3.20 pro gear for a 9" - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Rearends and Differentials - Mark Williams Enterprises
Old 10-12-2009, 05:35 PM   #1
MEAN_SBC
TURBOBULLET.COM BITCHES!
MEAN_SBC's Avatar
Default 3.20 pro gear for a 9"
anyone make one??? My car currenlty had a Nodular Iron case with Moser 40 spline axles with a 4.10 pro gear... I need a 3.20ish gear.. What to do, and what will I need???
I'm not to savvy on the 9" stuff...
Brant Campbell
Worlds Fastest MPH Car on 275's
6.92@212.09
2011 PSCA XDR/TT5 Champion
2011 PSCA Sin City Shootout Champion
Thanks To The Following:
MEAN_SBC is offline   Reply With Quote
Old 10-13-2009, 09:21 AM   #2
Scott @ DLS
Member
Pullin gears
Scott @ DLS's Avatar
Default Re: 3.20 pro gear for a 9"
There was a 3.40 available awhile back but it is no longer in production. The 3.50 is on back order till next month.
Scott @ DLS
Scott @ DLS is offline   Reply With Quote
Old 10-13-2009, 09:40 AM   #3
86merc
Launchin
86merc's Avatar
Subscribing.
I couldn't find one when I looked earlier this year. The guy at Strange actually laughed at me when I inquired about one. I explained how a gear in that range is very helpful for the guys who are limited to a 28" tall tire. Especially with the 275 drag radial classes showing up every where now. He just kept laughing.
Mike
I race my street car.
86merc is offline   Reply With Quote
Old 10-13-2009, 10:19 AM   #4
Pro Stock John
Pro Stock John's Avatar
Scott weren't there oddball size Nascar gears?
LSX RECORD LIST
RaceStar, Billet Specialties Dealer
Pro Stock John is offline   Reply With Quote
Old 10-13-2009, 11:47 AM   #5
Scott @ DLS
Member
Pullin gears
Quote:
Nope, special production run. If you have something drawn up you can have a 200 piece run of that gear ratio. Tom Reider was very good at this but he is no longer in business. The only answer at this time is to have a street gear annealed to attain the gear ratio desired. We do offer this process as well.
Scott @ DLS
Old 10-13-2009, 12:30 PM   #6
gryphon68
gryphon68's Avatar
Scott, how much does it cost to have a single gearset annealed?
I would imagine it would be more cost effective to put several in the oven at once. Do they use a static oven or a conveyer system? If it is a static oven how many gearsets can be cooked at once??
Beebe Motorsports
gryphon68 is offline   Reply With Quote
Old 10-13-2009, 12:38 PM   #7
Scott @ DLS
Member
Pullin gears
PM sent,
I haven't done any batch runs and I'm not sure on which process is used. I know the gear set is at about 60 rockwell and it is softened 5-8 points on the rockwell scale. I verify each set myself and they do vary some.
Scott @ DLS
Old 10-13-2009, 12:39 PM   #8
Sam Vincent
Sam Vincent's Avatar
I know I have a 3.40, thought they made a 3.20 too. Try calling Mark Williams, might have one
sponsors:
Nitrous Express, Diamond, JESEL, Marcella Manifolds, M/T, VP racing fuel, GRP, Bullet Cams, RacePak, Leashed Elect, ATI performance
Vincent Performance
Graham KY
270-977-1893
Dealer:
Diamond, Trend, TotalSeal, BulletCams, Morel, Jesel, Brodix, Moroso, Manton, GRP, Callies, PSI~PAC, Stef's, Nitrous Express, TrickFlow, TotalEngineAirflow, PTC converters, William's Perf, ProLite batt, UltraPro Machine, Danny Bee, ATI Perf, MOSER Engineering, Sonnax Industries, PST shafts...
Sam Vincent is offline   Reply With Quote
Old 10-13-2009, 12:58 PM   #9
DLW
Spooled up
DLW's Avatar
You can still get a 3.40 pro gear from Mark Williams in a large pin..
DLW is offline   Reply With Quote
Old 10-13-2009, 01:32 PM   #10
Uncle Paul
Uncle Paul's Avatar
Unless I am way off, a Pro set of gears is usually made from 9310 steel and a standard set from 8620. Both are carburizing grades but have different mechanical properities. Tempering a standard set back (not annealing) will increase the core toughness but will sacrifice surface hardness.
I'm your Huckleberry,,,,
http://www.northernchateau.com/
Uncle Paul is offline   Reply With Quote
Old 10-19-2009, 12:19 AM   #11
Capt Crash
Launchin
Capt Crash's Avatar
Garage
Try calling Cal Gear (Chrisman Driveline). I know that he had some a few years ago. Also I believe that there should be a 2.90 gear available for the A-fuel guys if that will work. I do have a new set of 3.20 9 1/2" gears with a 40 spline pinion with a MW pinion support $450.00 plus shipping if anyone is interested.
Brian
970-274-0843
ccrower@netzero.net
Capt Crash is offline   Reply With Quote
Old 10-19-2009, 01:03 AM   #12
LIMITED STREET CORVETTE
OTTA RULES
Pullin gears
LIMITED STREET CORVETTE's Avatar
I HAVE 3.40 S IM BOUT TO USE
LIMITED STREET CORVETTE is offline   Reply With Quote
Resources saved on this page: MySQL 1.02%
