NDRRA/KOTS X275 Points Race Series - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 01-09-2010, 03:26 PM   #1
02SS:Zeus
Spooled up
02SS:Zeus's Avatar
Default NDRRA/KOTS X275 Points Race Series
2010 SCHEDULE
April 9-11 Rockingham Civil Wars
June 12 Motor Mile
July 3rd Farmington
Aug 14 Motor Mile
Sept 11 Peidmont tentative date
October 1-3 Rockingham Fall Civil Wars
2010 RULES:
N.D.R.R.A. X275
X275 is a extreme 275 drag radial class.
Updated 1-7-10
X275 is an 1/8 mile heads-up class run on a .400 pro tree with a pro ladder. X275 is an all run field. Courtesy staging and auto-start is in effect.
TIRES:
01* All cars must compete on a Drag Radial type tire with the sidewall designation 275/60/15 or 275/50/15.
BODY:
02* All body panels other than hood and spoiler must have stock dimensions, no part may have exposed fasteners except the hood and deck lid, Lexan must look like stock glass from 15' away
03* Any hood and scoop permitted.
04* Must retain firewall in the stock location
05* Must measure within 1" of factory wheelbase, body may not be moved from stock location
06* Must have all working stock type headlights and taillights
07* No gutted interior, must have carpet, door panels and factory type dash.
CHASSIS & SUSPENSION:
08* Stock style suspension or 3 link ladder bar cars only. Four links are prohibited.
09* Complete stock frame rails must be retained. Back-halved cars are not permitted. Front core support may be modified or removed.
10* Rack and pinion conversions allowed
11* Mini tubs are allowed. Rear frame rails may be notched for clearance.
12* Pre 1979 vehicles may have a bolt on aftermarket subframe front end.
13* Pre 1974 Mustangs and Falcons may have a Mustang II front suspension conversion
14* Bolt on tubular K-member and A-arms are permitted
15* Front and rear coil-over conversions are allowed. Rear leaf springs, shocks, and coil-overs may be moved to accommodate tire clearance.
16* No wheelie bars allowed.
ENGINE:
17* Maximum displacement for all engines is 640ci. No 4.6" or larger bore space blocks.
18* GM blocks are limited to a 10.2 deck height, Fords to a 10.3 and Mopars to a 10.7 deck height.
19* Small Block combinations may run any type induction.
20* Big Block combinations are limited to a single carburetor with cast intake.
FORCED INDUCTION:
21* Forced induction permitted on small blocks only.
22* Any type intercooler is permitted.
23* Single power adders only except on 2-rotor, 4-cylinder, and 6-cylinder cars.
24* Turbo limited to single true 88mm or smaller, no sleeves or reducers permitted to arrive at this measurement. The compressor wheel must be no larger than 88mm. Tech dis-assembly permitted for compressor wheel measurements if necessary.
25* Roots superchargers are limited to a 10-71. Screw superchargers are not permitted.
26* Centrifugal superchargers are limited to a single F1R, Xi or smaller.
NITROUS OXIDE:
27* Small block is permitted to run any type multi-stage nitrous system (cars equipped with canted valve heads are limited to 2 nitrous stages).
28* Big blocks are limited to a single stage nitrous system (A single stage fogger is permitted or if using a single plate then your limited to 1 fuel solenoid, 1 nitrous solenoid, and 1 purge solenoid). 2nd system plates must be removed and fogger plumbing removed. Fogger nozzles can remain individually capped off.
29* All nitrous purge discharge tubes must be pointed away from any openings in the hood and the plume must be visibly all outside the engine bay.
EXHAUST:
30* Mufflers or inserts are required on all cars except for turbo cars. Exhaust may exit underneath car or out the front fenders.
FUEL:
31* Gasoline only is permitted. Methanol or E-85 or other derivatives are prohibited except on roots positive displacement blowers.
MINIMUM WEIGHTS WITH DRIVER:
Small Block
* Naturally Aspirated 2700 lbs.
* Nitrous 3100 lbs.
* Single YSI / F1A Supercharger 3100 lbs.
* Single F1C Supercharger 3200 lbs.
* Single F1R / Xi Supercharger 3300 lbs.
* Single 76mm T6 Turbocharger 3100 lbs.
* Single 80mm T6 Turbocharger 3200 lbs.
* Single 85mm T6 Turbocharger 3300 lbs.
* Single 88mm T6 Turbocharger 3350 lbs.
Big Block
* Naturally Aspirated (standard deck height and conventional head) 3000 lbs.
* Naturally Aspirated (tall deck height and conventional head) 3100 lbs.
* Naturally Aspirated (standard height and big chief head) 3250 lbs.
* Nitrous (standard deck height and conventional head) 3250 lbs.
* Nitrous (tall deck height and conventional head) 3400 lbs.
* Small Blocks with single stage nitrous system: deduct 100 lbs.
* Small Blocks with 23 degree Chevy heads, 20 degree Ford heads, and 18 degree Mopar heads: deduct 100 lbs.
