BBC NOS cam - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Valvetrain
Old 12-19-2009, 11:59 AM   #1
corcon
corcon's Avatar
Default BBC NOS cam
I've decided to go to a nos only cam in my 588".Dart 360 heads.350-500 shot.What cam company? Anyone have a 598" they would share cam specs.Thanks
corcon is online now   Reply With Quote
Old 12-19-2009, 12:04 PM   #2
tuffguy
Spooled up
tuffguy's Avatar
Default Re: BBC NOS cam
.875-.858 (w/ 1.75) lift 286 306 @.050 114.5 LS 111.5 ICL
tuffguy is offline   Reply With Quote
Old 12-29-2009, 06:00 PM   #3
another69camaro
another69camaro's Avatar
new bullet cam is on the way to my engine builder for my 598 spaying 400hp.901int 875ex with 1.75 rockers.lobe lift 515/500.115 ls forget the duration off hand.
1972 pro street nova. 2x3 Arm front clip and back halfed. All steel with glass hood. 8.50 cert. blown 540.
2009 vrod muscle. Blacked out and lowered. Stage 2 cams. Vreeland cnc ported heads etc 146 rwhp.
Sold 69 camaro
functional glass windows/lights etc
598
fogger and real street plate
single carb/conv heads
25.2
3150lbs
Sold 2003 svt cobra terminator street car
whippled @19psi
624rwhp.
another69camaro is offline   Reply With Quote
Old 12-29-2009, 06:03 PM   #4
another69camaro
duration 287/304 at .050
Sold 69 camaro
598
25.2
3150lbs
whippled @19psi
624rwhp.
Old 01-10-2010, 11:13 PM   #5
yz1
Burnout box
I am building a new 565, and the guys at BES recomended a comp roller with 824 lift 294 int @50 and 300 ex. 4-7 swap 114. my car wieghs 3625 and sprayin 300. for what its worth.
1974 camaro pg 496 ci. 3650# 8.86 @ 152.39 200 kit
yz1 is offline   Reply With Quote
Old 01-16-2010, 12:02 AM   #6
Radialturbodude
Spooled up
Radialturbodude's Avatar
be careful how much lobe lift you put on a std bbc cam core the cam ends up flexing to much
Radialturbodude is offline   Reply With Quote
Old 01-18-2010, 01:45 AM   #7
russ67chevelle
if i was u id contact udharold or bullet for a custom grind! let the pros grind u a cam
russ67chevelle is offline   Reply With Quote
Old 02-12-2010, 02:36 PM   #8
bbc540racer
Member
Pullin gears
bbc540racer's Avatar
just got mine back from bullet and its for a 540 on alcohol with a little spray...286/300 @.050 .874/.821 with 1.8's 113 ls
bbc540racer is offline   Reply With Quote
Resources saved on this page: MySQL 1.11%
