LSX E85 PCV venting question - Yellow Bullet Forums
Old 11-24-2011, 09:49 AM   #1
cjg454ss
Default LSX E85 PCV venting question
424cu LSx, 106mm turbo, 20-25psi, 7000 rpm shift. blowthru CSU
i m not sure how much to vent, i couldnt get the moroso evac to work correcly, im thinking of:
2= -10 lines from Valve covers to catch can
1= -12 line from the valley cover to same catch can
Is that enough to vent?
cjg454ss is offline   Reply With Quote
Old 11-24-2011, 10:10 AM   #2
TDmkr496
Default Re: LSX E85 PCV venting question
My buddy was having problems blowing valve cover gaskets out with his LS3, we took the plate over the lifter valley and tapped a 1/2" npt hole in the plate into the factory breather box and ran an AN-10 line to a breather tank, no problems after that.
TDmkr496 is offline   Reply With Quote
Old 11-24-2011, 02:55 PM   #3
fast track performance
Your plan sounds like plenty to me.
Anthony Peck
Fast Track Performance
502-235-3024
www.fastrackperformance.com
Dyno on location-very flexable scheduling and rates
Red 99 ws6 Trans Am:
Coming soon:
03 cobra with a couple turbo's, 4l80e, driven daily and 5 second time slips
SOLD! Turbo LSx foxbody:
5.06@142
Turbo LSX Foxbody #2:
4.86@151 and 7.48@189
fast track performance is offline   Reply With Quote
Old 11-24-2011, 06:34 PM   #4
cjg454ss
ok, the reason for the 3 is i have all the hoses and fittings for the two -10s off the valve covers. i didnt think 2 -10s was enough so i figured a -12 in the valley would be best,
would 2 -10s off each valve cover be enought?i
Old 11-24-2011, 06:35 PM   #5
1985fiero
1985fiero's Avatar
curious as well, I am just going to run two -10 to seperate breathers....
2014 NMCA LSX World Street Finals True Street king
2015 Street Car Takeover Indy Fastest Street Racer Class
2015 NMCA LSX World Street Finals True Street king
1985fiero is offline   Reply With Quote
Old 11-24-2011, 08:14 PM   #6
AutomagicLS1
mightymouse uses 2 3/8" lines off each valve covers to a breather tank he actually builds his own that has a pressure relief valve built in the top. That car is making 1300+rwhp and he said he has no crankcase pressure issues with those 2 lines. So I would think 2 #10 lines would be way more than enough
1998 Camaro SS - FR8Train 2.0
1998 Pontiac Trans Am- FR8Train 1.0 (sold)
AutomagicLS1 is offline   Reply With Quote
Old 11-24-2011, 08:39 PM   #7
cjg454ss
3/8 is -6, i dont see two -6 vents getting rid of the crank case pressure. also i dont think that car makes 1300+rwhp.
Old 11-24-2011, 09:46 PM   #8
Shum
8.50' s @ 3700 lbs... It's makin over 1000 for sure.
TUNED BY BLUECAT
99 Z28- 347- Turbo - E85
Shum is offline   Reply With Quote
Old 11-25-2011, 12:31 AM   #9
AutomagicLS1
161 @ basically 3800lbs.
Here's what hes using
http://ls1tech.com/forums/15608548-post8.html
Old 11-25-2011, 09:55 AM   #10
o2camaross
Im taking the advice from a guy on my truck forum and he is making over 800 rwhp with his ls2 and twin setup. He told me -12 off each valve cover and he also suggested venting the valley cover, but for my build ~600 rwhp, im just doing the -12 fittings on each valve cover to a -12 T to one breather tank i bought from RPS. hopefully that will work, if it doesnt ill drill and tap the valley cover and put a -6 hose on there. Also 1st post woohoo!!
o2camaross is offline   Reply With Quote
Old 11-25-2011, 10:54 AM   #11
Shum
Better hit the newbie thread before the nazis attack you..
TUNED BY BLUECAT
Old 11-25-2011, 11:11 AM   #12
o2camaross
uh oh, ok ill do that, Thanks!
Old 11-26-2011, 06:26 PM   #13
f_o_a_d
f_o_a_d's Avatar
Having more than enough venting is never an issue. One one my cars has only a pair of -12 vent to a single catch can. One of the others has a pair of 1-1/4" vents to a pair of catch cans.
Not having enough venting will create many issues, leaking turbos, blown gaskets, or even worse. What happens is those small vents can't keep up and you push out a couple of quarts of oil under the tires at speed. Big vents are ok.
f_o_a_d is offline   Reply With Quote
Old 11-26-2011, 07:00 PM   #14
o2camaross
OK so I should be OK with a -12 off each valve cover T-ing into a single -12 to one catch can?
Old 11-26-2011, 07:07 PM   #15
PAT WS6
PAT WS6's Avatar
would like to know this as well, we are doing a NA 408 build now and im running just 1 -12 from one valve cover to a catch can. Will this be enough?
00' Red WS6 PT4788/370/TH400
99' White T/A N20/347/ TH400
PAT WS6 is offline   Reply With Quote
Resources saved on this page: MySQL 0.99%
