Sorry, another rules question? - Page 4 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Racing Organizations > Ohio Valley Outlaw Shootout
Ohio Valley Outlaw Shootout Heads Up 1/8 Mile Drag Racing
Old 12-10-2009, 08:52 PM   #46
USAmade
Default Re: Sorry, another rules question?
Vern, Gerald, Art/Dave the All Motor rules are posted you guys coming up?
USAmade is offline   Reply With Quote
Old 12-10-2009, 09:06 PM   #47
GBoyd
Launchin
Give me time to make my mind up stiil looking for loop holes in the rules. If I can`t find an unfair advantage whats the point On a more serious not where are they posted?
GBoyd is offline   Reply With Quote
Old 12-10-2009, 09:24 PM   #48
inthe5s
inthe5s's Avatar
Quote:
Originally Posted by GBoyd View Post
.I did not say anything derogative about you in this post. Just stating that he does not know all that goes on so quit hating on me or I can bring out some direct quotes from you. So let sleeping dogs lay.
I did not say you did ..I said dont dunk me in the grease just as this post states you would do ... I am not hating on you just wish you realized I did nothing to cheat you and Robert .. I liked you up till you said I cheated you and its not you who was racing it was Robert as far as i know he did not say anything like that just you and I thought you and I was on good terms and you would know I would never do anything like that... apparently you know nothing about me as a person .. so I am not going to bother you about this any more Just want to clear the air with you on this so you know what I am thinking with out 3rd party he said she said BS .. I am sorry you have hard feelings toward me .. just hope we can race next year when we run into each other there is no friction and we can get along.. I Put on those races to have fun and promote 8.5 class not to cause any problems..
08 Outlaw 8.5 record Holder 5.36 @131.96
2008 8.5 champion
1,19 60' with GM stock TQ arm on 26x8.5 tire
5.21 @134.98 NA
VernHouseRaceCars.com
BES racing Engines
inthe5s is offline   Reply With Quote
Old 12-10-2009, 09:41 PM   #49
inthe5s
inthe5s's Avatar
Quote:
are these the rules
Liberty's Gears All Motor AM
1/4 Mile - .400 Pro Tree - 16 Car Qualified Field - Sportsman Ladder
Rules are subject to change. We will also review them after the third race.
Base Weights
Small Block minimum weight 2900 pounds
Big Block minimum weight 3300 pounds
Carburetors
Carburetors: Single carburetor allowed. Any modifications are allowed. No split carburetors allowed.
Fuel Injection: Electronic fuel injection is allowed. Single throttle body required
Intake Manifolds: Cast only (No sheet metal intakes), may be altered or modified
Mufflers: Mufflers are mandatory. No gutting allowed, they should be used as manufactured. Insert mufflers are not allowed. Collector mufflers are acceptable.
Lower Engine Containment Device Required
Oil Retention Device: Device may be custom-built ballistic blanket-style or metal-style (I.e., bucket) device. Metal pan may be no longer than the engine from the front of crank shaft to the rear of the flywheel. Pan must be inside the frame rails and fabricated to retain oil\liquid. Pan must attach to the frame via conventional fasteners or straps. Pan must be a minimum of 3 inches above ground.
Diapers: They do not have to be SFI rated.
Transmissions
Auto Transmissions: Any OEM American automatic transmission or a replica of an OEM American automatic transmission that uses planetary gears and torque converter permitted. Transmission-to-engine adapters are permitted. Trans brakes permitted. Automatic transmission entries run at listed base weights. Pneumatic, electric, hydraulic, etc. shifters prohibited. Any gear change must occur from direct action by the driver.
Manual Transmissions: OEM or aftermarket transmissions with a maximum of 5 forward speeds permitted. Clutchless models permitted. Any gear change must occur from direct action by the driver. Pneumatic, electric, hydraulic, etc. shifters prohibited. Vehicles using Clutchless manual transmission must add 125 lbs to listed base weight.
Front End: Stock frame rail from firewall forward required. Firewall to remain in the original location. Bolt-on replacement units allowed. This needs to be verified in tech that the bolt on factory mounting point are used with the bolts present.