* Non-Intercooled cars: deduct 50 lbs.
* Aftermarket rear suspension (Ladder bar): add 50 lbs.
PROCEDURE
* Once a racer takes the tree in qualifying they are counted in the ladder, will receive participation points and may not get an entree refund.
* All cars must be driven from the pit area to the starting line but may be towed back after a pass.
* Rules are subject to change and any combination that shows to have an definite advantage can be penalized to equalize the competition.
* Weather and time permitting, there will be 2 qualifying sessions. The quickest time will be the official qualifying time. Racers will be paired according to a pro-ladder. Driver with the quicker E.T. in the previous round during eliminations will have lane choice.
* Each car may only have 3 crew members in the staging area.
* Deep staging allowed at drivers own risk, no provisions made to hold the tree for the driver.
* If a race ends for any reason during a round of competition
no points will be given for that unfinished round.
* Any minor intentional or unintentional rule infraction that does not
cause a definite advantage will result in loss of any points and winnings achieved while in violation.
* Any intentional rule infraction done to gain advantage over the competition will result in a suspension from King of the Streets races for up to one year and no less than 2 races.
* A round does not begin until a KOTS official working the lanes says so.
* A driver does not start his burn out until an official says so.
* Once we signal the burn outs each driver has 1 minute to stage the car completely after the burnout. No just sitting there for no reason, you can be forced to stage by any KOTS official or the track starter.
* If a driver refuses to stage or is unable to stage or proceed to burnout after an official has told them to, the drivers will be disqualified during eliminations or loose their qualifying attempt for that round during qualifying.
* All drivers must be ready when called to the burnout box and must pull into his lane immediately when motioned up by an official or he will loose that round.
* If a driver double bulbs, the other driver does not have to pull up to the first beam. He can make the other driver back out and prestage again.
* Treat the other driver the way you want to be treated.
* If you have a problem with another driver or team, take it up with me (in an civil manner) not the other driver or team. If anyone starts an altercation with anyone else (right or wrong) they will not be allowed in the competition area for a year (the instigator only not the entire team).
2010 POINTS INFO:
2010
Points System
5 points - entering a race
1 point - each round won
1 point - low ET of the event
1 point - #1 qualifier
1 point - best reaction during eliminations
3 points - winning the race
5 points - attending every race
--Here is the points page where the points are kept. You will be able to see the current points standings throughout the season.
http://www.king-of-the-streets.org/Points%202010.htm
PAYOUT INFO:
Info to come. Working on $1,000.00 guaranteed prize payout with runner up.
SPECIAL NOTE: Both cival wars races are holcomb motorsports events. We are only carrying over your points from them and they will handle those payouts seperate from ndrra. Thanks.
Along with championship awards to 1st, 2nd , and two semi losers points winners .
ENTRY FEE WILL BE $50.00 PER CAR PER RACE.
2010 ADVERTISERS:
These are the businesses that are advertising our event. So please remember them when you need something. Without them we could not put on this race series.
( ALL ADVERTISERS GET THEIR NAME ON RACE SERIES T-SHIRTS & BANNERS. )
I'll keep the thread updated as we add new advertisers/sponsors. Thanks.
SPECIAL THANKS TO :
#1. KOTS - King of the Streets .com
#2. 1st Choice Lawn & Garden 336-776-8288 - Rodney Byerly
#3. Diamond Detailing - Commercial Cleaning 336-382-8033 - Melany Shoffner
#4. Hot Rod Shop - 336-689-0585 - Johnny Akines
#5.
#6.
#7.
#8.
#9.
#10.
If you have any questions, feel free to ask, or post them up over at NDRRA.com. Thanks.
NDRRA/KOTS X275 2010
2002 SS Camaro - ZEUS - #904
347 cid LS1 - 9.30 @ 144
02SS:Zeus is offline   Reply With Quote
Old 01-09-2010, 10:00 PM   #2
MelScrilla
Fastest mustang roller
MelScrilla's Avatar
Default Re: NDRRA/KOTS X275 Points Race Series
doing good things in a relatively short time
Quote:
Originally Posted by Monty Mikho View Post
This reminds me a lot of the civil war when the south was throwing dynamite at the north so the north got mad, lit the dynamite and threw it back..
MelScrilla is offline   Reply With Quote
Old 01-10-2010, 08:00 PM   #3
broncomania
Mike Case
broncomania's Avatar
Quote:
thanks. hopefully next year we can pay more money. its a learning experience for me.
East Coast Surplus & Tactical
336-674-3868
broncomania is offline   Reply With Quote
Old 01-11-2010, 12:58 PM   #4
02SS:Zeus
Spooled up
02SS:Zeus's Avatar
Being I can't edit my original post, I'll keep things as updated as I can with new posts.
***The 50 pound weight penalty for ladder bar cars has been removed***
We also have a new advertiser....
