brodix gb 2500 heads or sb2.2 heads - Page 2 - Yellow Bullet Forums
Old 06-14-2009, 10:30 PM   #16
powerade
powerade's Avatar
Default Re: brodix gb 2500 heads or sb2.2 heads
Quote:
Originally Posted by kba1987 View Post
I have a delima I would like to know what heads you guys think would be best for my application. My motor is 428 inches max effort n/a deal going to be running the ram racing stuff and some local stuff,I dont know what head I should go with I have a dart iron eagle block that has a std lifter bore pattern in it I know you can use this on a sb2.2 head but I am worried about valvetrain issues with it turning 9500 rpms. Should I go ahead with the sb2.2 or should I stick with a more convential set up like the gb 2000s,I am trying to make 1000 hp can it be done with gb 2000s. One more thing to consider is thier will be a added weight for the sb2.2 heads over the gb 2000s just need some input on what you guys think.
SB2.2's they make more power, at 428 CID they should make minimum 2.3 HP per cube if done right, MBE would be a great choice Matt can hook you up. http://www.mbellc.com/drag_sb22.html
powerade is offline   Reply With Quote
Old 06-14-2009, 11:05 PM   #17
kba1987
kba1987's Avatar
Like I said before I am going with the dart 9 degree head I know the sb2.2 head makes big power but if you can get the same cross sectional area,same flow,intake cc and valve size why wouldn't this head make as much power as the sb2.2 it also has a shallower valve angle than the sb2.2.
kba1987 is offline   Reply With Quote
Old 06-15-2009, 12:00 AM   #18
powerade
powerade's Avatar
Cool you will have to buy them from Ultra Pro Machining,along with their fabricated manifold, Don makes killer stuff, post your dyno # and ET's as long as there is no rule against billet heads in the class you plan to run they should make lots of power.
http://www.ultrapromachining.net/index2.html
Old 06-15-2009, 12:07 AM   #19
kba1987
kba1987's Avatar
Dart has the bare casting they took lasitos billet head and casted it, Its designed just like the billet head.
Old 06-15-2009, 12:11 AM   #20
John Wilson
Wonder how that top end (heads/intake/shafts) compares cost wise with the CFE 10 stuff?????? Sure looks sexy!
John Wilson is offline   Reply With Quote
Old 06-15-2009, 12:15 AM   #21
powerade
powerade's Avatar
I spoke to Dart, they said they do not have a casting, if they do post up the part #, not trying to pee in your cheerios just repeating what I was told.
Old 06-15-2009, 12:18 AM   #22
kba1987
kba1987's Avatar
John I have the bare castings on order they wont be out for about 6 weeks,I called jesel and they dont have a rocker set up for it but t&d does jesel told me it should not cost any more than your typical 18 or 15 degree set up since it is going to be a massed produced head and not a one off custom.
Old 06-15-2009, 12:21 AM   #23
kba1987
kba1987's Avatar
I build the engines at doug herbets and they have them just not avaible yet I have them ordered.
After months of development with Don Losito and intense dyno testing, our new nine degree small block Chevy cylinder head is now available... and we've got some specs for you!
Here's a quick breakdown for you.
Nine Degree Small Block Chevy Cylinder Head Specifications:
Valve Angle: 9 Degree parallel valve
Intake Valve Diameter: 2.200", 2.230" Titanium valves
Exhaust Valve Diameter: 1.625" Titanium Valves
Intake Port Volume: 299cc
Intake Port Dim: 2.345 x 1.440
Exhaust Port Volume: 215cc
Exhaust Port Dim: 1.725 x 1.645
Lifters: Intake 0.150" offset
Spark Plug: 3/4 Reach 14mm
Spring Pockets: 1.625"
Valve Length: 5.840"
Valve Stem Diameter: Available from 7mm to 11/32
Valve Guides: Manganese Bronze
Valve Seats: Beryllium Copper or Ductile Iron
Bore Spacing: 4.400" or 4.500"
These heads are cast from C355-T61 aluminum alloy. They are available with chamber volumes as low as 38cc and multiple exhaust bolt patterns.
Features include raised intake and exhaust port locations, optimized spark plug locations, extra thick decks, expanded water jacket capacity, bosses for down nozzles and revised valve cover rail to clear long ratio rocker geometry.
9 Degree piston available from Race Tech Pistons and Diamond Pistons, rocker arms available from T&D Machine and Jesel.
Old 06-15-2009, 12:22 AM   #24
powerade
powerade's Avatar
Wink Re: brodix gb 2500 heads or sb2.2 heads
Thats cool, I spoke with Don and he says to go 4.5 bore space, he can fit a huge intake valve into it, will dart make a 4.4 and 4.5 bore space cast version ?
Old 06-15-2009, 12:25 AM   #25
kba1987
kba1987's Avatar
Yes 4.4 or 4.5 I belive you will be able to get a 2.250 int valve in the 4.400 with a 1.580 exh valve.
Old 06-15-2009, 12:29 AM   #26
powerade
powerade's Avatar
This is a motor that I want to see !!!! sounds great so far !!
Old 06-15-2009, 12:33 AM   #27
kba1987
kba1987's Avatar
Be patient its coming together slowly just ordered the heads and keyway lifters thursday
Old 06-15-2009, 12:34 AM   #28
powerade
powerade's Avatar
I will, I have this book marked, I'm very interested in your build.
Old 06-15-2009, 01:26 PM   #29
Chris Uratchko
Moderator
Chris Uratchko's Avatar
I'd be curious as to why they chose 9 degree for the valve angle. Small CID stuff?
I'm also curious to see how the head likes rpm given the chamber and valve angle.
Chris Uratchko is offline   Reply With Quote
Old 06-15-2009, 10:19 PM   #30
kba1987
kba1987's Avatar
Chris just curious to why you would think this head is made for small cid motors? What does the chamber and valve angle have to do with rpm didn't you run some 10 degree cfe heads on Butches car and twist the $hit out of it?
