Best SBC Stock Heads - Yellow Bullet Forums
Old 02-03-2010, 01:02 PM   #1
youngengines
youngengines's Avatar
Default Best SBC Stock Heads
I am building a circle track engine for a local dirt track. Its called a "renegade" class. Gotta run .420 lift hyd cam(max) stock crank, rods, flat top 4 eyebow pistons, performer intake, 500 2 barrel holley or #1850 4 barrel holley. We cant run any small chamber heads, no 461's,041's, Vortec etc. Does anyone know what would be the best head # to run? I have been told a 441 (last 3 digitis in casting #) is good. 882's are easy to find, but we are gonna cut them down a lot (no cc rule! )and want the strongest head to resist cracking as well. Any suggestions?
youngengines is offline   Reply With Quote
Old 02-03-2010, 04:35 PM   #2
SStrokerAce
SStrokerAce's Avatar
Default Re: Best SBC Stock Heads
Just stock or can you run aftermarket heads? Gotta be cast iron right?
Prof Gordon Blair “Those engine developers who grossly exaggerate their engine’s power as evidence of their genius!” ARE IDIOTS
SStrokerAce is offline   Reply With Quote
Old 02-03-2010, 04:52 PM   #3
z289sec
z289sec's Avatar
882's get a bad rap for some reason, but I've had some motors with 882's using 2.02 1.60 valves, some decent port work, and a good surfacing. They made good power, for what they were.
I believe they also have one of the better flowing exhaust runners of all the stock iron heads out there. Don't know how much that would help or hurt on a N/A application. Works good for blowers or nitrous though.
Don't know the exact specifics of your camshaft rule and how much choice there is in that low of a lift, but possibly you could use a grind that would keep the cylinder charged longer. Since you can't run a domed piston.
RTCTTFMF!!!!
Stock suspension 67 Camaro
565 Conventional head BBC with fogger and a plate on 275's
Just about done
Thanks to:
Texas Racewerks, Sanger, Texas
Nyes Automotive Racing Engines, Muncie, Indiana
FTI Converters and Transmissions, Deland, Florida
ACE Racing Transmissions, Garland ,Texas
z289sec is offline   Reply With Quote
Old 02-03-2010, 07:23 PM   #4
Quik598
Launchin
The 441's are a good head to use.
Quik598 is offline   Reply With Quote
Old 02-03-2010, 08:05 PM   #5
Gerald Dyer
Spooled up
993 are a very good head single heat riser as to the 882 has 2 heat risers, I have a set we run on our dirt car they are 52cc's call me is you need a cam also or more info.
Gerald Dyer is offline   Reply With Quote
Old 02-03-2010, 08:53 PM   #6
youngengines
I'll probably run an Isky cam. I run them in the .450 lift rule engines. They have 244 dur at .050. They have a .420 lift with 248 at .050 too. Howards has a .420 lift with 250int 254exh at .050 as well. I gotta run stock production heads. (cast iron). Are the 993 a small chamber originally? We cant port at all, and gotta run 1.94 1.5 valves. Thanks Guy's
Old 02-03-2010, 09:07 PM   #7
gforce nos
Launchin
gforce nos's Avatar
They're some good flowing vortec heads for cheap out there.
gforce nos is offline   Reply With Quote
Old 02-03-2010, 09:08 PM   #8
Tom Cowle's wife
Tom Cowle's wife's Avatar
AMC combinations legal? or chevy only? If chevy only I'd do the 441's
Tom Cowle's wife is offline   Reply With Quote
Old 02-03-2010, 09:18 PM   #9
Gerald Dyer
Spooled up
Yes 993's are open chambers
Old 02-03-2010, 09:26 PM   #10
youngengines
[QUOTE=gforce nos;3559019]They're some good flowing vortec heads for cheap out there.[/QUOT
Vortec's arent allowed.
Old 02-03-2010, 09:49 PM   #11
90lxracer
90lxracer's Avatar
What about 186's and 292's? Oh weren't there some 041's too?
O.G. X275 racer
90lxracer is offline   Reply With Quote
Old 02-03-2010, 09:59 PM   #12
youngengines
Quote:
No, no small chamber heads at all. That includes 461,462,041,292,Vortec, Cant remember all the #'s but ya get the picture. However there is no cc rule so we will cut the heads down as much as possible.
Old 02-03-2010, 10:39 PM   #13
*BOSSMAN*
*BOSSMAN*'s Avatar
487 or 487X are another sought after casting.
http://www.smithbergracing.com
*BOSSMAN* is offline   Reply With Quote
Old 02-04-2010, 09:37 AM   #14
youngengines
Quote:
Did you angle mill em to get to 52cc? Can you tell me how much ya had to cut em? Thanks for the info.
Old 02-04-2010, 08:43 PM   #15
Gerald Dyer
Spooled up
175 angle mill, Then take a 2.1 valve and turn it down to leave large margen, same way on ex.
