thinking about a 70s jet boat any advise ? - Yellow Bullet Forums
Old 01-22-2010, 05:27 AM   #1
Lsxoo7
Lsxoo7's Avatar
Default thinking about a 70s jet boat any advise ?
looking for a nice jet boat to enjoy this summer have seen a few local on Craigslist and looking for some advise before i purchase . dos and donts and any other helpfull info.
most of the are earlie late 70s , looking for mainly a big block to be able to mess around later .
pics and info and wich boats to stay away from would help out greatly !
Lsxoo7 is offline   Reply With Quote
Old 01-22-2010, 05:39 AM   #2
Drag Racer 345D
Default Re: thinking about a 70s jet boat any advise ?
Where do you live?
Drag Racer 345D is offline   Reply With Quote
Old 01-22-2010, 06:20 AM   #3
69Z
Member
Pullin gears
69Z's Avatar
If you want a boat that will run some big #s look at a youngblood and there have been a bunch of copies of them.
69Z is offline   Reply With Quote
Old 01-22-2010, 06:26 AM   #4
low warranty
low warranty's Avatar
the two best days of boat ownership; the day you buy one, and the day you sell it.
Special Thanks to:
Billy Briggs
Jim-Powski Racecraft
Joels on Joy
TRZ Motorsports
DADS Custom Intercooler Tanks
RCS
low warranty is offline   Reply With Quote
Old 01-22-2010, 07:11 AM   #5
B DOUCET
Launchin
B DOUCET's Avatar
We had a Taylor back in the late 70's that was a very well built boat. Look for one with a Berkley pump and a BB Chevy are Ford. Stay away from anything with a Jaccuzi pump. They were slow and burn fuel like crazy. The Younglood hulls were light weight, but the one I had would peel the outer gelcoat finish of in small sheets from the bottom. Good luck.
B DOUCET is offline   Reply With Quote
Old 01-22-2010, 07:41 AM   #6
mad man
mad man's Avatar
Quote:
x2
mad man is offline   Reply With Quote
Old 01-22-2010, 08:50 AM   #7
FordRacing250
FordRacing250's Avatar
Like said, try to find one with a berkley pump. We had a challanger for a while. was a great boat. had the engine and jet set back about a foot.
Check the bottom side of the hull for damage, cracks ect... and also where the engine plates mount.
RaceTec Pistons
OB1 Joel @ Orme Brothers
FordRacing250 is offline   Reply With Quote
Old 01-22-2010, 09:27 AM   #8
Codeman
Codeman's Avatar
www.screamandfly.com anything you could possibly need to know can be found there.
Codeman is offline   Reply With Quote
Old 01-22-2010, 09:34 AM   #9
motorman
Burnout box
motorman's Avatar
forget the jet find a vdrive
motorman is offline   Reply With Quote
Old 01-22-2010, 09:39 AM   #10
bad_68
Member
Pullin gears
bad_68's Avatar
Ihad a Tahiti for 20 years. BB Olds with Berkley Jetovater pump.Killer 200 ft roostertails! Check the transom and floors good for rotting wood.
1968 Mustang 3200lbs
Well's Racing 427 SBF
E85 carb by Mark Sullens
Bullet Solid Roller
Victor Jr
AFR 205's
Performance Transmissions , Kennedale Texas
4.11 Rear
M/T Pro Drag Radials 275/60/15
Kroger "Racin'Fuel" E85
Thanks to my sponsor! My Wife's Bank Account. LOL!
10.02 @ 132 1.34 60' "New Best" 4-21-13
http://www.youtube.com/watch?v=1aGqQxq1mCw Drag Radials w/E85
"Corn Fed Ford"
bad_68 is offline   Reply With Quote
Old 01-22-2010, 10:32 AM   #11
DRAGRACR
Spooled up
DRAGRACR's Avatar
Just really depends on what you are wanting to do with it.... Just check the floors and runners in these older hulls... x10 on the Berkley pump, and if you are looking for a rooster tail get a jetavador(lets u adjust the nozzle from the drivers seat) Taylor is one of the heaver hulls, and dont look as good to me. I have owned a Hawaiian, youngblood and sanger picklefork. The youngblood is a damn good hull for speed, just make sure what thickness the hull is when buying, and check for cracks as stated. There used to be 3 versions of thickness.
Also if you are looking to go as fast as possible cheap, then go with a v drive. If you were to put the same motor in a jet will be prob 15-20mph slower than a v drive.. It takes way less motor to push the v.
DRAGRACR is offline   Reply With Quote
Old 01-22-2010, 03:25 PM   #12
Eddie Wilson
Eddie Wilson's Avatar
Jets are fun as hell! I have a Bahner 18 ft with a berkley drive. 468 ci Chevy B/B with water injected headers.It has the orginal gel coat /paint.....I never take out since buying a Jet Ski. Left hand drive.
I would like to sell. its just taking up space............. I can post pics?
EWW
Eddie Wilson is offline   Reply With Quote
Old 01-22-2010, 03:36 PM   #13
Blownmope
Thread killa
Blownmope's Avatar
Find something with a jet o vator, drive the boat and if it rpms like crazy and isn't moving out of the hole the impeller is probably junk. If you need parts and pump work this is the guy to go to.
http://home.pacbell.net/jmcclure/
Jack is a great guy and will give you great info and help out on your set up.
Have a super sparkly day!
Blownmope is offline   Reply With Quote
Old 01-22-2010, 04:11 PM   #14
GM KILLER 5.0
Member
Pullin gears
GM KILLER 5.0's Avatar
I have a early 70's Tahiti Torino, Berkley pump with Jetovator trim. Used to have a 455 Olds, that went boom, so it now has a 468 BBC. It's a lot of fun, shoots a lot of water!!!!! It's left had drive, with a gas pedal for the throttle, get's a lot of looks. It's THIRSTY though!!!! Good Luck.
GM KILLER 5.0 is offline   Reply With Quote
Old 01-22-2010, 04:16 PM   #15
Drag Racer 345D
Had a Kachina. BBC with a glide. Berkley pump and had to have the jetovator! Rooster tails were high and long. When you beat another boat you could get them soaking wet.....lol Dont think a jetovator is allowed in Az. anymore.