Front Suspension: Any type of suspension is allowed
Rear Suspension
Stock Suspension: Deduct 25 pounds from base weight
Ladder Bar: Runs at base weight
4-Link: Add 75 pounds to base weight
Wheelie Bars: They are allowed. Maximum length is XX inches from the axle center line to wheelie bar wheel center line. NOT SURE ON WHICH STYLE YET
Add 50 pounds from base weight if using wheelie bars
Rear Tires
Slick Tires:Must be stamped 29.5 x 10.5 (No W's allowed) and will be measured with a go/no go gauge at 10.75". The "bigger" Hoosier 18192 and tires like it stamped 29.5 x 10.5 will still be allowed with a 25 pound weight penalty. Slicks that are 9" or narrower may be no taller than 30".
Drag Radials: These are the brands and sizes that are allowed
BFGoodrich Drag Radial 275/50/15, 275/60/15, 325/50/15
Mickey Thompson ET Street Radial 275/60/15, 275/50/15, 325/50/15
Nitto NT555R Drag Radial 275/50/15, 275/60/15
Body
Exterior:
Body panels can be replaced with factory appearing bolt-on replacements. No one piece front ends. OEM style forward facing hood scoop are allowed, Pro Stock style forward facing hood scoops are allowed, add 50 pounds to the base weight.
Glass: Lexan is allowed in the doors, side widows and the back
Interior: Stock appearing interior required, including two front seats.
MUST MEET ALL NHRA RULES INCLUDING LICENSE AND CERTIFICATION
2008 8.5 champion
5.21 @134.98 NA
BES racing Engines
Old 12-10-2009, 10:02 PM   #50
USAmade
That looks like them to me. Except the rules I read said guys named Vern had to add a 100lbs.LOL
Old 12-10-2009, 10:36 PM   #51
inthe5s
inthe5s's Avatar
if those are the rules I can run 5.20 to 5.22 with them rules in 1/8 I dont know if it would do that well in the 1/4 ....
2008 8.5 champion
5.21 @134.98 NA
BES racing Engines
Old 12-10-2009, 10:50 PM   #52
USAmade
They run 1/4 mile. You would probably be competitive, the fastest car usually didnt win before the wheelie bar addition, dont know what will happen now.
Old 12-10-2009, 11:29 PM   #53
USAmade
Do you know a good fab guy that could make you a set of wheelie bars? If so you would be right there with them. Heard Gary Rohe is good and treats ya right.
Just a little joke Vern to get a chuckle out of you and a few others.....
Old 12-12-2009, 02:47 AM   #54
R347GT
The Medcine Man
R347GT's Avatar
You call me a newbie? Mr. dick smoker I been a member longer than you! As for the past you idiot your the one that keeps bring it up. Get over it assclown. All you want to do is drop other people`s names in your post beause you have ZERO life in the racing world. Go find another chat room that you have somthing in common with the others in it like knitting or something. You started this a long time ago beeing a dick in a post to me and I still would not know who you are if I saw you. So go fixate an some other hero of yours besides me I am getting that creepy stalker feeling about you. What else have you checked about my profile? OMG I hope he doen`t know where I live. I must go now I feel a trip to the local gun shop is in order.
Soc cer:
R347GT is offline   Reply With Quote
Old 12-12-2009, 12:55 PM   #55
Kelly Leslie
Kelly Leslie's Avatar
I think that is why I put SORRY at the beginning because I knew it would get out of control.LOL It always does on this site.
LOL dont worry Darren. Im glad you asked, its always better to ask then guess. As for the drama, its easy to pick through the relative questions & answer versus the BS, no worries lol. Im pretty sure we all know whats up. It just stinks for the people reading the BS and not knowing whats going on.
On Point Image
www.onpointimage.com
Kelly Leslie is offline   Reply With Quote
Old 01-13-2010, 01:39 PM   #56
EnzoRacing
Spooled up
Can an Import run at these events?
i have an RX-7 and run 26 x 8.5" slicks. Car has run 5.7's but still hasn't been fully sorted yet.
Would be cool to race against some of you guys.
EnzoRacing is offline   Reply With Quote
Old 01-13-2010, 01:43 PM   #57
Kelly Leslie
Yes you can. Just check the rules to make sure you fit Would be great to get some more divertisy out there this year!
http://www.outlawstreetmadness.com/i...d=15&Itemid=28
On Point Image
Old 01-13-2010, 01:46 PM   #58
EnzoRacing
Spooled up
It'll fit if i follow the 4cyl weight rules..
Old 01-13-2010, 01:50 PM   #59
Kelly Leslie
Cool hope to see ya out then! Where would you be coming from?
On Point Image
Old 01-13-2010, 02:53 PM   #60
EnzoRacing
Spooled up
NY. I'll stop by for some of the events.
