cecilcountydragway.co;
Old 01-16-2010, 08:16 AM   #166
t berry
t berry's Avatar
Default Re: ORSCA REAL STREET 2010 RULES & PAYOUT........
Quote:
Originally Posted by 1SLOLT1 View Post
Made some clarifications...
Entry Fee - $75.00
Winner - $700
R/U - $200
3 - $100
4 - $100
Contingency options:
$125 is a 1 year membership and you are in the hunt for points and contingency eligible.
Each race is $75 for everybody. member or non member.
For the 1 time racer at his/her local track you can pay an additional $25 to be eligible for contingency for that individual race.
So if you are a local racer and want to race one time only but you want to be eligible for contingency your entry fee would be $100. No contingency eligibility would be $75
REAL STREET RULES
- No Transbrake
- Any size true street radial (300 Tread Wear Rating or greater) Drag radial rules below
- No Lexan
- Full Interior can swap to aftermarket gauges, must retain stock dash (any added safety equipment acceptable)
- Exhaust at least to within 12" of the rear axle with mufflers (3" duals, 4" single)
- 427ci SB max
- Only BBs allowed are factory Buick, Olds, Pontiac, AMC (Up to 500ci)add 100lbs
- EFI must use factory computer
- 3100lb base weight
- Plate system nitrous only (.092 jet limit SB) (0.63 jet limit BB) (3200lbs)One fuel solenoid, One nitrous solenoid, Purge must be in line.
- Turbo's limited to SINGLE 76mm and equivalent supercharger (air to air IC only) (meth only with no IC) (3300lbs) - Reducers are not allowed
- Only basic ignition boxes (no 7531)
- No progressives or electronic boost controllers
- Stock style clutches only (no slipper clutches)
- Stock suspension only (no 4-links or backhalf cars)
- Qualifying runs required for eliminations. Random pairing during eliminations.
Tire Tread Dia
235/60/15 BFG/NITTO 8" 26.1
275/50/15 BFG/NITTO 10" 26.1
255/50/16 BFG/NITTO 9.7" 26.1
275/40/17 BFG/NITTO 10.2" 25.7
285/35/18 BFG/NITTO 10.2” 26.2
ANY SIZE ON TRUE STREET RADIAL
Cylinder Heads Limited to Stock Valve Angle only!
No Sheet Metal Intakes!
4150 Carbs ONLY!!!
All veh. Must be registered, tagged, insured, and licensed driver…All lights must work…
TECH INSPECTION HAS THE FINAL SAY ON ALLOWING A CAR TO RACE. IF YOU BRING A RACE CAR YOU WILL BE DISAPPOINTED.
I like these rules.
t berry is offline   Reply With Quote
Old 01-16-2010, 08:22 AM   #167
Zippo
Launchin
Zippo's Avatar
I like them too,
I need to rethink my vacation plans for the year
Zippo is offline   Reply With Quote
Old 01-16-2010, 08:48 AM   #168
WRIGHTRACING
UNDFTD
WRIGHTRACING's Avatar
Todd glad to see you're helping ORSCA out with the rules for this year...looks to be making racers happier when they get to make suggestions and someone listens. Good job BTW, I know you say it's nothing and you're just listening to the racers, but it really does help when the racers actually get a say so in what goes on...I can't say anything I ain't raced in a while, but am working on getting this thing back together, hopefully in time to make a few ORSCA races this year...
WWW.NDRRA.COM WWW.OUTLAWRACING.COM
Quote:
Originally Posted by broncomania View Post
new update : the oil leak has been stopped. a diver dropped his wedding ring in the gushing hole and all of a sudden it quit putting out.
WRIGHTRACING is offline   Reply With Quote
Old 01-16-2010, 09:25 AM   #169
t berry
t berry's Avatar
Quote:
Thanks,
I think as long as everyone works together it want do nothing but make it better. When the racers actually take part in helping there class it gives them ownership and that is a good thing for everyone.
You will never fail if everyone believes in what they are doing.
Old 01-16-2010, 09:43 AM   #170
1SLOLT1
1SLOLT1's Avatar
Is it March yet damn it?
95 Z28 - Slow
www.1slolt1.com
1SLOLT1 is online now   Reply With Quote
Old 01-16-2010, 11:00 AM   #171
lighting bolt
Spooled up
Quote:
Originally Posted by t berry View Post
No 7531 boxes. If you have a stock computer it will do the timing if not your not legal anyway.
Stock computer? You tell me what 85 mustang came with a stock computer. My car came from ford with a carb and it still has one on it today. I'm not knocking your rules im asking questions to see if i could join in the fun. So is a MSD BTM legal or not?
lighting bolt is offline   Reply With Quote
Old 01-16-2010, 11:08 AM   #172
WRIGHTRACING
UNDFTD
I don't know to say they are legal or not, don't know the functions they have. But I do wander How the hell did you fit 18" wide tires under a stock suspension Mustang?
Old 01-16-2010, 11:26 AM   #173
lighting bolt
Spooled up
The function of a BTM is plain and simple. It pulls out X amount of timing per X amount of boost. It's just a 6AL with the timing feature. To answer your other question. I have more than one car in my garage, just trying to figure out which would be closer to fitting in the class. The better question would be how did a 85 mustang with SS end up with leaf springs.. lol
Old 01-16-2010, 11:35 AM   #174
1SLOLT1
1SLOLT1's Avatar
I am thinking the class should be limited to 6AL type boxes. It is OK if the box pulls timing but it should not be able to ramp timing in or out based on boost, time, gear, etc...
95 Z28 - Slow
www.1slolt1.com
Old 01-16-2010, 11:35 AM   #175
WRIGHTRACING
UNDFTD
I noticed that when I went back and read it....that was all posted when I was at work last night and I remembered it on the email I read coming home...lol...But for the case of the BTM, is it the same as one that would pull timing for nitrous at the hit and thats all it does???
Old 01-16-2010, 11:43 AM   #176
lighting bolt
Spooled up
Are we on both sides of the fence here or what? I just said a MSD BTM pulls timing based off the amount of boost. If you put the little knob on 2 it pulls 2 deg of timing per pound of boost. But it will not pull more than a total of 15deg of timing. That is the only feature it has over a 6al.
Old 01-16-2010, 12:05 PM   #177
WRIGHTRACING
UNDFTD
So basically like I explained it...all it is, is a timing control to take out timing with boost...sounds legal, like slo said as long as you dont pull timing when it spins, or add all the timing back when you get to half track...
Old 01-16-2010, 12:08 PM   #178
t berry
t berry's Avatar
Sounds cool to me.
Old 01-16-2010, 12:15 PM   #179
lighting bolt
Spooled up
Nope once she pulls timing thats it, you cant ramp it back in at any point down the track.
Old 01-16-2010, 12:17 PM   #180
lighting bolt
Spooled up
Quote:
Originally Posted by lighting bolt View Post
So a fully tubbed car with stock leaf springs and cal-tracs are not ok? And the MT S/R?
Now back to my other question that never got answered.
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
YellowBullet.com
