Can you reuse fel-pro permatorque head gaskets? - Yellow Bullet Forums
Old 02-01-2010, 07:27 PM   #1
94-6spd
94-6spd's Avatar
Default Can you reuse fel-pro permatorque head gaskets?
Would it be wise to reuse these gaskets? I have a couple of used sets from rebuilds. It's a hundred dollars that I could spend elsewhere if it'd be ok. They aren't blown out or anything.
http://www.jegs.com/i/Fel+Pro/375/17031/10002/-1
94-6spd is offline   Reply With Quote
Old 02-01-2010, 08:16 PM   #2
crd89stang
Spooled up
Default Re: Can you reuse fel-pro permatorque head gaskets?
no why would you want to skimp on 100.00 gaskets with all the money you have spent? Is it really worth leaking head gaskets
crd89stang is offline   Reply With Quote
Old 02-01-2010, 08:21 PM   #3
94-6spd
94-6spd's Avatar
Some are reusable and I'm just asking. These actually look great to be honest. Do you know if these can be reused?
Old 02-01-2010, 08:43 PM   #4
sprayinstang
Launchin
I have reused them several times. Just make sure you use your same torque sequence. Never had a problem.
sprayinstang is offline   Reply With Quote
Old 02-01-2010, 08:57 PM   #5
njc.corp
njc.corp's Avatar
Cool Re: Can you reuse fel-pro permatorque head gaskets?
Quote:
I don't think its about skimping but i tend to use them only twice as i notice the outer ring on the mls ware off-(i mainly do ls engines )
i have never had a issue with using them only twice-
I know some had gone a season with them before a refresh of the whole engine-
NJCLSX ENGINES- PARTS/SALES/PERFORMANCE
www.njclsx.com
sales@njclsx.com
PH-61 03 9331-6757
FRE--ENGINES
www.Nitrousoutlet.com
www.ptcrace.com
www.straubtechnologies.com
njc.corp is offline   Reply With Quote
Old 02-01-2010, 09:29 PM   #6
Ron Miller
Ron Miller's Avatar
Why not, I have in the past. Is it a N/A deal or ?? Give them a light coat of Permatex Copper Head Gasket Spray.
Ron Miller
Brownstown,Michigan
Ron Miller is offline   Reply With Quote
Old 02-01-2010, 10:03 PM   #7
94-6spd
94-6spd's Avatar
I think I'm going to save my hundred dollars and reuse these. One set only had six passes when a rod bearing spun. I will probably try the copper spray as well. BTW, these are the marine gaskets that are a little stouter to begin with.
Anyone ever heard of putting a light layer of marine grease on head gaskets? An old guy told me to do this years ago. I didn't do this on this engine but maybe it was the old way to do things before copper spray.
Old 02-01-2010, 10:10 PM   #8
Hotrod 36
Member
Pullin gears
Hotrod 36's Avatar
I agree.
Hotrod 36 is offline   Reply With Quote
Old 02-02-2010, 01:35 AM   #9
sc3283
Launchin
sc3283's Avatar
remember its more than just the gasket material you need to worry about.....the sealing ring around the cylinder bore has been compressed on the 1st use....just a thought...I have never reused them...not worth my time to have to do it again if it would leak
sc3283 is offline   Reply With Quote
Old 02-02-2010, 02:13 AM   #10
pontiac_baron
Spooled up
I've reused them quite a few times
Clay Marsh
1967 GTO TT Convertible, 5 spd
pontiac_baron is offline   Reply With Quote
Resources saved on this page: MySQL 1.09%
