Rubber or solid motor mounts for TT car? - Yellow Bullet Forums
Old 11-25-2011, 11:36 PM   #1
Nobody.
Nobody.'s Avatar
Default Rubber or solid motor mounts for TT car?
When I put the motor in my '81 Corvette TT project, I used new replacement motor mounts but I've been thinking about going the solid route. This will be 90% streetcar. What are most using in this application? The motor is a 383 efi on E85 with twin 57mm BWs. I'm basically done except for fabbing the down pipes and completing the exhaust. So... solid or rubber motor mounts?
Nobody. is offline   Reply With Quote
Old 11-25-2011, 11:43 PM   #2
ssnova
ssnova's Avatar
Default Re: Rubber or solid motor mounts for TT car?
Solid for sure
ssnova is offline   Reply With Quote
Old 11-25-2011, 11:43 PM   #3
Wicked69
Wicked69's Avatar
I am using tall moroso solid big block motor mounts but I don't have it all together yet so can't really tell you. However, that is what was recommended to me. Solid engine mounts and a poly trans mount.
1969 Chevelle "Sinister"
5Sec LS
Check out my website www.splitmastertiming.com
Wicked69 is offline   Reply With Quote
Old 11-26-2011, 10:00 AM   #4
Nobody.
Nobody.'s Avatar
I'm leaning more toward the solid mounts now that I've seen a couple of YouTube videos and how turbo motors really torque up in these cars. I guess vibration isn't an issue?
Old 11-26-2011, 10:25 AM   #5
Solid mounts will cause vibration .
Old 11-26-2011, 10:53 AM   #6
Turbo 70 Camaro
Turbo 70 Camaro's Avatar
I am gonna attempt to keep my poly mounts and run engine limiters, hope it works out for me
70 Camaro RS 454 BB, 91mm, Fast efi, tial..................... in progress
Build video: http://www.youtube.com/watch?v=GKAzWDc0wKg
Build pics(slow)http://www.nastyz28.com/forum/showthread.php?t=187740
03 Dodge 3500 SRW 4x4(http://www.thecarlisuspension.com/do...ominator3.html)
Turbo 70 Camaro is offline   Reply With Quote
Old 11-26-2011, 11:28 AM   #7
71 Cam
71 Cam's Avatar
I run solid mounts with solid mount trans plate and poly tranny mount. Yeah there is some vibration but nothing major. Street/ strip 8.50 car.
71 Camaro, Andy Jensen 400ci SBC with Precision 67/66's , Th 400, 3.55 gear.
Best: 8.57@ 161. 3500lbs.
71 Cam is offline   Reply With Quote
Old 11-27-2011, 12:43 AM   #8
67turbogt
67turbogt's Avatar
solid motor mounts and poly trans. whats up
67turbogt is offline   Reply With Quote
Old 11-27-2011, 01:47 AM   #9
10secgoal
I've run rubber mount with an engine strap with good luck. Also poly engine mounts aren't bad either.
10secgoal is offline   Reply With Quote
Old 11-27-2011, 02:11 AM   #10
quick-silver
I use motor plates in my street strip setup and i dont think it vibrates/shakes very much at all.
Id go solid, rather live with a little annoying vib than breaking a mount
quick-silver is offline   Reply With Quote
Resources saved on this page: MySQL 2.15%
