BUILDS: - Page 10 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > LSX, Mod Motor and Gen III Hemi Tech
Old 01-26-2010, 08:34 PM   #136
ericg69ss
Default Re: BUILDS:
So I got bored and decided to get my 1969 Camaro running again. I've had the car since I was 18 and it still has the first motor I built with my dad. Anyhow, its been 10.80's @ 3450lbs all day long with a true 350 SBC naturally aspirated. Unfortunately, we don't have the time to build motors anymore so I asked Kurt Urban to build another motor for me and going to redo the suspension with parts from Alston Chassisworks. I'm building the car so I can drive it on the street and run a Limited 10.5 class. This car will be running well before my Trans Am is done so the race season won't be entirely lost.
Details below and pictures of the car with the old setup and prior to painting it GM Electron Blue:
Engine:
410" GMPP LSX Iron Block w/ Procharger F1C
Callies Magnum Crankshaft
Howards 6.125 Rods
Diamond Pistons
All Pro 244cc Cathedral Heads
Hydraulic Roller Cam
Jesel 1.7 Mohawk Rockers
GMPP Single Plan Manifold with Elbow and 90MM TB
Trans and Converter:
ATI TH400 rebuilt by Steve Casner
10" 4200 Converter
Chassis and Suspension:
Alston Front Clip, A Arms, Double Adjustable Varishocks
Alston FAB 9", Strange 35 Spline Axles, Calvert Split Mono Leafs, Double Adjustable Varishocks
Cage cert'd to 8.50's... don't think we'll go faster than that...
Also going to run a FAST XFI standalone for LS1 and coil on plug set up.
ericg69ss is offline   Reply With Quote
Old 01-26-2010, 11:34 PM   #137
camscam02
Member
Pullin gears
camscam02's Avatar
Default Re: BUILDS:
hey eric, I would check the rules for limited 10.5, you can only run a 80mm tb max and have to run the stock pcm setup as far as I remember. That is the only 2 questions that were brought up in my mind when I read that.
Seems like an awesome build. Can't wait to see this one either.
R&E Racing 275 LSX Mustang Crew Chief
1/8 Mile Best: 4.24 @ 173 MPH
1/4 Mile Best: 6.82 @ 204 MPH NMCA SO Legal
2015 NMCA East Street Outlaw Champion
2014 NMCA West Street Outlaw Champion
2014 WCHRA 275 Drag Radial Champion
2014 SCSN Wild Street Champion
**Westcoast Doesn't Count**
Like Us: https://www.facebook.com/RandERacing
camscam02 is offline   Reply With Quote
Old 01-28-2010, 07:54 PM   #138
Greenturbo
Burnout box
Default Re: BUILDS:
Engine:
Howards 6.125 Rods
Diamond Pistons
10" 4200 Converter
thats a pretty cool shot!
Greenturbo is offline   Reply With Quote
Old 01-28-2010, 07:59 PM   #139
ericg69ss
Default Re: BUILDS:
Quote:
Thanks! That picture was taken at my office about 6 years ago. We were testing out the transbrake on our concrete launch pad. If we hook there (which we did)... we can hook almost anywhere.
Old 01-28-2010, 10:55 PM   #140
qwiknotch
ProStock Jackstand Winner
qwiknotch's Avatar
Default Re: BUILDS:
Here is the latest interior pics of my car.... Just need to wire it and plumb the fuel system and the car itself will be done... Still waiting on the flywheel and some new engine pieces... first race is March 27,28..
qwiknotch is offline   Reply With Quote
Old 02-06-2010, 05:56 PM   #141
niceguy
niceguy's Avatar
Default Re: Another "my build" thread
Quote:
Originally Posted by niceguy View Post
Saw the other one and thought I'd go ahead and put mine up as well, so I can thank some people who are helping me. Here goes, lemme know what you guys think. This is going to be a mostly street/very little strip car, but should still haul the mail.
2000 Trans Am
HKE 429ci LS3; 11.6 comp
custom HKE cam (not sure on specs, but is pretty big for hyd roller... close to .700 lift, dur. unknown)
Dart heads (full overhaul by Ricky at NRC, 2.100 intakes, 1.6 exhaust, hollow stem stuff)
1.8 Yella Terras light weight rockers
Edelbrock Super Vic (minor port work)
FAST 4150 tb
42lb injectors (G-Force)
2" Kooks with 3" exhaust and dumps (exhaust will be my own design and build)
MSD coils/wires and relocation kit
T-400 fmrvb with t-brake
PTC 8" 5k converter
Moser 12-bolt, narrowed 6"
33 spl axles/Eaton posi (for now)/TA cover
BMR adj torque arm, mounted on trans crossmember
CM Adj lower control arms (custom made by Westside Hotrods)
CM tubular frame connectors
BMR k-member, upper and lower CA's
manual rack, manual brakes (strange m/c)
Strange front/rear drag brakes (Blitzkrieg-Dennis)
Front and rear QA1's
BS Street Lites 3.5" fronts and 10" rears
325/50 Drag radials
Battery re-located to rear (my own design and build)
Dual 255 pumps in tank with -8 feed and stock return
And tuning will be done by G-Force in Pearland.
