All Motor Rules for 2010????? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Racing Organizations > Milan's Heads-up Shootout - Videos -News - Interviews
Old 10-20-2009, 03:34 PM   #1
Mike Konigshofer
Pre-Staged
Mike Konigshofer's Avatar
Default All Motor Rules for 2010?????
Anything gonna change??????
Mike Konigshofer
OTPC CNC Machining
(519)718-0545
8.117@173.15
NMCA N.A 10.5 - 397" SBF
5 Speed Liberty
2860 lbs
Mike Konigshofer is offline   Reply With Quote
Old 10-21-2009, 08:38 AM   #2
j russell
j russell's Avatar
Default Re: All Motor Rules for 2010?????
i hope weight break for stock suspenion powerglide..and a red firebirds
1998 trans am
Thanks u.t.p (Brian Hable)
powerglide service Budd
racetech engine & dyno service
QC coatings
Crooked creek farm and dairy
the wifey Jenny & kids
tomas&shannon
people that drink our milk
TCI
Chet@ CRE performance
BK
X275
j russell is offline   Reply With Quote
Old 10-22-2009, 12:05 AM   #3
Ben Mens
Ben Mens's Avatar
Quote:
How about on your end?
Lucas Oil Products / Dart / Total Seal Piston Rings / Trick Titanium / Wiseco Pistons / Scott Rod Fabrications / Motorcity Solutions / Mike's Garage
Ben Mens is offline   Reply With Quote
Old 10-22-2009, 12:39 AM   #4
mayhem
mayhem's Avatar
Baxter posted "Suggestions Wanted" on the Milan site.
I submitted the following:
1. Add Wheelie Bars - weight penalty
2. Tunnel Rams - add weight penalty (the "cast intake" is being abused IMO)
3. Modify Tire Section to read something like the following:
29.5x10.5 maximum (no w's)
30x9 Allowed
Define a tire size for Drag Radials, rather than state "equilvilant" (like 275/60 and 315/60 only allowed)
But I am just a spectator...LOL
mayhem is offline   Reply With Quote
Old 10-22-2009, 08:14 AM   #5
Mike Konigshofer
Pre-Staged
Quote:
Not sure yet????
I want to run NMRA/NMCA but we tore up lot of stuff from wheelstands...it doesn't look like they will ever allow wheelie bars so i will need more testing to figure stuff out.
Just hoping Milan will adapt a wheelie bar rule so I can run there next year. It's close and a great series.
Right now... Looks like OSCA Pro Stock and 3 or 4 Ram races.
But I may see you @ Bradenton
Mike Konigshofer
OTPC CNC Machining
(519)718-0545
8.117@173.15
5 Speed Liberty
2860 lbs
Old 10-22-2009, 10:39 AM   #6
gryphon68
gryphon68's Avatar
30x9 Allowed
315/60 D/R's in All motor? I would think the 295/65 would be a closer match. Even then, I would think most guys with an automatic trans end up on the radial by the end of the season.
Beebe Motorsports
gryphon68 is offline   Reply With Quote
Old 10-22-2009, 03:28 PM   #7
david2
david2's Avatar
How about a weight break for Conventional Heads
Jim-Powski Racecraft
Uratchko Racing Engines
Proformance Racing Transmissions
Marcella Manifolds
Slick Rick Racing Heads
www.ultimateconverter.com
www.centraltruckrepair.com
david2 is offline   Reply With Quote
Old 10-22-2009, 03:53 PM   #8
mayhem
mayhem's Avatar
Quote:
Right now it says "or equivilant Drag Radial".......I'm just saying ....define it, that way there is not controversy.
Old 10-22-2009, 04:03 PM   #9
mayhem
mayhem's Avatar
I misquoted the current rules..... Here is how its worded today.
"Maximum Tire 29.5 x 10.5 (NO W's allowed) Drag Radials are OK they must not be larger than spec slick"
The bolded part is what I think needs to be defined (ie. tire size)
Old 10-22-2009, 04:22 PM   #10
gryphon68
gryphon68's Avatar
Yes, it would be a good clarification, but what would it say? If you go by M/T specs the 295/65 is 30x10.9(tread), which would not be legal by the existing wording IMO.
The next largest tire is a 275/60 (28x9.5 at the tread) which is probably not going to win to many converts compared to a 29.5" slick.
So the question is, should a 295/65 be legal in A/M???
Beebe Motorsports
Old 10-22-2009, 04:54 PM   #11
Ben Mens
Ben Mens's Avatar
If you make the MAXIMUM tire size somewhat generic, that is a size that will capture ALL of the tires you want in the class and keeps the racers from either being excluded by a technicality i.e. 9 x 30. Something like this seems to work ok? :
TIRES–REAR: Street type or racing slicks required. Maximum actual measured tire size is as follows: Actual measured tread of tire is limited to 10.75 inches by 30.5 inches tall. Tire width will be measured by a “go-no go” gauge. Tire width and height will be measured after conclusion of run at scale area. Tire tread may not extend outside fenders.
5.1a) The following radial tires are acceptable for use in Pro Stock:
• BFGoodrich Drag Radial 275/50/15, 275/60/15, 325/50/15
• Mickey Thompson ET Street Radial 275/60/15, 275/50/15, 325/50/15
• Nitto NT555R Drag Radial 275/50/15, 275/60/15
The 295/65/15 & 315/60/15 are prohibited tire sizes.
Old 10-22-2009, 04:59 PM   #12
Ben Mens
Ben Mens's Avatar
Not sure yet????
I was referring to your OSCA rules about sponsor decals on the windows only! You may or may not see me at Bradenton, what you gonna run..........?
Old 10-22-2009, 05:27 PM   #13
Chris Uratchko
Moderator
Chris Uratchko's Avatar
I say no weight penalties for anything.
Wheelie bars = free
Sheetmetal intakes = free
4 links = free
Forward scoops = free
Cast intakes? Stupid rule for pretty much an outlaw class. That stuff costs more money than a sheet intake... sheetmetal intake, let her eat.
This class cannot be policed with major engine rules, major chassis rules.... and it will pretty much screw up a good thing by injecting a few strict rules on top of an outlaw class.
LET HER EAT. You have a small block and a big block within a few hundys.... If you can't keep up, WORK ON IT. I'll be working hard next year on my junk.... and it will be an underdog.
Chris Uratchko is offline   Reply With Quote
Old 10-22-2009, 05:45 PM   #14
Ben Mens
Ben Mens's Avatar
Don't you come out on this subject every year about this time?
Old 10-22-2009, 06:16 PM   #15
Chris Uratchko
Moderator
Yeah yeah...
