Strange axles. - Yellow Bullet Forums
Old 10-20-2009, 06:23 PM   #1
randyrw
randyrw's Avatar
Default Strange axles.
Has anyone delt with the bs warranty. They say they only warranty broke axles. If your axles are twisted they say run them until they break. So who pays for a wrecked car when those bitch's break at 100+mph. All they could say is send them in and they may or may not warranty them. WTF!!
www.leashelectronics.com Boost Leash, Pulse Leash push button staging system, Nitrous timers, wiring boards, ect...
http://sherwood-performance.smugmug.com
2000 Mustang 509BBC twin 88's Radial SHOP CAR best 4.43@175 1.19 60ft 3.02 330ft ON 275 RADIALS!! http://youtu.be/eVOGMDLzv2U
Check out my Boost Leash video http://youtu.be/4ZyLtsWalMY
randyrw is offline   Reply With Quote
Old 10-20-2009, 06:26 PM   #2
Berryracer
Launchin
Berryracer's Avatar
Default Re: Strange axles.
I don't know how they warranty their axles, but I sure have seen them with twisted splines more than once. Bummer
Berryracer is offline   Reply With Quote
Old 10-20-2009, 06:35 PM   #3
sleeper409
sleeper409's Avatar
Strange has always been like that. They told a friend of mine to be twisted 5 or 6 spline was normal!!
SHOW CARS ARE FOR PUSSIES
sleeper409 is offline   Reply With Quote
Old 10-20-2009, 06:38 PM   #4
BRIANS02TA
Member
Pullin gears
BRIANS02TA's Avatar
Quote:
i have a buddy that twisted some 40 splines and they told him the same. that was normal... b/s i say
head floor sweaper at sherwood performance.
68 chevelle
BRIANS02TA is offline   Reply With Quote
Old 10-20-2009, 06:39 PM   #5
BAD INT
BAD INT's Avatar
swap sides and fixem yourself. I know they allow foor so much twist but didnt know when warranty kicked in or replacement was warranted
BAD INT is offline   Reply With Quote
Old 10-20-2009, 06:40 PM   #6
quick331coupe
Launchin
quick331coupe's Avatar
Yes, there warranty is questionable but when is the last time you heard of someone breaking a strange axle? I sent mine in last winter from one of my old cars, they were twisted almost 2 splines. The told me, we don't harden our axles to the hardest, like some other company's do (Mark Williams is who they used as an expample). When our axles twist, they get harder, so three splines of twist is usual. If you take an axle out and it has more than that, then its about time to replace it. The other company's will show no sign of being weak, they will just break. Thats the explanation I got from them. I have yet to break one, so I believe them.
quick331coupe is offline   Reply With Quote
Old 10-20-2009, 07:12 PM   #7
randyrw
randyrw's Avatar
I would just have a hard time sleeping at night knowing my axles are twisted to shit. I could probably live with a long gradual twist. But when the splines make a 45 degree sharp twist it's just unacceptable. I would think that they could do alittle engineering to prevent that. Naturally the spline area is the weakest point cause cutting the spline basicaly decreases the root diameter of the axle. i think if the long part of the axle was the same diameter as the inside root diameter of the spline area then that would seem to stop the severe twisting. Just thinking out loud.
Old 10-20-2009, 07:14 PM   #8
SHAWN DAVIS
SHAWN DAVIS's Avatar
Plain and simple, if you twist a strange axle then you need a bigger axle
SHAWN DAVIS is offline   Reply With Quote
Old 10-20-2009, 07:22 PM   #9
Tom Cowle's wife
Tom Cowle's wife's Avatar
Sounds like a call to MARK WILLIAMS is in your future.
Tom Cowle's wife is offline   Reply With Quote
Old 10-20-2009, 08:17 PM   #10
Imlow78
Head Phuckstick
Imlow78's Avatar
Quote:
x2
Thats why you pay the extra $$$ for Mark Williams! I know it sucks when you get the price, I've been down that road! Good luck man and I hope Strange does the right thing for you!
Shannon
"Native Americans be aware of foreign influence"
Imlow78 is online now   Reply With Quote
Old 10-20-2009, 08:29 PM   #11
nohook
nohook's Avatar
Quote:
psssssssssssssssstttttttttttttttt i'm on my third set !....since 1982 !(35 spline solids too )
nohook is offline   Reply With Quote
Old 10-20-2009, 08:38 PM   #12
streetrace1
streetrace1's Avatar
I snapped one in georgia nmca 07 right at the bottom of splines,clean in half, they gave me a new one but only after i sent in the broken one.
streetrace1 is offline   Reply With Quote
Old 10-20-2009, 08:39 PM   #13
Tony Christian
Launchin
Tony Christian's Avatar
Theres no way Strange would tell you that....What spline axles do you have?? Let me know..I will talk to them and either get them to warranty them (unless there old old 35 spline stuff and you need 40's} but either way you will be happy.....I've never had a problem with Strange. (nor has Warren or Kurt or Greg anderson) give me your phone no. Tony Christian
Tony Christian is offline   Reply With Quote
Old 10-20-2009, 08:52 PM   #14
randyrw
randyrw's Avatar
Quote:
These are in a drag radial car that has around 50 passes. They're 35 spline bought new through Chassis Works in Feb 09. Car wasnt track ready till June 09. Car has only been the best of a 1.28 60ft. I called Strange today and talked to a lady and she said if there not twisted by 4-5 splines then they usually don't warranty them. Said if there not more than 2 splines of twist then don't bother sending them in. There OK!! We're gonna send them and see what they say.
Old 10-20-2009, 08:56 PM   #15
WIKDLX
WIKDLX's Avatar
just swapped my strange axles(had over .020 runout on the flange) for some Moser's in my street car
WIKDLX is offline   Reply With Quote