The car still has all the air conditioning stuff, as the wife's only demand was to keep that. Right now I am waiting on the heads, but they should be done sometime this week and the shortblock is already built. Should be able to have the car rolling by Mar 1st. I'll snap a few photos tonight.
Alright had to update the build, as it changed a little due to shortage of funds. Motor is almost done, should be dropping everything in within the next couple of weeks. Will update on the dyno numbers when finished, but here is a few pics of the roller. First time out of the garage since I got started the project.
the rear with 325's and my "sunshine" helper
Blown BBC 18' Hondo V-drive
2011 F150 Lariat
2013 Mustang GT 5.0L (Wife's ride)
Special thanks to my beautiful wife for her understanding of my obsession of modding everything we own!
niceguy is offline   Reply With Quote
Old 02-06-2010, 11:18 PM   #142
95silverstallion
95silverstallion's Avatar
Default Re: BUILDS:
Those v-banded manifolds I assume are a custom job? Are they 3" V-bands? How do they come stock, ball and socket?
1966 Chevrolet Caprice
<img src=http://www.yellowbullet.com/forum/image.php?u=1845&type=sigpic&dateline=1242753188 border=0 alt= />
95silverstallion is offline   Reply With Quote
Old 02-07-2010, 03:20 PM   #143
minytrker
LSX Power Tuning
minytrker's Avatar
Default Re: BUILDS:
After countless hrs and almost a year re-doing the car is finally done. Everything on the car is brand new again, for the last time. Its H&C forgged nitrous LS motor, glide, 9in, BMR suspension, Bogarts, 325/50/25.
minytrker is offline   Reply With Quote
Old 02-07-2010, 11:05 PM   #144
zssman
Launchin
zssman's Avatar
Default Re: BUILDS:
Quote:
Lookin good.
zssman is offline   Reply With Quote
Old 02-13-2010, 01:21 AM   #145
qwiknotch
qwiknotch's Avatar
Default Re: BUILDS:
got my Advanced Clutches flywheel today. This is #1 on his LS flywheels. He had never made one for an LS engine before.. This is part of his fully adjustable 10" clutch.
Billet aluminum, rebuildable and weighs less than 12lbs. I opted on the alum to kill the intertia and since I have an n/a deal and steep gears, I think it will work out well..
Old 02-15-2010, 08:08 PM   #146
tirefryin_s10
tirefryin_s10's Avatar
Default Re: BUILDS:
not much new on the car front around here.... too busy with customers stuff.
Made a little progress and started fitting the turbo kit..... I am not fancy fabricator but I think it looks ok for DIY crap.
Got the V band welded on the passenger side, You can see how much different the manifolds are based on where the passenger turbo kit is in relation to the hot side piping.
tirefryin_s10 is offline   Reply With Quote
Old 02-15-2010, 10:44 PM   #147
Billyman
out of work hair dresser
Billyman's Avatar
Default Re: BUILDS:
Badass looking piece.
*FYI--that is not where it goes.
Quote:
Originally Posted by Monty Mikho View Post
If you can't dazzle them with brilliance.. baffle them with bullshit
Quote:
Originally Posted by Plato
"Wise men talk because they have something to say; fools talk because they have to say something."
Billyman is offline   Reply With Quote
Old 02-17-2010, 02:26 AM   #148
qwiknotch
qwiknotch's Avatar
Default Re: BUILDS:
DAMMIT..
these damn LS engines have me all flustered, you sure it doesn't go there?... probably the safest place for it. LMAO
Old 02-18-2010, 12:31 PM   #149
tirefryin_s10
Default Re: BUILDS:
Did a little on the drivers side of the kit last night :
Got the v band all fitted and the flex welded in also changed the bends on the kit to try and match the other side a little better even being that the manifolds exit in different areas, Still gotta clean up and weld the bottom half as well as build a piece to bridge the gap.
Soon it will be time to clean it all up and coat/wrap it.
Old 02-19-2010, 12:51 AM   #150
tirefryin_s10
Default Re: BUILDS:
Got the drivers side welded up..... Now I just need to finish smoothing things out and coat/wrap this shit.
Also got my turbosmart Pro port BOV to match my turbosmart gates.
Resources saved on this page: MySQL 1.00%
