will closed chamber pistons work with open chamber heads? - Yellow Bullet Forums
Old 10-05-2009, 05:39 PM   #1
DaBu
Member
Pullin gears
DaBu's Avatar
Default will closed chamber pistons work with open chamber heads?
I have a .070 over 454 with a large dome closed chamber piston. the head was damaged and i have a set of open chamber heads. Will a closed chamber domed pistion work with a GM open chamber head.
DaBu is offline   Reply With Quote
Old 10-05-2009, 05:43 PM   #2
Collinsautomotive
Default Re: will closed chamber pistons work with open chamber heads?
Check it with clay. My thought would be that you will loose a bunch of compression.
Henry Ford, on the stock market
Quote:
"As betting at the race ring adds neither strength nor speed to the horse, so the exchange of shares in the stock market adds no capital to business, no increase in the production and no purchasing power to the market."
Old 10-05-2009, 05:53 PM   #3
DaBu
Member
Pullin gears
DaBu's Avatar
Quote:
When you say bunch of compression does that mean that it would go from say 14 to 1 to 10 to 1? or?
Old 10-05-2009, 05:55 PM   #4
Mark @ Meridian Tool
Mark @ Meridian Tool's Avatar
If we are talking Chevy or old TRW stuff, the piston will hit the head.
Oddly enough, the open chamber piston will usually clear a closed chamber head, but not the other way around.
Mark the Machinist
Thanks to:
Racetech Racing Engines Scott Carter
C.A.R.S. Sean Collins
TeamZMotorsports Dave Zimmerman
Greg Powrie
Mark @ Meridian Tool is offline   Reply With Quote
Old 10-05-2009, 05:58 PM   #5
396chevelle
396chevelle's Avatar
That seems bass ackwards??? No doubt you are correct.
93 mustang project
396chevelle is offline   Reply With Quote
Old 10-05-2009, 06:01 PM   #6
DaBu
Member
Pullin gears
DaBu's Avatar
They were a Venolia custom closed chamber piston.
Old 10-05-2009, 06:01 PM   #7
Collinsautomotive
I forgot the closed Chamber head has the valve deeper in the chamber. Still you can clay it up and see what ya get.
Old 10-05-2009, 06:02 PM   #8
Collinsautomotive
Quote:
without knowing a whole lot of specifics thats tough to say.
Old 10-05-2009, 06:13 PM   #9
I would mock it up to be sure but I will guess it ain't gonna work.
The good news is you can usually find open chamber TRW piston sets used
for a couple hundy or so.
Mark the Machinist
Thanks to:
Greg Powrie
Old 10-05-2009, 06:17 PM   #10
Collinsautomotive
If the domes are thickenough you might be able to use a bit of milling and clearancing on the piston and a thick head gasket if the interferance isn't to bad. IIRC its only .075 difference in valve depth between the 2 anyways.
Old 10-05-2009, 06:34 PM   #11
joesmithz28
Gonna lose an easy couple points of compression in that swap...probably 15-20cc worth of chamber size difference being conservative.
joesmithz28 is online now   Reply With Quote
Resources saved on this page: MySQL 2.17%
