The Baddest 468 BBC on earth!! - Yellow Bullet Forums
Old 10-21-2009, 01:10 AM   #1
Bolt
Bolt's Avatar
Default The Baddest 468 BBC on earth!!
Who has built the baddest 468 BBC. Everyone is building 600 cube engines now. Back in the day there were some Bad to the Bone 468 running around. I am old school and was wondering if anyone cared to share there engine combo and HP.
Bolt is offline   Reply With Quote
Old 10-21-2009, 02:22 AM   #2
JUNKMAN1
JUNKMAN1's Avatar
Default Re: The Baddest 468 BBC on earth!!
I am working on one now hoping to get 1400 HP with nitrous.
JUNKMAN1 is offline   Reply With Quote
Old 10-21-2009, 02:23 AM   #3
draggingto
yep its a BBC !!!!!
draggingto's Avatar
not a 468, but got a 475 in the nova, what do you want to know? it makes around 1300hp on the jugg
draggingto is offline   Reply With Quote
Old 10-21-2009, 06:57 AM   #4
limitedstreet.com
Member
Pullin gears
If you dont mind sharing, what kind of piston, rod, crank combination are you running? I assume standard rod, standard crank, and a .60 over piston. What compression are you running and what heads? Thats alot of ponies from a 468. I would love to make that with the one that im building. I got steel 990 heads, with about 12.5:1 pistons. I dont think I will be anywhere near yalls numbers.
limitedstreet.com is offline   Reply With Quote
Old 10-21-2009, 07:18 AM   #5
jlo
jlo's Avatar
We have a 468 cid combo that makes 853hp on motor, so far its been 9:60s on power @3500lbs on a TT5 tire. Factory block, factory steel crank, eagle H beam rods, custom J&E Pistons, BMF heads, full roller valve train, Holley tunnel ram with (2 ) 4150 carbs.
jlo is offline   Reply With Quote
Old 10-21-2009, 07:40 AM   #6
SprintRacer
Spooled up
SprintRacer's Avatar
9.10 at 147 mph all motor, no nitrous, in 2800 pound car. 468 with Methanol quick fuel carb 1050, Dart 320 Race Heads, Edelbrock 454R intake, standard deck cast block
SprintRacer is offline   Reply With Quote
Old 10-21-2009, 07:58 AM   #7
excelerater
Senior Frog
excelerater's Avatar
468BBC Y BOTHER LOL
excelerater is offline   Reply With Quote
Old 10-21-2009, 08:33 AM   #8
gryphon68
gryphon68's Avatar
1300-1400hp is really punishing a stock block, if you are using a goood aftermarket block why would you limit yourself to 468 ci?
Beebe Motorsports
gryphon68 is offline   Reply With Quote
Old 10-21-2009, 08:34 AM   #9
chevyxpress
Burnout box
Had a 468 in my 62 Nova. 2900 lbs, glide, went 8.22@168mph. 325 dart heads, worked over, .250 long rod, scat crank, 14:1 compression, 300 shot nos on single 4 barrell.
chevyxpress is offline   Reply With Quote
Old 10-21-2009, 08:42 AM   #10
hiway
hiway's Avatar
Factory steel crank, Eagle stock length rods, 12.5 SRP's, 305 Canfield with work, big roller, Brodix intake, 1000hp 4150 carb. No numbers yet....and a BigShot plate
Just your average Arkansas street machine
MidsouthRacers.com
hiway is offline   Reply With Quote
Old 10-21-2009, 08:42 AM   #11
79540
KEVIN CAPS LOCK
79540's Avatar
Quote:
YEP!
79540 is offline   Reply With Quote
Old 10-21-2009, 09:16 AM   #12
smallblk77
I like to party!!
smallblk77's Avatar
Thats the question, aftermarket block why no go bigger?
Here for the and
smallblk77 is offline   Reply With Quote
Old 10-21-2009, 09:25 AM   #13
levers
levers's Avatar
468 2 bolt block gm crank 7/16 gm rods trw replacement ls7 pistons 1 kit 1 carb 8.90 153mph @ 3800lbs, motor lived for ever
levers is offline   Reply With Quote
Old 10-21-2009, 09:39 AM   #14
nosbill
Spooled up
468,stock block,stock crank,.250 long grp rods, weisco 13.2 pistons dart pro 1 335's, .714 roller, 1050 carb, 3550lb car with fogger and plate- 8.40's @ 160
www.scrivenerperformance.com
team ctboys grudge racing
nosbill is offline   Reply With Quote
Old 10-21-2009, 09:44 AM   #15
71Monte
PowdercoatBill
71Monte's Avatar
My old 462 stock block, eagle rods, stock steel crank, dart 310's .714 solid rioller, and a 1050 Dominator went 9.50's consistantly with a best of 9.47 @ 142 on a 175 shot in my 4000 lb tank!
71Monte is offline   Reply With Quote
