BUILDS: - Page 24 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > LSX, Mod Motor and Gen III Hemi Tech
Old 10-22-2010, 04:09 PM   #346
Preacher's Kid
Preacher's Kid's Avatar
Default Re: BUILDS:
very cool color nutcase, it's got so many dimensions. i like paints that have different personalities.
Matt
9.974@135.55 All Motor
"Like" MotorManiaTV on Facebook!
Check out my videos!
Preacher's Kid is offline   Reply With Quote
Old 10-22-2010, 11:18 PM   #347
ericg69ss
Default Re: BUILDS:
Quote:
Originally Posted by Shum View Post
PH8A.... Isn't that a SBF oil filter?
Looks great guys!
LOL, I looked at that and you are right. Pretty funny.
ericg69ss is offline   Reply With Quote
Old 10-31-2010, 12:05 PM   #348
2000z28
Burnout box
Default LS1 In a Dodge Ram
The truck used to have a big block 440 in it, it was fun and seemed like a tq monster, but the mpgs just weren't there and it was hard to make a smog era motor run good, I think it was a 8.1 compression motor with a .420 lift cam from the factory
2000z28 is offline   Reply With Quote
Old 10-31-2010, 12:09 PM   #349
2000z28
Burnout box
Default Re: LS1 In a Dodge Ram
Since I bought my 2000 z28 in 2006 it have been nothing but impressive, runs low 10's and gets 22 mpgs driving 60 miles to the track.
I swapped the 78 440/np203/727 for a ls1 with a 4l60e and a np208.
The 440 ran a 15.7 @ 84,(9mpg) the ls1 has run a best time of 14.0 @ 94 getting 18mpgs, also the truck is now 540lbs lighter, sounds good, but now the suspention is really bumpy, still need to take some leaf springs out to soften it up a bit.
Old 10-31-2010, 12:10 PM   #350
2000z28
Burnout box
Old 10-31-2010, 12:11 PM   #351
2000z28
Burnout box
Old 10-31-2010, 12:13 PM   #352
2000z28
Burnout box
It took a little while to get all the mounts and transmission lined out, but once it all lined up the LS1 was at home
Old 10-31-2010, 12:13 PM   #353
2000z28
Burnout box
Old 10-31-2010, 12:17 PM   #354
2000z28
Burnout box
The Ls1 is a completely stock 98 model with a corvette "batwing" style oil pan. I found a good deal on some stainless steel headers, ported the throttle body, and rebuild a 4l60e I bought from a guy who had it in a 700hp twin turbo camaro. The 3-4 clutch pack was smoked, and the 2-4 band was missing, a simple rebuild kit and a 4wd output shaft made it ready for the np208 transfer case
Old 10-31-2010, 12:19 PM   #355
2000z28
Burnout box
I did a few things to the 4l60e....beast sunshell, borgwarner dual cage sprag, hd pump slide springe with sonnax boost valve for the pump, stiffer 1-2 acc. spring, drilled 2nd and 3rd gear feed holes to .093. This made for a very quick shifting transmission, but not to hard to where its going to break parts.
Old 10-31-2010, 12:21 PM   #356
2000z28
Burnout box
Old 10-31-2010, 12:22 PM   #357
2000z28
Burnout box
Old 10-31-2010, 12:23 PM   #358
2000z28
Burnout box
Old 10-31-2010, 12:25 PM   #359
2000z28
Burnout box
These pics are in no specific order, just a few of the build along the way
Old 10-31-2010, 12:26 PM   #360
2000z28
Burnout box
Resources saved on this page: MySQL 2.06%
