First, get ready for what may be one of the longest single posts in YB history. Sorry about that. :-D
I just learned little bit about anti squat on this thread: http://yellowbullet.com/forum/showthread.php?t=169353
However, I've decided to start a new one rather than hi-jack SLOCOUPE's thread any further. Thanks to SLOCOUPE for starting that thread and thanks for all the info so far from "feetfirst"
The problem: I've made 72 passes in the car over the last year and have not once have I made it down the track cleanly. To say I'm frustrated would be about the biggest understatement ever. Right now I don't think I could get a kid's "Big Wheel" to hook in a puddle of VHT
That said, here's some of the specifics of the car: 25.5 93LX coupe, 94mm Precision turbo, G-trim, with a 1.0 A/R, 8 blade billet compressor wheel, 349 SBF, TFS R heads, super victor, 90mm TB, yada yada, FAST XFI fuel management (and I do have a driveshaft sensor and I do log DS rpm), MSD 7531, AMS-1000 boost controller. ProMod glide with 1.80 1st, Neal Chance bolt together converter (refined a coupe of times so far by Marty), Team Z/Strange 9 inch with a Moser aluminum 3rd member, 3.50 gears.
That's the basics of the power train, if other info is needed, please ask, I'm happy to provide it if it will help. I have been doing most of my testing on 325's (Hoosier's 1st, then M/T), but about a month ago I put a set of 275's on the car (M/T's) due to the recent popularity of 275 racing in my area. I run 10" alumastars with Sheppard bead locks. The car is 3300lbs with me in it (I'm 6'5" 250lbs).
Rear suspension:
I currently have Wolfe lowers and UPR uppers with Afco Big Gun coil overs and Afco 12" 150lb springs in the rear with a Wolfe double anti roll bar (note: I mentioned in the other thread I thought the roll bar might have a binding problem, but I verified last night that it is now moving freely). I did my testing last fall with Afco 12" 125lb rear springs, and I still have them. I have no extra control arm mounting holes other than stock, so the only instant center adjustment I have is changing the ride height.
One of the problems I think I'm having is too much adjustability in the coil overs. I've never had a shock or coil over with more than 10 clicks of adjustment and these have 40 clicks on separation and 20 clicks on compression. I've started at 50/50 began loosening separation and tightening compression, but I honestly didn't know where to start.
Current front suspension: KONI SPA-1 struts with QA1 14" 175lb springs on stock V-8 Fox Mustang spindles. I have about 5" of separation from rest at the current ride height (camshaft centerline is 18.75" from the shop floor). I also have a set of Wolfe travel limiters, so I can tie the front end down if I need to. I have a set of 14" 125lb springs I haven't tried with the SPA-1 strut and OEM spindle set up, but I think with the iron R302 block the 125's are too light. I will buy a set of 14" 150's to try very soon. I have been told by several people including Gordon Benson who is the drag racing guru at KONI that the SPA-1 cannot be adjusted tight enough for my application, but as of yet I can't get it to hook well enough to find out.
I have also tried (and still have sitting on a shelf) this set up:
AJE 2" drop front spindles with KONI yellow double adjustable inserts, and a set of Afco 14" 125lb springs. I didn't have but 1.75" of separation from rest with that set up, but I'm now thinking I gave up on it too soon. I now think that with the correct anti-squat percentage it would have worked.
If you watch the outlaw radial guys, NONE of them seem to have much front suspension separation. I know at one point there was an interview with John Kolivas in the NMRA Race Pages where he was quoted as saying after going to his 114mm turbo 427 cube Outlaw radial combo he had tied the front end down COMPLETELY to get the car to 60ft. Literally NO separation at all.
However, as I understand it (from Dave Morgan's "Door Slammers, the chassis book") it's take a TON of power (torque more specifically) to be able to get a car to transfer weight without the benefit of front suspension separation. John has well over 2000HP and I only have about 1300 (on a Mustang brand chassis dyno), so that may not work for me. I sure was hoping it would work because with that little suspension travel the car is a BREEZE to drive if it gets loose on the top end (which it always does if it see's anything over 20lbs of boost).
We have a set of Intercomp scales and I probably shouldn't have started this thread without the scaling info, but I'll get it today while I'm at the shop. I know the front to rear percentage has been roughly 52% front and 48% rear with me in it. I'm going out to move the batteries rearward today, hoping to get closer to 50/50. Here's where they are now:
I'll be moving the kill switch to the right side of the ice chest and the batteries as far rearward as possible, but the new setup will allow me to move them to any of 3 positions quickly if I need to change at the track.
OK, after "War in Peace," back to the title of the thread. The "anti squat percentage" thing is new to me, but after searching this forum extensively I now believe it must be critical to making a higher power radial car work.
Last night I did some "quick and dirty" measuring and came up with some insane numbers. I'm guessing my haste in measuring is at least partially at fault, but got 7" for my upper control arm length, and 17 3/8" for my lower length. (note: I have pinion angle set at one degree down, and I measured the control arm length 90 degrees square to the axle tubes) On the Induction Motorsports calculator they have 7.5" for the upper and 18" for the lower when you open the page. Is that pretty standard for a Mustang?
Anyway, I entered my data and I got this:
IC Length: 36.167
IC Height: 9.5
Anti squat: 140.323
I'm pretty old school (I'm 46 years old) and most of what I've learned over the years is from Dave Morgan's book: "Door Slammer's, the chassis book." The contents of that book are directed toward cars with slicks and either leaf springs, ladder bars, or aftermarket 4 links. Apparently I'm going to have to "unlearn" a lot of what I've learned to get a stock suspension radial car to work.
If that calculator (and my measurements) are correct, thinking old school on slicks, my instant center is WAY too short for a car of this power. But on radials, IS it too short? At my current ride height on the rear suspension, my lowers are dead level, 9.5" off the shop floor front and rear.
OK, if you are all not asleep from all the reading, what do you need to know?? I hope for all your sakes nobody ever gets as lost as I am right now. HELP!!
Rear suspension:
IC Length: 36.167
IC Height: 9.5
Anti squat: 140.323
