BUILDS: - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > LSX, Mod Motor and Gen III Hemi Tech
Old 10-11-2009, 05:18 PM   #1
LSWon02Z28
LSWon02Z28's Avatar
Default BUILDS:
Got the car back yesterday now the fun begins
Rhode's Custom Auto did the chassis and body work the quality is second to none.
Current engine is a 383 small bore, compstar crank and rods, diamond nitrous pistons, with some old GTP heads. TH400, 9" etc etc - still need to decide on the direct port system and a few other things
Future use will be in a 275 radial class, current set up I think would qualify but not set the world on fire - gotta start somewhere to learn and get some seat time.
LSWon02Z28 is offline   Reply With Quote
Old 10-11-2009, 09:30 PM   #2
CanuckSS
Launchin
Default Re: 02 Camaro Build
Looks real nice!! Love the hood and the color!
Running a dry sump?
What igntion setup are you using?
CanuckSS is offline   Reply With Quote
Old 10-12-2009, 12:18 PM   #3
LSWon02Z28
LSWon02Z28's Avatar
Wet sump oiling, with a moroso vacuum pump. Ignition is a MSD 7531
Old 10-12-2009, 12:30 PM   #4
cryer
Spooled up
on the hood is that corner made out of alum of glass? we planed on doing the same thing. looks good
cryer is offline   Reply With Quote
Old 10-12-2009, 12:37 PM   #5
ken sloat
Member
Pullin gears
ken sloat's Avatar
Quote:
I'm interested in that as well. Are there any pictures of the underside available?
Has-been
ken sloat is offline   Reply With Quote
Old 10-12-2009, 12:55 PM   #6
LSWon02Z28
LSWon02Z28's Avatar
Rhode's Custom Auto made the corners...
The corners are made from aluminum. The first step is to use some light aluminum 90 angle and form it along the edge of the fender and bolt it on to the fender lip. Then fab up the corner pieces, remove the angle piece, and weld to the corner piece, remove fender and bolt it all up. There is no way to get to the underside with the fender on the car
Old 10-12-2009, 02:39 PM   #7
LSWon02Z28
LSWon02Z28's Avatar
Hope these help...
Old 10-12-2009, 03:10 PM   #8
ray toth
Burnout box
where did you get your rad and waterpump?
ray toth is offline   Reply With Quote
Old 10-12-2009, 03:12 PM   #9
LSWon02Z28
LSWon02Z28's Avatar
Radiator is a custom Afco, with a meziere pump
Old 10-12-2009, 07:36 PM   #10
zssman
Launchin
zssman's Avatar
Nice, well done. Any pics of the cage and interior?
zssman is offline   Reply With Quote
Old 11-15-2009, 01:31 PM   #11
LSWon02Z28
LSWon02Z28's Avatar
Did some plumbing work...
Old 11-23-2009, 07:29 PM   #12
ericg69ss
Default 275 Drag Radial Build Thread
So I posted something similar on the LS1 Tech and thought I would share this with the Yellowbullet community. I'm a bit of newbie on here but I'm looking forward to learning and hoping to be successful with the new combo. I think we have some great people on board and have had some key vendors step up to help sponsor the build.
Kurt Urban @ KUP is building the motor. He speced out the entire engine set up and I can't wait to see it when its done. Theo Dec @ Wizard Racing will be responsible for EFI and Suspension Tuning. Through Theo's great working relationship with Chris Alston Sr. and Chris Alston Jr., Alston Chassisworks is going to build the entire cage and rear suspension set up. They currently do not offer any 4th Gen F-body stuff and is going to use my car for R&D and develop a full line of drag race suspension, FAB 9" housings, and 25.2, 25.3, and 25.5 roll cages. Alston is very excited to enter the 4th Gen F-body market and is looking forward to provide the F-body community with some great stuff!
Car:
2002 Pontiac Trans Am WS6. Its being built for 275 Drag Radial classes in PSCA and WCHRA on the West Coast. We are going with a 25.3 set up. I believe this will make the car safer and more valuable if we want to go Forced Induction or sell it.
Engine (just some basic stuff):
485 Cubic Inch Nitrous LSx motor, 4.165" bore and 4.450" stroke
Dart LS Billet Block
Callies 4.450" Center Counterweight Crankshaft
Wiesco pistons
Dyers 300M Forged Rods
All Pro LSWr LS7 heads by West Coast Cylinder Heads
Jesel Belt Drive
Jesel custom shaft mount rockers
60MM camshaft in raised location
Custom Dailey 4 stage Dry Sump
Carl Fultz (CFE) Custom Tunnel Ram intake w/ 2 4500 TB's and plumbed for 2 Dry Direct Port Fogger systems
Trans:
JW Powerglide with Ultra Case, Ultra Bell, etc... built by Steve Casner
EFI Management:
FAST XFI with 8 160lbs per hour injectors to handle the fuel requirements for Dry Nitrous
Chassis, Suspension, and Safety:
25.3 Chromoly Alston Chassisworks and Wizard Racing
This is what I can think of so far and have include pics of the FAB work Theo @ Wizard Racing has done so far. Pictures are chronologic and looking good I think. Thanks for looking and will update as we make progress.
Some pics of what we are starting with.
In the first picture you can get an idea on how much stuff he took out. The bottom U shape brace is also coming out and getting replaced with chromoly tubing as well. You notice in this first pic a tube going between the frame rails and he put that there first before he started cutting the front off to keep things straight. Not a bad idea and it will come off when the front support is done.
The next 2 pics are of the left and right side of the front bumper support on the bumper of course. You can see how it mounts up and stabilizes the front cover.
The last picture shows the chromoly tubing he put together to hold the headlight covers on to retain the stock appearance. We completely eliminated all the OEM headlight mounting and put this in its place so the covers can stay attached. Pretty slick IMO. Hope you enjoy and more pics coming.
Here is more front end work from the chassis shop. The front end is going to be able to slide off as one piece when this is all done. Should be really slick. Anyhow, a lot more work to go but its coming along nicely.
Pics of the Cowl area welded and closed up. I think it looks pretty nice.
ericg69ss is offline   Reply With Quote
Old 11-23-2009, 08:55 PM   #13
Chevy406
Member
Pullin gears
Chevy406's Avatar
Default Re: 275 Drag Radial Build Thread
Fantastic build thread. You will certainly do your part in spreading LSX domination with this car. Sounds like Kurt is whipping up a monster for you.
Chevy406 is offline   Reply With Quote
Old 11-24-2009, 02:39 AM   #14
camscam02
Member
Pullin gears
camscam02's Avatar
very nice. I am going to see Theo on weds. to get my car scaled so ill get to see it in person. Can't wait. Ill snap some pics and tell your car you said hi. lol
R&E Racing 275 LSX Mustang Crew Chief
1/8 Mile Best: 4.24 @ 173 MPH
1/4 Mile Best: 6.82 @ 204 MPH NMCA SO Legal
2015 NMCA East Street Outlaw Champion
2014 NMCA West Street Outlaw Champion
2014 WCHRA 275 Drag Radial Champion
2014 SCSN Wild Street Champion
**Westcoast Doesn't Count**
Like Us: https://www.facebook.com/RandERacing
camscam02 is offline   Reply With Quote
Old 11-24-2009, 01:04 PM   #15
ericg69ss
Quote:
Nice!!! I haven't seen my car in person since I dropped it off over a month ago. That would be great if you took some pictures and sent them my way. My e mail is ericg43@hotmail.com or feel free to post them on the thread. Good luck with Theo on Wednesday and he will get you taken care of!
Resources saved on this page: MySQL 1.02%
