Go Back   Yellow Bullet Forums > Technical Section > Nitrous - Induction Solutions
Old 12-29-2009, 02:14 PM   #1
myworld69ss
Spooled up
myworld69ss's Avatar
Default READING PLUGS WITH REVERSE VALVE BODY TH350
everything I've had to read plugs on has had a PG trans(bump neutral and kill everything etc...) now I need to do some plug checks with a reverse valve body th350 so theres no bumping neutral, if he kills it in high gear its still gonna draw some raw fuel in the cylinders, how well will the plug read like this? what is everybody else doing with this type situation? Thanks!!
myworld69ss is offline   Reply With Quote
Old 12-29-2009, 02:17 PM   #2
myworld69ss
Spooled up
Default Re: READING PLUGS WITH REVERSE VALVE BODY TH350
OH yeah, anybody tried the new NOS jet chart out?
Old 12-29-2009, 02:47 PM   #3
conbread
conbread's Avatar
cant you just hold the leaver and take it all the way to N... i always did that with my c4 and it had a rev valve body..
conbread is offline   Reply With Quote
Old 12-29-2009, 03:22 PM   #4
Jp outlaw
village idiot
NEVER put a 3-speed in neutral while decelerating if you like walking. Rev vb or not.
Just leave it in high gear and click the motor off as you turn onto the return road. The reading will still be plenty clean enough and you're not risking exploding a drum.
Jp Shawgo - Close E'nuff Racing
www.sandeperformance.com -
Quote:
...I just enjoy playin internet forum chess in my spare time...
Jp outlaw is offline   Reply With Quote
Old 12-29-2009, 03:35 PM   #5
conbread
conbread's Avatar
gotcha!! i didnt know that thanks...
Old 12-29-2009, 03:44 PM   #6
marc1166
Member
Pullin gears
marc1166's Avatar
Can't say that I've heard that one before? I've done it for years when I ran an automatic T400. Never had a problem. I might have been lucky?
As for the plugs being plenty clean... That's relative. Depends on if you want a true reading or one that is just close IMHO.
marc1166 is offline   Reply With Quote
Old 12-29-2009, 04:16 PM   #7
Jp outlaw
village idiot
lucky. Read about "neutraling" on the trans forum.
I fully agree that it keeps you from having a 100% true plug reading, but so far it has worked well for me and many other running 3-speeds.
Old 12-29-2009, 04:43 PM   #8
bottlefed1
bottlefed1's Avatar
Marc, what happens is the gear section rotates at a multiple of the output shaft speed, I am not sure of the exact numbers trans to trans but for an example if you are turning 10000 rpm (just to make the math easy, I don't have a calculator handy) and your multiplication is 2.23 your drum would be rotating 22300 rpm. Some may only rotate at the multiple of 2nd gear it all depends on which clutch drags but even at 1.81 it could get ugly. On the glide the gearset is so small the centrifugal forces are small.
Richard G
bottlefed1 is offline   Reply With Quote
Old 12-29-2009, 07:03 PM   #9
SmallBlockNova
Member
Pullin gears
SmallBlockNova's Avatar
I've wondered this myself. Can you kill the ignition through the lights leaving it in high gear?
Thrift-Way Auto Body & Chassisworks
www.thriftwayautobody.com
Just another streeter
SmallBlockNova is offline   Reply With Quote
Old 12-29-2009, 07:13 PM   #10
Power Mad Racing
Power Mad Racing's Avatar
WOW jp I got the rossler 210 ,and always push into nuteral at the traps in 1/8th or 1/4 for 5 years!!..with a cheetah shifter.. lucky i guess??
Power Mad Racing
HorsePower Sales
Power Mad Racing is offline   Reply With Quote
Old 12-29-2009, 07:19 PM   #11
580stang
Member
Pullin gears
580stang's Avatar
if the trans was built right the coast band should not be in the tranny. in a 350 or 400 so all you have to do is shut off the motor.
580stang is offline   Reply With Quote
Old 12-29-2009, 08:04 PM   #12
bottlefed1
bottlefed1's Avatar
Quote:
The Rossler 210 has planetaries that are specifically designed to handle extreme RPM without explosion, in addition to a 123n clean neutral setup.
Richard G
Old 12-29-2009, 09:48 PM   #13
Power Mad Racing
Quote:
thanks sweet It's always good to learn !!!!!
Power Mad Racing
HorsePower Sales
Old 12-30-2009, 11:46 AM   #14
Jp outlaw
village idiot
The clean neutral vb's keep the direct drum applied, but dump the forward, thus keeping the direct drum from "hyper speeding". Killing the motor is no different than clicking into neutral, once the pump stops turning the applys will dump.
If neutralled at speed, the direct drum can/will counter rotate from the output shaft speed via the first gear ratio; thus a stock ratio th400 can spin the drum 2.48 x's the output shaft speed, a stock ratio th350 can spin the drum even faster(lower 1st gear).
Again, search "neutralling" on the trans forum. You'll find a lot of input from people who know much more than me. - I used to drop back to neutral as well, but have stopped doing so pending the input of many builders and a little research. IMO, the perfect plug reading is not as important to me as walking.
Old 12-30-2009, 07:39 PM   #15
droppedf100
Spooled up
droppedf100's Avatar
OK so I have a stock rebuilt C6 with better clutches and a forward manual vb. I should leave it in 3rd gear and shut it off to be safe correct? I have done the neutral thing but only a handfull of times.
droppedf100 is offline   Reply With Quote
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
YellowBullet.com