SPECIAL THANKS TO :
#5. Rumley Services - 336-669-8115 - David Rumley
Old 01-11-2010, 01:15 PM   #5
LS1StreetZ
Launchin
LS1StreetZ's Avatar
this should be a blast!
LS1StreetZ is offline   Reply With Quote
Old 01-12-2010, 05:32 PM   #6
02SS:Zeus
Spooled up
02SS:Zeus's Avatar
Added a couple more advertisers. Thanks guys!
SPECIAL THANKS TO :
#6. Jab Construction - 336-312-1721 - Joe Alvarez
#7. Johnson Custom Construction - 336-498-7720 - Don Johnson
Old 01-15-2010, 06:31 PM   #7
broncomania
Mike Case
thanks for updating this post ken. im working now on getting us some stuff for the points winner and runner up. cash,jacket,275's , plaques !!!!! this race starts and ends with the holcomb motorsports cival wars at rockingham. a lot of you guys will be there racing. might as well hit the other 4 races and grab some winnings and earn your bragging rights as the class champion. thanks.
-mike.
336-674-3868
Old 01-15-2010, 11:26 PM   #8
SouthernTrendKill
Revolution Is My Name
SouthernTrendKill's Avatar
So progressive controllers are legal?
SouthernTrendKill is offline   Reply With Quote
Old 01-17-2010, 09:14 PM   #9
broncomania
Mike Case
Quote:
yes and all the weight has been dropped by 100 lbs.
336-674-3868
Old 01-17-2010, 09:18 PM   #10
broncomania
Mike Case
Default official rules
N.D.R.R.A. X275
Updated 1-7-10
TIRES:
BODY:
ENGINE:
FORCED INDUCTION:
NITROUS OXIDE:
EXHAUST:
FUEL:
Small Block
* Naturally Aspirated 2600 lbs.
* Nitrous 3000 lbs.
* Single YSI / F1A Supercharger 3000 lbs.
* Single F1C Supercharger 3100 lbs.
* Single F1R / Xi Supercharger 3200 lbs.
* Single 76mm T6 Turbocharger 3000 lbs.
* Single 80mm T6 Turbocharger 3100 lbs.
* Single 85mm T6 Turbocharger 3200 lbs.
* Single 88mm T6 Turbocharger 3250 lbs.
* Roots blown up to 10-71 3250 lbs.
Big Block
* Naturally Aspirated (standard deck height and conventional head) 2900 lbs.
* Naturally Aspirated (tall deck height and conventional head) 3000 lbs.
* Naturally Aspirated (standard height and Big Chief head or non-conventional) 3100 lbs.
* Nitrous (conventional head) 3300 lbs.
* Nitrous (Big Chief or non-conventional head) 3400 lbs. Limited to a single spray bar plate and a single nitrous solenoid of maximum 1" diameter. No SV1 type carbs.
PROCEDURE
336-674-3868
Old 01-17-2010, 09:19 PM   #11
broncomania
Mike Case
Default differences with x275 up north and ndrra/kots x275
NDRRA weights are 100lbs lighter for all combos.
Makes the cars safer and faster.
NDRRA permits Big Chief style of non-conventional style heads to use nitrous at 3400lbs and with a single spray bar plate, a single max 1" diameter nitrous solenoid and no SV1 carbs
With these restrictions they will not be able to spray as much as the conventional big block and will not be able to get a carb over 1650cfm. With the restrictions and extra 100 lbs they should run equal to the other combos and we will be letting in more cars. The average HP gain from a non conventional big block head will be outweighed by the conventionals being able to use larger solenoids and foggers.
NDRRA does not restrict the use of a manual transmission or electric/air shifters.
Because a stick shift on a 275 would be cool to see and nobody cares about how you shift.
NDRRA allows Methanol as a fuel for roots blowers.
Because not letting a roots blower have alcohol is like being stranded on a island alone with 50
playboy models and getting your junk chopped off.
NDRRA allows 88mm turbos without the 85mm reducer.
Because the reducer don't do much anyway and the weights should keep the combos even without one.
NDRRA has is no rule requiring a drivers seat.
I don't think any explanation is necessary on that one.
NDRRA does not require you to drive to the staging lanes.
This allows you to save the wear and tear of multiple starts and allows for a better plug reading.
NDRRA does not have a weight penalty for ladder bars.
It has been proven many times that ladder bars are no better than a trick stock type set up. This is more fair to cars that came with less than ideal stock rear suspension and should allow for more diverse body styles.
NDRRA allows for a maximum engine size of 640ci instead of 588ci.
638ci is the maximum good rebuild size of the popular 632ci motor. There isn't a gnats anus difference between 588ci and a 632. Some argue the shorter arm makes for a more reliable nitrous motor.
NDRRA does not permit the 28x10.5 slick for any combo.
Because this is a radial only class.
Other than these differences the rules are actually the same other than wording. Any car except for those slick tire fkrs that fit up north fit NDRRA X275. Actually more cars are allowed in NDRRA than up north.
336-674-3868
Resources saved on this page: MySQL 1.08%
