Blower Carb question - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Supercharged - All Out Automotive
Old 11-07-2009, 10:00 AM   #1
DTPerformance
Pre-Staged
Default Blower Carb question
Im putting a BDS 671 blower on my BBC. I have had several Roots style blowers and always just put regular holly carbs on them and never really had an issue. My question is what is the differance with buying carbs "blower carbs" from like BDS ect from a reg holly on a roots blower?
Also what size carbs should I use. Its a 468, AFR 325 heads, jessel rockers, 8.5 to 1 stock block, blower cam motor and im going to put about 10-12 pounds on it (shooting for 700-800) and turn it no more than 65-6700
I have one brand new 950 HP and was wondering if I just got one more if that would be to much.
Thanks for any help
DTPerformance is offline   Reply With Quote
Old 01-14-2010, 02:48 AM   #2
hellafastcar
Burnout box
hellafastcar's Avatar
Default Re: Blower Carb question
My BG 750 blower carbs are boost referenced. I pick up boost off the boost gauge line, ran to each carbs base plate on the primary side. There are no PV's on the secondary side, and I run 75 pri jets/85 secondaries.
I made three passes in a blown SBC, hotlapping, without the boost line plumbed, third run I ruined the engine, detonation, lean, aggressive timing.
I've heard people say boost referencing is a myth. BG tech says different.
hellafastcar is offline   Reply With Quote
Old 01-14-2010, 11:57 AM   #3
SHAWN DAVIS
SHAWN DAVIS's Avatar
I never boost reference mine, just plug the power valves, and up the jetting approx 10% over stock jetting, maybe some more squirter, never had any problems. Probably done 10 or 14 motors.I dont like adding additional lines with the boost reference.
Hard to over carb a roots, I'd run the 950's
SHAWN DAVIS is offline   Reply With Quote
Old 01-14-2010, 01:30 PM   #4
OLDHEAD
After over a hundred pulls the stock 3310 vacuum opening carbs are very good with .035 shooters and converted to secondary #78 jets,Holley supercharge carbs are REAL rich and are very low on power. I have tried 950 hp's and they were good on a all out SBC-421...I have tried Boost ref. power valves and have found they open to early and at 10% overdrive they don't ever close...Oldhead
Drive everywhere,Blown8.92 at 150,3570#With nitrousmuch faster
OLDHEAD is offline   Reply With Quote
Old 01-14-2010, 04:15 PM   #5
BigB
Member
Pullin gears
BigB's Avatar
I did like Shawn said , just plugged the power valves and stepped the carbs up 10 jet sizes. Fired the motor up and glowed the headers bright orange inside of 30 seconds. Stepped the carbs up 10 more jet sizes and found a good starting point. I didnt even know about boost referencing and since I learned about it I have not run the motor.
BigB is offline   Reply With Quote
Old 01-15-2010, 08:16 PM   #6
72much
Launchin
72much's Avatar
Garage
I found out years ago when I was running a roots a carb is like a governor to the blower. The bigger the carb the better the blower breaths and the more efficient the blower is. Block off the PVs and jet up.
X2
http://www.cardomain.com/ride/763439
http://www.youtube.com/watch?v=i_2KlG2mkmk
http://www.youtube.com/watch?v=aJduCg3jWKs&feature=plcp
sbc 357 on E85 - CSUs
F1R ft braking / 3625lbs with driver
5.73 @122.45 mph in street tune
72much is offline   Reply With Quote
Old 01-16-2010, 10:45 AM   #7
2 Windows
2 Windows's Avatar
Garage
Ok, after reading this, I have questions.
I'm about to build a 496, 8.75:1, aluminium square ports with a 6-71 Weiand.
While looking for a pair of carbs, I came across a freshly rebuilt set of blower calibrated Holley 850 double pumpers for a really good price, so I scooped them up.
This is for a street driven car, but of course, I want all the power it can make.
Is there a downfall to the blower calibrated carbs, or is there something that I need to do, to use them effectively?
Thanks in advance.
208.6 mph/Texas Mile.
1635cc Hayabusa, all motor. 10/24/10
Click linky>>> http://smg.photobucket.com/albums/v1...20Race%20cars/
2 Windows is offline   Reply With Quote
Old 01-16-2010, 12:37 PM   #8
WJ Birmingham
WJ Birmingham's Avatar
Thanks in advance.
In your case, the carbs won't be the limiting power maker, the blower will.
Rather than accepting things you can't change; change the things you can't accept.
WJ Birmingham is offline   Reply With Quote
Old 01-17-2010, 09:23 PM   #9
DTPerformance
Pre-Staged
Thanks for all the advice and replies.
Resources saved on this page: MySQL 2.27%
