S10...Cal-trac or ladder bar? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension - TRZ Motorsports
Old 10-10-2009, 10:39 PM   #1
hiway
hiway's Avatar
Default S10...Cal-trac or ladder bar?
2800#, Iron BBC, braked glide, 12" wheel, 29.5x11.5 hoosier, narrowed frame. Wanting to HOOK! Just for going fast....no certain class. What's best...and hooks anywhere? Ladder or Cal-trac system?
Just your average Arkansas street machine
MidsouthRacers.com
hiway is offline   Reply With Quote
Old 10-10-2009, 10:44 PM   #2
1fast10
1fast10's Avatar
Default Re: S10...Cal-trac or ladder bar?
i run ladder bar here. hooks great with small tire. been 1.29 60ft footbraking with a 200 shot and 10.5 slick.ive heard caltracs can work great with track time to adj
www.precisionfabandwire.com
https://m.facebook.com/precisionfabwire/
Leashelectronics.com dealer
Holley efi dealer
Injector dynamics dealer
Nickels performance
1fast10 is offline   Reply With Quote
Old 10-10-2009, 11:10 PM   #3
hiway
hiway's Avatar
you using stock fram rails?
MidsouthRacers.com
Old 10-10-2009, 11:13 PM   #4
1fast10
1fast10's Avatar
yes stock frame rails with no tubs. i did brace the ladder bar brace really well for support
Holley efi dealer
Nickels performance
Old 10-10-2009, 11:13 PM   #5
Firetruck1
draggin' ass
Firetruck1's Avatar
I think they both will work, your gonna hve more of a issue of the weight of a iron bbc then rear suspension.
Michael
Thank you to all who have helped me on my projects:
Dan Neumann Race Cars
Fast Forward Race Engines
FTI Converters and Transmissions
Holeshot Wheels
Jones Racing Products
NRC Motorsports
TRZ Motorsports
“Le Petomane Thruway? Now what'll that a**hole think of next? Does anybody got a dime? Somebody’s gotta go back and get a sh**-load of dimes!”
I have sincere gratitude for gold star families. Thank you
Firetruck1 is online now   Reply With Quote
Old 10-10-2009, 11:16 PM   #6
hiway
hiway's Avatar
we have stock leaves, comp 3-ways, floaters, and home made ladders now.....tire spin lots. 1300 on the rear and a tad over 1500 on the front without driver. It's hulled and only has the bed sides in the rear. 2 batteries and small cell at rear. Moroso springs and 3-ways up front.
MidsouthRacers.com
Old 10-10-2009, 11:18 PM   #7
hiway
hiway's Avatar
1fast10 your ladder bars 32" long? Crossmember around where the front leaf mount was?
MidsouthRacers.com
Old 10-10-2009, 11:32 PM   #8
1fast10
1fast10's Avatar
i beleive they are 32" long. its a applied racing technoligy ladder bar kit. the crossmember is right where the frame starts to rise to go up at the rear tire. heres a pic
heres a pic of it on the wheelie bars going 1.29 60ft. did this with no transbrake and a crappy tci super street fighter tranny and a 200 shot. going 5.8s @120
Holley efi dealer
Nickels performance
Old 10-10-2009, 11:47 PM   #9
hiway
hiway's Avatar
Which kit did you get? What pinion angle do you run with it?
MidsouthRacers.com
Old 10-10-2009, 11:52 PM   #10
1fast10
1fast10's Avatar
i just bought the ladder bar diag link and crossmember.my angle is down -3*
Holley efi dealer
Nickels performance
Old 10-10-2009, 11:58 PM   #11
hiway
hiway's Avatar
You go with the qa1 doubles? 12" spring?
MidsouthRacers.com
Old 10-11-2009, 12:02 AM   #12
1fast10
1fast10's Avatar
yep. having some down track issues with current 110lbs springs but otherwise qa1 or better shock and def double adj.and yes im a 12" spring
Holley efi dealer
Nickels performance
Old 10-11-2009, 12:10 AM   #13
hiway
hiway's Avatar
I just found your thread. Nice vids! I was thinking 130's since that's what my Malibu has. You think the lighter spring is hurting your down track? I don't think I'm as heavy back there as you...do have two batteries but only outter bed sides and thin tubs. No bed. I appreciate the info! 1.48 is my best 60' and 6.42 is the best et. Haven't even touched the bottle yet. Figure it should be a tenth better in the 60 before I add any more power. What gear you run?
MidsouthRacers.com
Old 10-11-2009, 12:17 AM   #14
1fast10
1fast10's Avatar
i had 130lbers first and problem started after i went from .024 jet squared to a 4 jet split and picked up 1 tenth. that tenth has been nothing but headaches so far. at first we though it was front end. so i over hualed everything. added rack and pinion. went back to track with same problems. chenged to 110lbers and luanch was harder but still down track problems.think i need 85 cuase rear is stiff as hell.but who knows im gona work on the shocks some and figure it out somehow.i run a 4.29 gear with a th350 tranny. converter is a super street figheter. will stall around 3100 footbrakeing and flash 3800. on the gas it comes to life and flashes to 5000. i usally leave on the 2step at 2400rpm(i know its low but works). on motor its a dog. goes 6.6s-6.7s with 1.52-1.56 60ft. on gas been 1.29 a handfull of times and 1.32 consistant.usallu 5.85 to 5.95 et.depends if it gets loose on me or not. if i can hold it when it starts to get loose i goes 5.8s easy
Holley efi dealer
Nickels performance
Old 10-11-2009, 12:27 AM   #15
hiway
hiway's Avatar
Everyone tells me to trash my 4500 nitrous stall and 4:30 gear (mopar 8.75). I keep them in there wait on the day I can nuke it! As I understand it, you only want enough spring to hold up the rig and let the shock do the rest? Just asking. I don't have any pictures on this puter to post of my rig. My frame is cut behind the cab and move inward around 6" per side.
MidsouthRacers.com
