need advise on converter - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 08-30-2009, 11:47 AM   #1
04mustang
Pre-Staged
Default need advise on converter
Hi all, new here, I have a question about an issue ive been having this year. I'm thinking I have a converter that is too tight but I really don't know much about converters. So heres what I'm dealing with, 04 mustang 3200 lbs sbf powerglide tranny drag radials. Car runs 8.90's with small nos shot. Current converter is a tci 9" 6000stall nitrous converter. Engine has trouble stalling the converter to 5000 on the brake. So I have the 2step at 4500. Car leaves the line real nice and hard. will 60 ft in the mid 1.2's. Then through 1st gear engine seems to have a hard time to accelerate until it reaches about 7000 then pulls hard. Shift at 8000 rpm drops to about 6200 then again seems to just nose over till rpm reaches 7000 again then hauls. Just doesn't want to haul the mail. not sure if its the converter or not, but I am thinking it is. Any advise??
04mustang is offline   Reply With Quote
Old 08-30-2009, 11:48 AM   #2
04mustang
Pre-Staged
Default Re: need advise on converter
Oh glide is a tci pro x with 1.8 fist gear
Old 08-30-2009, 03:35 PM   #3
ericandkayti
Launchin
ericandkayti's Avatar
sounds like the stator is making the converter lock up too fast.
eric
ericandkayti is offline   Reply With Quote
Old 08-30-2009, 05:35 PM   #4
Tony Akins
Member
Pullin gears
Tony Akins's Avatar
Is it a custom converter or is it a shelf unit? Could you give me the part number along with your combo?
Tony Akins
TA PERFORMANCE
Custom Torque Converters and Transmissions
(662)-587-1665
Tony Akins is offline   Reply With Quote
Old 08-31-2009, 11:33 AM   #5
04mustang
Pre-Staged
tci converter pt # 251804 sbf 427 ci brodix neal 201 heads. engine makes peak torque at 5500 rpm and peak hp at 7500.
Old 08-31-2009, 10:10 PM   #6
DewRonInc
DewRonInc's Avatar
I have used PTC converters for some time, BTE, TCI, ATI all have been in my car, all worked fair, PTC worked best, Kenny owns place, lane and tim are the spec guys. I agree converter is too tight for your app.....
DewRonInc is offline   Reply With Quote
Old 09-01-2009, 03:38 PM   #7
gray86hatch
gray86hatch's Avatar
If the car is not comming up on the converter good and hard look at the carb.
Tim
86 mustang 3000lb
454 FTI LS3 Mast intake FTI hyd roller Holley EFI 275 MT e85
9.24 143.58 1.33 3.73 5.84 116.21
HR Drag Week 2013 ss-BB-NA Winner
LSX here we come
with help from
My wife and daughter's 2
www.flowtechinduction.com
www.boozebrothersracing.com
gray86hatch is offline   Reply With Quote
Old 09-01-2009, 06:43 PM   #8
04mustang
Pre-Staged
what sould I look for in the carb?
Old 09-01-2009, 10:01 PM   #9
Tony Akins
Member
Pullin gears
Tony Akins's Avatar
Are you wanting the converter to work with the nitrous or just on engine alone? If it's engine alone, it's the wrong converter.
Tony Akins
TA PERFORMANCE
(662)-587-1665
Old 09-02-2009, 01:52 PM   #10
gray86hatch
Alot of problems comming up on the converter are due to a carb that is not setup correctly.
I am not a carb guy but have been around guys that found quite a bit in the carb.
Tim
86 mustang 3000lb
LSX here we come
with help from
Old 09-02-2009, 05:06 PM   #11
04mustang
Pre-Staged
thanks for the input. Tony, this engine is run primarily on nos. Had the car on the chassis dyno today, with the nitrous on we started the pulls from 5000 rpm when I mashed the throttle the engine would dart to 68 - 6900 and would spike up and down in rpm throughout the pull till i shut it down at 7500. seems weird to me.
Ive going to borrow a convereter from a friend this weekend see if the problem stays or not.
Resources saved on this page: MySQL 2.17%
