what base circle can I run in a 421 up ci small block - Yellow Bullet Forums
Old 10-11-2009, 03:20 PM   #1
64nova
Launchin
64nova's Avatar
Default what base circle can I run in a 421 up ci small block
do I need a small base circle cam or can I use a stock base circle cam. looking to build a 421 or bigger small block and no one can tell me what I need. if any other info is needed please let me know
drag racers do it til the rubber smokes
nova build
http://www.whateverittakesracing.com...?showtopic=956
64nova is offline   Reply With Quote
Old 10-11-2009, 03:27 PM   #2
totalchaos
totalchaos's Avatar
Default Re: what base circle can I run in a 421 up ci small block
strandard cam location will need a small base circle cam , raised cam can run a standard base circle.
hold my beer while i dance with your girlfriend
1998 Camaro Z28
2010 STR8 Jeep
2003 Mustang - Sbc swapped
totalchaos is offline   Reply With Quote
Old 10-11-2009, 03:34 PM   #3
Horndog
Do you already have a block?
If so what is it?
If not and you will be buying an aftermarket block, get a block with the cam tunnel raised like Dart's Iron Eagle.
In addition to the raised cam tunnel, this block also comes in either std deck height (9.025") or raised deck (9.325") version. Cubes up to 455.
Jim Horner
" ...oh no, what the fuck was that?
...the motor ... we've thrown a rod.
...is that serious?
...yup."
Horndog is offline   Reply With Quote
Old 10-11-2009, 05:06 PM   #4
manyponies
Member
Pullin gears
manyponies's Avatar
Get a raised cam block and then go to a larger journal and base circle. Its worth it
manyponies is offline   Reply With Quote
Old 10-12-2009, 11:02 AM   #5
us7race
us7race's Avatar
If you run Eagle 6" Stroker rods and a 3.875 Stroke crankshaft it will clear in a standard location block with a standard base circle cam. I have one in my motor with a .635/.630 roller it all works fine.
us7race is offline   Reply With Quote
Old 10-12-2009, 04:52 PM   #6
SStrokerAce
SStrokerAce's Avatar
Yep.... all depends on the rods and lobe lift really. I've done a bunch of cams for 3.875" strokes and the rods are usually the biggest issue with the clearance.
Prof Gordon Blair “Those engine developers who grossly exaggerate their engine’s power as evidence of their genius!” ARE IDIOTS
SStrokerAce is offline   Reply With Quote
Old 10-12-2009, 06:10 PM   #7
jmarkaudio
jmarkaudio's Avatar
Run a 2" rod journal, give you a bit more clearance.
jmarkaudio is offline   Reply With Quote
Resources saved on this page: MySQL 2.27%
