you will need .060 more cut out of the valve relief.
B1 SCOTT is offline   Reply With Quote
Old 02-08-2010, 04:54 PM   #13
WeDgiE
WeDgiE's Avatar
ratio change will increase lift .065,,, please explain B1. thx
Old 02-08-2010, 05:12 PM   #14
s10w/sbford
Spooled up
wedgie,i understand you pain about taking it out, but you need to ck actually how much v/p clearance you have instead of just cutting extra(guessing). the higher ratio rocker will actually open the valve quicker cause of the ratio.
disassembly of shortblock is best but you need to be very careful when cutting it in the block to keep shaving out. it can be done.....but go back and ck v/p clearance and then cut accordingly....it is time well spent....just my .02
07 PINKS WINNER VMP
804 648 8737
Old 02-08-2010, 05:20 PM   #15
B1 SCOTT
Burnout box
Ratio will increase max lift .065 When the valve is at max lift on the intake for example the piston will be 108* past tdc if the cam is installed at 108* icl. The valve will be no where near the piston at max lift because at that point the piston will be inches down in the cylinder. The valves are close to the piston when the piston is near tdc and valve lifts at and near tdc will not increase by .065 Not saying they will not need to be cut just not .065. You should mock it up and check it to be sure. Removing more than needed will lower compression.
