VP CMP - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Racing Fuels
Old 02-20-2007, 04:57 PM   #1
swebb
Spooled up
swebb's Avatar
Default VP CMP
I had asked a question a while back about which fuel to use and I was told C12 or C14. Now I noticed recently more people are being recommended to use CMP. Is this a fuel I should consider??
Engine setup:
Naturally aspirated 347 SBF
Cylinder Heads: AFR 205cc (Milled to 55cc Chambers)
Vacuum Pump: Moroso 3 vane (~14 inches of vacuum)
Compression: ~13.75 - 14:1 C/R
Shift: ~ 7500
3000# race weight
Steve Webb
QuickLX.com
X275 - SBF 363, 88mm, A/A, 1.27 60', 5.36 @ 131.7 (3185lbs street car)
Special Thanks to:
Competition Components (Scott Brown)
Team Z Motorsports (Dave Zimmerman)
Hutch's Transmission Service (Hutch)
Monson Racing(Jim Monson)
Work Turbocharers (Reed Patridge)
swebb is offline   Reply With Quote
Old 02-21-2007, 12:37 PM   #2
Pooch565
Pooch565's Avatar
Default
If you want to run an oxygenated fuel, then CMP would be a great choice. It should give you 3 to 5 hundredths in the quarter over C12.
Jason
Jason Rueckert
Regional Manager
VP Racing Fuels -Midwest
812 878 2026
jason@vpracingfuels.com
Pooch565 is offline   Reply With Quote
Old 02-21-2007, 01:24 PM   #3
swebb
Spooled up
swebb's Avatar
Default
Are there any pros or con to running an oxygenated fuel?
Steve Webb
QuickLX.com
Special Thanks to:
Old 02-22-2007, 01:46 PM   #4
Pooch565
Pooch565's Avatar
Default
Pro's it makes more power. Cons it costs more. Thats about it.
Give me a call at 812 466 1175 if you want to chat.
Jason
Jason Rueckert
Regional Manager
812 878 2026
Old 02-22-2007, 07:00 PM   #5
MattG
MattG's Avatar
Default
At what compression ratio would it be advised to go from CMP to DRT?
MattG is offline   Reply With Quote
Old 02-25-2007, 11:34 PM   #6
Pooch565
Pooch565's Avatar
Default
It depends on CR, cubic inch and RPM. I would say to be safe, in a small block and high rpm, 8500 or so, 14 to 1 or higher go to DRT. If you were at 7500rpm I would say CMP. If you are a big block and 7500rpm, I'd say 13 to 1 or so go to DRT. Let me know if there is anything else you need.
Thanks,
Jason
Jason Rueckert
Regional Manager
812 878 2026
Old 02-26-2007, 07:44 PM   #7
MattG
MattG's Avatar
Default
Thanks for the info Jason!
Resources saved on this page: MySQL 2.27%
