oil pressure to high for hyd. lifter?? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Supercharged - All Out Automotive
Old 01-16-2010, 12:52 AM   #1
9sectruck
Launchin
9sectruck's Avatar
Default oil pressure to high for hyd. lifter??
I originally set the rockers 1/2 turn past zero lash, the engine would not fire, so I done a compression test 100psi, then i backed off all the rockers and done another compression test and got 120 130s, on the seconed go around i only went 1/4 turn past zero lash, the engine fired and ran for two 1min cycles but it never sounded right, so directly after the second run i pulled some plugs and did another compression test and again "I only got 104psi, I run 20/50 vr1 oil at 85psi, is the oil pressure to high and causing the lifter to pump up and act like a solid????
9sectruck is offline   Reply With Quote
Old 01-16-2010, 02:01 AM   #2
notagn
Member
Pullin gears
notagn's Avatar
Default Re: oil pressure to high for hyd. lifter??
Try backing off your lifters some and grammer school.
notagn is offline   Reply With Quote
Old 01-16-2010, 02:47 AM   #3
GrannySShifting
GrannySShifting's Avatar
no, we run 100 psi oil pressure and do some dumb shit with hyd lifters. Just put a tiny amount of preload (.010 though, a 1/16 of a turn or just enough to take lash out) on the to get it started, let the lifters pump up, then redo them. Maybe youve got them collapsed and they are pump up as it runs and you have much more preload than you think.
GrannySShifting is offline   Reply With Quote
Old 01-16-2010, 09:54 AM   #4
9sectruck
Launchin
9sectruck's Avatar
my cam is only a 610 lift at the rocker, if you dont preload them enough wont the lifter just collapse instead of pushing the valve open?
Old 01-16-2010, 11:35 AM   #5
WJ Birmingham
WJ Birmingham's Avatar
Quote:
100% agree.
I bet the lifters are bottomed out.
Back them all the way off, then hold the push rod and jiggle it as you tighten the lash up. When you can feel the slack go away, stop. Once the slack is gone, you can still probably collapse the lifter another 1/4".
Rather than accepting things you can't change; change the things you can't accept.
WJ Birmingham is offline   Reply With Quote
Old 01-16-2010, 09:01 PM   #6
9sectruck
Launchin
9sectruck's Avatar
ok i figured out my lash problem, i found out its not the lifter at all its the overlap on the cam, with the rockers completly loose the valve terain will not see the cam profile. we set the rockers from zero lash, and all the way down to 1/2 turn past zero lash and the compression test came out the same
AGREE????????????????
Old 01-18-2010, 02:19 PM   #7
Bellman
Bellman's Avatar
Quote:
If the lifters are filling with oil, they will not compress..
BTW.. I set my lifter pre-load at only 1/8 turn, after all the pushrod slack is removed.. My hydraulicly cammed motor turns around 7500 thru the lights..
86 Mustang GT
383 ci SBF
Garrett GTX5518r turbo
TH400 Tranny
Bellman is offline   Reply With Quote
Old 01-18-2010, 10:23 PM   #8
Bandit1320
Launchin
Bandit1320's Avatar
how much spring pressure Jeff?
Bandit1320 is offline   Reply With Quote
Old 01-18-2010, 10:30 PM   #9
Bellman
Bellman's Avatar
Quote:
I'll have to check to be sure.. But it's around 215 or 218 lbs on the seat..
86 Mustang GT
383 ci SBF
TH400 Tranny
Old 01-19-2010, 08:19 AM   #10
Bandit1320
Launchin
Bandit1320's Avatar
Not wanting to hyjack the thread but spring pressures are important on hydraulic rollers too and I like doing comparo's to see what others are doing to have success. I think I will end up adding more to mine as I am only at 165 on the seat.
Old 01-19-2010, 10:59 AM   #11
Bellman
Bellman's Avatar
I had a NMRA Renegade racer tell me you can't run too much spring pressure..
I know that's not totally true, but I got the jest of what he was saying..
The Renegade rules state that they must run stock factory roller lifters, and they can't be bottomed out or shimmed up.. Totally un-modified.. Many Renegade cars are turning in excess of 8000 rpms..
Many are also running "zero" lash.. Just taking out all the pushrod clearence.. And NO preload what so ever..
86 Mustang GT
383 ci SBF
TH400 Tranny
Old 01-20-2010, 09:54 AM   #12
Bandit1320
Launchin
Bandit1320's Avatar
Thanks Jeff, this will help clarify questions others may have as well.
I want a solid in my ride but it will have to wait untill next season for now I will use these tricks.
Old 01-20-2010, 05:34 PM   #13
9sectruck
Launchin
9sectruck's Avatar
170 here on the seat but a very mild cam 6500redline
Old 01-21-2010, 09:15 PM   #14
302man
302man's Avatar
I can speak from experience on the lifter thing. You can't have too much oil pressure, anything you do to keep it pumped up is a plus. Depending on your approach on lifters....some guys say you can't have too much spring pressure because they run the lifter almost bottomed out and then run an aggressive cam. Easy to go 8500 rpm that way. Others will run less spring pressure...around 150lbs seat and 375 open...but that at .550 lift. There are more tricks to making a hyd roller rev, but here are some of the basics theories people use.
see me for TUBULAR MUSTANG BUMPERS
Parachute Bumpers for Fox Bodies
www.DonathenRacing.com
See my face book for more pictures "Tim Donathen"
87 Mustang - Drag Radial Car
ProTree Race Cars -Chassis
Simple Engine and Machine
Kurgan Motorsports - Tune
Automotion Race Cars
Mike Duke Cylinder Heads
5.27@138 so far on 275's
302man is offline   Reply With Quote
Old 01-22-2010, 02:00 AM   #15
GrannySShifting
.600-.700 lift, done everything from @130 on seat to 220 on seat and turned stuff 7500-8300 rpm Its a combination of alot of things, lifter valving, valvetrain mass and location, spring setup, and of course lobe choice.
if someone is telling you you cant run too much pressure, also consider if they are limited lift classes and they are purposefully lofting the valves. In that case Im sure you want it to loft and settle down ASAP. The one thing I dont like about tons of spring pressure though esp on stock cast lifter bodies not something as rigid as Morels or something, would be what I imagine happening with lifter body distortion. If it dont stay round, wont seal well just like a ring seal&cylinder.
Sometimes, MORE lift will make a lobe more stable at rpm when other dynamics start to show up vs 1500 rpm action
