stock suspension malibu & 12 in. rim - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension - TRZ Motorsports
Old 05-23-2009, 02:03 AM   #1
emoutra1
Pre-Staged
emoutra1's Avatar
Default stock suspension malibu & 12 in. rim
Can u fit a 12 in. rim under a 80 malibu with stock suspension, coil overs, and notched frame rails?
emoutra1 is offline   Reply With Quote
Old 05-23-2009, 08:21 PM   #2
excelerater
Senior Frog
excelerater's Avatar
Default Re: stock suspension malibu & 12 in. rim
I could not make it happen on my malibu when I tried,supposedly it can be done
but I have not seen it with my own eyes
excelerater is offline   Reply With Quote
Old 05-23-2009, 10:33 PM   #3
mikeyfrombc
mikeyfrombc's Avatar
what size rim and tire you running now Mitch ?? we,re gonna be notching and halftubbing my kids 81 bu here shortly looking for idea i know before you had a 10" rim a small w yrs back
Demon Precision Products
mikeyfrombc is offline   Reply With Quote
Old 05-23-2009, 11:04 PM   #4
Drag Radial
SOFA KING WHAT?
Drag Radial's Avatar
10 inch is about the most you can go without seriously cutting out the rear frame rail to nothing. 10 inch rim and a 295 or 315 works well for some really fast guys.
Quote:
Originally Posted by Monte Smith View Post
You CAN'T make rules based on what guys HAVE..........you have to make rules based on the POTENTIAL on any given combo. FAIR is next to impossible..............plus FAIR is a place where they have rides and pigs are judged, has nothing to do with racing..............LOL!!!
Monte Smith
Drag Radial is offline   Reply With Quote
Old 05-24-2009, 11:00 AM   #5
dover1320
dover1320's Avatar
With a full notch and a stock width rear you can fit a 10 in wheel with a 5.5 bs
dover1320 is offline   Reply With Quote
Old 05-24-2009, 08:53 PM   #6
JeffMcKC
JeffMcKC's Avatar
10's all I can fit
"IF IT DOES NOT HAVE A TRAILER HITCH ITS A RACE CAR!!!"
TRZ Dealer
2012 Winner SSSB/NA 9.67 @ 139MPH
2007 Winner SB/NA Drag Week 9.98
Thanks Curtis @ RFD Heads and Intakes
http://www.raceflowdevelopment.com/
JeffMcKC is offline   Reply With Quote
Old 05-25-2009, 08:53 AM   #7
gr8pumpkin
www.punisherracing.net
gr8pumpkin's Avatar
1988 Cutlass, but a G body is a G body. I have a 9" rear with
12" rims that have 6.5" backspace. They have 29.5 x 10.5w
on them with no problems.
gr8pumpkin is offline   Reply With Quote
Old 05-25-2009, 09:05 AM   #8
McLovin
McLovin's Avatar
I tried that size and it would not fit and Im max daddy on the notch to the point where its just sheetmetal
McLovin is offline   Reply With Quote
Old 05-25-2009, 10:28 AM   #9
4doorbu
J&E POWER!!
4doorbu's Avatar
but your frame rails aren't in the stock location...
Former Wild, now Mild Bill Dutka retired ODR racer...
4.42 179mph
Tuned by OAB RACING!!!
www.jandeperformance.com
www.trzmotorsports.com
www.rhodescustomauto.com
www.187graphix.com
www.proformanceracingtransmissions.com
"It would be great to see Wild Bill racing Ultra instead of riding around on a bike-drunk!!!"-Chris Evans
4doorbu is offline   Reply With Quote
Old 05-25-2009, 10:31 AM   #10
mikeyfrombc
i.ll try it shortly we,re just about finished scrapping all the seam sealer from the floor pan and the trunk , i,ll be cutting the wells and notching the frame shortly , i have a some tires on a 12" rim and a set of 12" wide rims with no tires i,ll do some test fitting .
Old 05-26-2009, 07:25 PM   #11
gr8pumpkin
gr8pumpkin's Avatar
Quote:
But my rails are moved the same amount as a notch
Its the rear being narrowed that allows the 12" rim
Old 05-26-2009, 08:06 PM   #12
JeffMcKC
JeffMcKC's Avatar
That would be a no, I call bullshit on that one
TRZ Dealer
Old 05-26-2009, 08:23 PM   #13
HardonParts
Chinese buffet destroyer
HardonParts's Avatar
ive got a 12 bolt factory long, with a 10 inch wheel, and 6.5 of backspace. i dont know about a 12 inch wheel, its really tight with a 10 inch wheel, if i shortened my axle tube and axles i could tuck the tire in more but a 12 might work. its hard to say, it gets really tight with the setup i've got.
1978 Chevy Malibu BBC, Nitrous, 25.5 X275 Drag Radial
Motor City Outlaws c.c
HardonParts is offline   Reply With Quote
Old 05-26-2009, 11:52 PM   #14
charasmatic1965
Launchin
charasmatic1965's Avatar
That's true I have a 9.5 rim with a 10.5 x 29.5 and it's tight. 12" is a real stretch for sure.
It's only a 396/375
charasmatic1965 is offline   Reply With Quote
Old 05-28-2009, 12:31 AM   #15
9sec231
Launchin
Ten inch is about it without relocating the springs n lower control arm . I got the most notching you can do on the outer frame leaving the stock inner per the rules and i can fit a 10.5x28 w or a 10x29.5 and thats all .
9sec231 is offline   Reply With Quote
Resources saved on this page: MySQL 0.99%
