#1 |
I'm running about 10.3:1 static. I'm thinking of throwing about 7-8 pounds at it with a ProCharger.
What do you think? Too much compression to throw forced air at it? |
#2 |
Member
Pullin gears
Nope, have at it. make sure you have a good tuner to make it safe. lots of guys running that type of compression these days. the tuning is alot better than it was back with the 8.5:1 was as high as guys would go. Let me know if you need help with getting a procharger as well.
Michael Keenan XS4996 PROCHARGER DEALER Thanks to Wade at Southern Speed - www.southernspeedracing.com Jeff at Jeff Burns Racing Engines Tony at HP Performance - http://www.hp-performance.com Automatic Transmission Factory - www.atfspeed.com Greatest Fear: When I die, my wife will sell my race car and parts for what I told her I paid for them! |
#3 | |
Quote:
Thanks, I was worried about the mechanical aspects...thanks for the response. |
#4 |
Launchin
I used to be 10:1 and 10psi, not a problem!
#5 |
Spooled up
10.3, 17 psi, pump gas and meth, daily drive 300 miles a week, 24mpg.
http://www.youtube.com/watch?v=HrzYsvEbrcA |
#6 |
Burnout box
10.5, 15 psi, carb and E85.
#7 |
Pre-Staged
what about running 12 .5 with race gas and an f1r on my 496 bbc.. i can get it down to 11.5 with gaskets if needed as well. i know this is not the ultimate setup . but can it work. im sure that 8 to 1 with pump gas and boost will get me the power i want but the car is running now. but with big compression and a N/A cam grind. i dont mind running race gas. so is it still worth it to drop compression. the car is all steel street car but less than 500 miles a year.
#8 |
Launchin
We have ran as much as 14.5 on alky with 50 psi with no problem.
#9 |
Burnout box
The common thing here is good fuel, and lots are using alky which we all know is a cool fuel. literally. lol
I was not aware people are running that much compression and boost, are these mostly drag cars? Are they living on the street? Suppose e85 is the minimum on fuel, pump gas would not cut....or I am thinking it wouldn't. |
#10 | |
Launchin
Quote:
Thats alot of compression especially if you hammer on it after a decent drive when everything is good and hot. Id drop it to the 11.5. Im fairly certain it would work at 12.5 but the 11.5 just opens your tuning window up for a small mistake and im certain it better be really small. LOL. I'm running 9.7:1 with my sbf and F3 thats set up for 35psi give or take a few. But thats a drag only engine. If you have a good meth injection setup then you will be fine especially on race fuel. I would say if you dont mind the cost run c16 even on the street. It gets the looks when ya roll to the ice cream stand on a friday nite and everyone smells it.
#11 |
Pre-Staged
thanks for the feedback.
im thinking about changing head gaskets to drop compression and a cam change . droping from a 4.10 gear to a 3.25 or so and about 8 lbs boost . the car is a 11. 00 car now with all stock water pump fan and air cleaner. and full exaust and i want a full sec more. with a more drivable gear and cam . and boost . thanks. |
#12 | |
Launchin
Quote:
Boost is a drug its awfully easy to get addicted!. Best of luck to ya. should make for a real nice ride on the street. |
#13 |
Launchin
The 14.5 and 50 psi is in my friends Top ALky Dragster. I have also seen this kind of comp and boost in Mark THomas's Top Alky Funny car on E98.
#14 |
Spooled up
How many of you guys are using pump gas, 91-92 Octane? I have a vortec headed 383 with 10.7-1 and am looking at around 10 lbs. what would you guys suggest to keep it alive
#15 |
Spooled up
| Thread Tools | |
| Display Modes | |
